USB3 enough to power 2,5 external HDD?
(05-26-2019, 04:07 PM)va88 Wrote: I tried another USB 3.0 external drive, a Seagate Expansion with 2TB, small form factor too. This one won't mount and will keep beeping everytime I time ask to mount (the command hangs in the terminal).
Could you give mainline a go?
USB3 enough to power 2,5 external HDD? - by va88 - 05-25-2019, 01:59 PM
RE: USB3 enough to power 2,5 external HDD? - by Luke - 05-26-2019, 04:08 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 338 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,271 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 4,665 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  Alternative power supply ju0n 0 1,037 09-06-2022, 02:46 AM
Last Post: ju0n
  USB3 SATA ReleaseTheGeese 2 2,779 04-04-2021, 12:55 PM
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 2,529 08-21-2020, 09:16 PM
Last Post: prog-amateur
  USB3 to SATA cable - Firmware Eule 0 2,195 03-03-2020, 01:31 PM
Last Post: Eule
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 4,450 01-02-2020, 02:26 PM
Last Post: dpgraham
  Using a stronger power supply myn4m3 1 2,884 06-23-2019, 05:01 PM
Last Post: Rocklobster
  How to check if my power supply is underperforming? va88 3 4,574 06-02-2019, 05:59 PM
Last Post: va88
