Using a stronger power supply
right now I dont have a 5V 3A power supply
but I got another 6V 5A.
Can I use that for longterm?
thx
No. Don't use it at all.
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,831 03-24-2025, 06:41 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 19,811 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 8,703 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  Alternative power supply ju0n 0 3,352 09-06-2022, 02:46 AM
Last Post: ju0n
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 3,698 08-21-2020, 09:16 PM
Last Post: prog-amateur
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 5,986 01-02-2020, 02:26 PM
Last Post: dpgraham
  USB3 enough to power 2,5 external HDD? va88 11 21,663 06-06-2019, 03:40 PM
Last Post: va88
  How to check if my power supply is underperforming? va88 3 7,022 06-02-2019, 05:59 PM
Last Post: va88
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 9,462 01-09-2019, 01:02 AM
Last Post: t4_4t
  Boot on power-up vicencb 1 4,564 11-26-2018, 11:45 PM
Last Post: evilbunny
