UART ttyS2 on RockPro64 for custom communication
1) > We get some Uboot messages on boot, after that the port is silent.
There may be a bug.
You should try to another image from the location shown in the following url.
If it works as expected, the problem you pointed out is a kernel bug.
For example,
https://dl.armbian.com/rockpro64/archive/
Armbian_5.67_Rockpro64_Ubuntu_bionic_default_4.4.166.7z
or
https://github.com/ayufan-rock64/linux-b...oad/0.8.3/
bionic-minimal-rockpro64-0.8.3-1141-arm64.img.xz
or etc.
2) > Due to voltage issues, we regulated the TXD and RTX pins to exactly 3.3V (see schematic attached).
Is the product that you pointed out the problem listed below ?
https://store.pine64.org/?product=padi-serial-console
If it is not a defective product and the output signal of a good product is 3.8v, it is a terrible product.
In the presented schematic, you can use resistor splitting to solve the problem,
but if you choose a resistor value that is higher than necessary, the problem arises.
The presence or absence of harmful effects depends on the parasitic capacitance due to the wiring length.
I think it is better to choose a value (220Ω / 1KΩ) that is about 1/100 of the resistance value of the circuit diagram that you presented.
RE: UART ttyS2 on RockPro64 for custom communication - by t4_4t - 08-21-2019, 02:27 PM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,449 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 979 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,395 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 888 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,715 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,924 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,199 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,603 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,254 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,812 05-16-2022, 02:34 AM
Last Post: dukla2000
