Sometimes no power to SATA PCIe controller
I am not good enough at linux or hardware  and i no longer have a working asm 1062 card same revision but i just wanted to tell you that i had the same issue using the same image "Linux rockpro64 4.4.132-1075-rockchip-ayufan-ga83beded8524 " with ASM1062 not recognizing my hard drives. I found it to be reproducible by leaving the power off for over an hour or overnight and pluging in the dc charger in to power socket on the wall, this started drives spinning but sata card not communicating to them.
I purchased different sata and still testing if it resolves the issue but look at the post https://forum.pine64.org/showthread.php?tid=7538&page=4 created by me and look at some urls with pcie delay but not sure how to implement those or test.
RE: Sometimes no power to SATA PCIe controller - by vecnar - 06-13-2019, 07:03 PM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,314 04-01-2024, 10:24 PM
Last Post: nano2
  Which SATA card should I use my NAS server RAID5 Louysa 3 974 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 605 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 466 09-15-2023, 04:20 AM
Last Post: JPT223
  RP64 Won't Boot After Power Down ColPanic_ 10 7,995 06-27-2023, 07:31 AM
Last Post: dkebler
  Compatible PCIe Sata Controller spacebricker 1 1,610 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,279 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 1,383 11-28-2022, 05:12 PM
  NAS Setup: Hdds PSU external power option Robotik 1 1,767 07-18-2022, 10:10 PM
Last Post: zer0sig
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,952 04-01-2022, 11:25 AM
Last Post: ashleymills
