Install OS on RAID1 thanks to dual SATA board?
(05-07-2019, 04:34 PM)markb1 Wrote: I don't have my RockPro64, yet. (It's on its way!) I hope to do something similar. You should be able to put just the boot partition on the SD card, and then put your root partition on SATA drive. The best way to accomplish this may be to start with a complete Linux image on the SD card and boot up on it. Then setup the SATA drives as RAID1, create a partition, and copy the root partition files from the SD card over. Then configure your fstab to make the new partition root and update your bootloader configuration.
Note: The above is all speculation, and I haven't tried it!
But what I really want to do with my system is eliminate the SD card dependency entirely. I think this should be possible with u-boot, assuming u-boot has built-in support for SATA. Just flash u-boot the SPI and configure it to boot from SATA!  Probably easier said than done! But it seems like it should be possible.
As your RockPro64 is on the way and you plan to try that out, would you mind taking notes of your work and share them or even better write a step by step tutorial that, who knows, could be published on pine64's wiki?
That would be awesome!
RE: Install OS on RAID1 thanks to dual SATA board? - by Thatoo - 05-08-2019, 05:59 AM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 728 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  Star64: SATA Der Geist der Maschine 1 1,063 07-26-2023, 12:35 PM
Last Post: Gladox114
  PBP Debian 11 GRUB install error zlth 2 1,992 11-18-2022, 07:42 AM
Last Post: zlth
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,606 10-06-2022, 08:46 PM
Last Post: ihab
  wrong launguage install chadace 1 4,068 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 6,501 03-18-2020, 09:42 AM
  Rock64 suitable for headless TVHeadend install? elsmandino 3 6,517 06-26-2018, 11:37 AM
Last Post: Luke
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,239 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  My first Single Board! jjh221 4 6,832 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 4,438 03-31-2018, 04:09 AM
Last Post: pfeerick
