Android 9 for Rock64?
#33
-----------------RELEASE NOTE------------------------------- ------------
[rk3328_box_pie_release_v1.1.2_20190418.xml]
Uboot & kernel:
  1.uboot: Repairing small memory may cause malloc failures;
  2.kernel:fixed PCM DSP format;
  3.kernel:dw-hdmi: Fix some scenes such as the voice assistant playing the beginning of the sound loss problem;
System:
  1. Fix boot animation package with audio.wav audio playback failure;
  2.TvSettings more settings to add performance floating window function;
  3. Fix the probability of googleplayservice crash when integrating gms;
  4. Fix the problem that the focus of the playmovie&tv part cannot be operated;
  5. Fix the video conference zoom application call without sound problem;
[rk3328_box_pie_release_v1.1.1_20190403.xml]
System:
  1. Fix the invisible problem of the mouse icon on the Amazon video playback interface (frameworks/base);
  2. Fix some machines with low probability to boot systemserver no response problem (frameworks/base);
  3. Fix some apk under infrared simulation mouse click input box will not automatically play soft keyboard problem (frameworks/native);
[rk3328_box_pie_release_v1.1.0_20190401.xml]
RKDocs&RKTools:
   1. RKDeviceTest update, support lamp configuration, etc.;
   2. Update the "RK3328 Software Development Guide Document" to the V1.3 version:
a. Add a common configuration macro description
b. Update the WideWine function configuration instructions
c. Add adjustment and save of display parameters
d. Add system debugging - Lastlog open
e. Add system debugging - serial debugging
f. Add system debugging - Log automatic save system abc.
3. Add customer common custom function patch package directory RKDocs/rk3328/PATCHES
4. Update each module's documentation to the latest version.
5. Update the programming tool to v2.65, fix the exception such as erase failure;
  6. Update tools such as KeyWrite and SecureBootTool.
Uboot:
   1. Fix 8bit logo display exception problem;
System:
  1.update aosp codes to android-9.0.0_r33;
  2.secure patch update to SPL 2019-03-05;
  3. Update hwc to version 0.56:
    a. Repair h HDMI color mode switching failure;
    b. Fix some apps to exit the splash screen;
    c. Fixing the vrefresh calculation exception causes some resolution settings to be abnormal.
    D.swith to new code branch
    e. Fix kodi playback hdr invalid problem
  4. Update settings new features:
    a. Add the application dynamic uimode whitelist function;
    b. Add the power button function menu option;
    c. Add a home page option;
    d. Repair screen saver function, fix setting screen saver setting time does not refresh abnormally;
    e. Add a boot volume protection switch option;
    f. Fix the usb option function abnormally;
    g. Fix Bluetooth Receive File option cannot open the question, etc.;
   5. Fix the boot video can not play abnormally if there is an animation package;
   6. RKDeviceTest update, support lamp configuration, etc.;
   7.omx library update, optimized 4k online play;
   8. Update the video library to the latest, fix memory leaks;
   9. Fix screencap exceptions in some scenarios
   10. Fix settings Advanced function Power button configuration user version invalid problem:
   11. Fix the problem that the network adb switch and the abc background log save switch are invalid under the user version;
   12. Fix some selinux permissions issues;
[rk3328_box_pie_release_v1.0.0_20181206.xml]
Initial release
Just a pity we will never see such Android Pie firmware since it was abandoned.
Android 9 for Rock64? - by Blinky - 01-19-2019, 01:22 AM
RE: Android 9 for Rock64? - by fender90 - 01-19-2019, 10:46 AM
RE: Android 9 for Rock64? - by Pepe - 02-04-2019, 11:11 AM
RE: Android 9 for Rock64? - by tllim - 02-06-2019, 05:40 PM
RE: Android 9 for Rock64? - by fender90 - 02-08-2019, 01:15 PM
RE: Android 9 for Rock64? - by Blinky - 03-04-2019, 11:27 PM
RE: Android 9 for Rock64? - by tllim - 03-06-2019, 02:49 PM
RE: Android 9 for Rock64? - by shripal17 - 03-08-2019, 12:03 AM
RE: Android 9 for Rock64? - by psychedup - 03-14-2019, 11:03 AM
RE: Android 9 for Rock64? - by shripal17 - 03-17-2019, 08:05 AM
RE: Android 9 for Rock64? - by Blinky - 03-18-2019, 10:10 PM
RE: Android 9 for Rock64? - by tllim - 03-25-2019, 10:01 PM
RE: Android 9 for Rock64? - by Blinky - 04-01-2019, 12:26 AM
RE: Android 9 for Rock64? - by Blinky - 04-09-2019, 09:00 PM
RE: Android 9 for Rock64? - by tllim - 04-15-2019, 02:57 PM
RE: Android 9 for Rock64? - by tllim - 04-16-2019, 01:50 PM
RE: Android 9 for Rock64? - by fender90 - 04-16-2019, 04:26 PM
RE: Android 9 for Rock64? - by tllim - 04-16-2019, 04:33 PM
RE: Android 9 for Rock64? - by kostaman - 04-16-2019, 09:03 PM
RE: Android 9 for Rock64? - by fender90 - 04-27-2019, 05:30 AM
RE: Android 9 for Rock64? - by kostaman - 04-28-2019, 11:59 PM
RE: Android 9 for Rock64? - by fender90 - 04-29-2019, 12:04 AM
RE: Android 9 for Rock64? - by Blinky - 04-29-2019, 12:45 AM
RE: Android 9 for Rock64? - by fender90 - 04-29-2019, 02:11 AM
RE: Android 9 for Rock64? - by Blinky - 05-03-2019, 03:08 AM
RE: Android 9 for Rock64? - by Blinky - 05-09-2019, 09:11 PM
RE: Android 9 for Rock64? - by tllim - 05-12-2019, 02:43 PM
RE: Android 9 for Rock64? - by Blinky - 05-13-2019, 01:45 AM
RE: Android 9 for Rock64? - by dkryder - 05-13-2019, 10:11 PM
RE: Android 9 for Rock64? - by vincentroggero2 - 05-22-2019, 10:36 AM
RE: Android 9 for Rock64? - by fender90 - 06-09-2019, 04:29 AM
RE: Android 9 for Rock64? - by Blinky - 06-10-2019, 11:39 PM
RE: Android 9 for Rock64? - by Blinky - 06-12-2019, 12:27 AM
RE: Android 9 for Rock64? - by tllim - 06-13-2019, 09:48 PM
RE: Android 9 for Rock64? - by bigbertha - 06-17-2019, 10:26 AM
RE: Android 9 for Rock64? - by tllim - 06-18-2019, 11:37 PM
RE: Android 9 for Rock64? - by boro - 06-20-2019, 07:02 AM
RE: Android 9 for Rock64? - by Vanbesem - 06-25-2019, 12:39 AM
RE: Android 9 for Rock64? - by tllim - 07-08-2019, 06:37 PM
RE: Android 9 for Rock64? - by lumix14 - 08-29-2019, 08:24 PM
RE: Android 9 for Rock64? - by R_V - 09-12-2019, 05:07 PM
RE: Android 9 for Rock64? - by R_V - 09-15-2019, 05:39 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 4 6,389 05-09-2024, 02:49 PM
Last Post: Blackheat45
  Android Images (ROCK64) pineadmin 74 169,803 05-09-2024, 02:40 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,384 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,104 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,619 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,064 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,546 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,097 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,610 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,782 09-18-2020, 07:58 PM
Last Post: BowerR64
