board not working
(08-30-2019, 09:49 AM)kardanadm Wrote:
(07-03-2019, 05:27 PM)evilbunny Wrote:
(07-03-2019, 07:17 AM)kardanadm Wrote: Hi
When I woke up one morning, I wanted to turn on rockpro64, but it didn't. Green LED flickers, white and red LEDs do not light. board not working. What could be the problem?
"RockPro64 4GB"
The green led shouldn't flicker, what power supply are you using?
board is still not working. Should I throw it in the trash or repair it? What is your advice? where the problem may be. I want to take it to an electrician for repair. Is there any possibility of repair?
According to the wiki, the green LED should light as long as there is 12V applied to the connector. (Even if the RockPro64 is powered off.)
I have no clue on what is your issue, and I dont have such devices yet, but if I were you I would start by looking at the card, and check if there is some burned electronic component.
By the way, after how much time did you get this issue ? Are you using your device a lot ?
board not working - by kardanadm - 07-03-2019, 07:17 AM
RE: board not working - by evilbunny - 07-03-2019, 05:27 PM
RE: board not working - by kardanadm - 07-06-2019, 03:04 AM
RE: board not working - by kardanadm - 08-30-2019, 09:49 AM
RE: board not working - by kaylios - 08-30-2019, 10:11 AM
RE: board not working - by kardanadm - 08-31-2019, 04:50 AM
RE: board not working - by kaylios - 08-31-2019, 06:23 AM
RE: board not working - by kardanadm - 08-31-2019, 07:37 AM
  power button not working Vista8720 0 124 05-07-2024, 11:26 PM
Last Post: Vista8720
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 820 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 710 08-14-2023, 07:55 AM
Last Post: kundanjha
  Cant get rockpro64 working brasilikum 3 1,889 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,768 02-06-2023, 10:10 AM
Last Post: diizzy
  Cannot get my board to boot deutschlmao 11 8,479 09-05-2022, 04:23 PM
Last Post: ljones
  After Power Loss feature working bdherouville 2 2,290 08-22-2022, 03:52 AM
Last Post: bdherouville
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,798 02-11-2021, 10:18 AM
Last Post: LMM
  When did the wifi module start working? stormchaser3000 1 3,116 11-12-2020, 08:59 AM
Last Post: Darren
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 7,735 10-18-2020, 08:05 PM
Last Post: revoman
