PCIE SATA controller ASM1062 problems or software
#28
(06-02-2019, 05:02 AM)Nikolay_Po Wrote: This is good enough soldering:
[Image: attachment.php?aid=1357]
All the jumpers are conducting the signal to corresponding SATA connectors pins? This is right time to check by a DC Ohmmeter. You may loose O-ring if it is on inactive side of PCB. If other side with a PCB trace is OK, the connection will be OK.
You have decreased the stray capacitance by replacing larger jumper by smaller. If they are conducting right and not shorted between each other, this is all you may done here.
Looking into the dmesg output...
Thank you Nikolay,
I had some paste laying around with soldering iron so I assume it was flux as it was non conductive. Cleaned it after with methylated spirit and a tooth brush, something I had at home.
I tested for shorts yesterday and there were none between neighbouring pins. Sata connector pinout is the same on both connectors. Pins 2,3,5 and 6 are linking to soldered posts. pins 1,4 and 7 have no connections to soldered posts and looking online for pinout they are ground
RE: PCIE SATA controller ASM1062 problems or software - by vecnar - 06-02-2019, 05:52 AM
  Which SATA card should I use my NAS server RAID5 Louysa 3 976 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 606 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 467 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,614 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,285 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 1,383 11-28-2022, 05:12 PM
  Existings disks and using a StarTech SATA Controller jkugler 1 2,133 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,590 11-27-2021, 11:38 PM
Last Post: Cerberus
  Rockpro64 Sata Card kills itself jerry110 33 45,050 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 3,039 09-15-2021, 12:46 PM
Last Post: corax
