Cannot get my board to boot
I'm not super great at figuring these things out. But I'm trying to boot Dietpi on my rockpro64 board and all I get is a flashing white light. How can I fix this? I'm not really sure what to do. Detailed instructions would help a lot Big Grin thank you!
(02-28-2022, 09:27 PM)deutschlmao Wrote: Hello,
Can you get anything to boot on it. Are you.booting from eMMC or SD card.
I'm booting SD card and no I cannot
Try installing Armbian to rule out any hardware issues with your board. Install instructions can be found here https://wiki.pine64.org/wiki/ROCKPro64_Software_Release
None of these downloads actually download anything and a few are broken
Yes I've just seen that. 404 error on them all. This is the link to the archive versions. Pick whichever suits, probably Buster current 5.4.8 and follow the instructions on how to install from the wiki page
Remember this is just to test if your board is booting.
https://armbian.hosthatch.com/archive/ro...4/archive/
Since above URL may change, the actual download page is https://www.armbian.com/download/ then click on ROCKPro64 -> https://www.armbian.com/rockpro64/ then scroll down to bottom where you will find links to builds.
Cheers,
TRS-80
Protocols, not Platforms
Still only getting the white light with these builds D;
(03-16-2022, 04:41 PM)deutschlmao Wrote: Still only getting the white light with these builds D;
That doesn't sound good.
I'm assuming you are using the official power supply from Pine. Do you have another power supply you could try.
It was the microSD. I tried another one today and got it fixed
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,871 06-21-2025, 06:21 AM
Last Post: aleksei
  enble boot after power loss/restore dkebler 18 30,332 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 226,154 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,153 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 4,541 09-08-2023, 08:14 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,852 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 13,789 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,126 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,617 09-06-2022, 10:32 AM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,580 07-19-2022, 10:48 PM
Last Post: hazz
