RETRO-GAMING: ANNOUNCING BETA RELEASE OF RECALBOX FOR THE ROCKPRO64
#26
I don't have a 4:3 screen, but it seems to me like LibreRetro cores shouldn't be an issue at all. Perhaps only saving the config and overwriting the existing one may be a bit tricky ...
Engaging Integer scaler and setting the aspect ratio to custom you can easily set custom aspect ratio height and width. Here is an example of a custom 608x448 aspect ratio 2x (first image) and below 304x224 (1x).
[Image: EzppuTP.jpg]
Here is the 1x :
[Image: tsfCj49.jpg]
If you turn off the integer scaler the entire rendered image should 'stick' to the top-left of your display. From there you can set the Aspect ratio width and height so that it works for your monitor. You can then use X/Y Aspect ratio position settings to center the image... in example, below is a screenshot of a custom 820x720 aspect ratio centered by adjusting X pos to 230.
[Image: BQjGzMj.jpg]
Now, when you've got a setup that works well on your screen you'll want to save it (main menu -> configurations -> save new configuration). It will save to:
/recalbox/share/system/.config/retroarch/config/name_of_cfg.cfg
You want to use the values in this config to overwrite the default retroarch cfg that is used. After saving your .cfg, just follow these instructions from point 5 onward.
RE: RETRO-GAMING: ANNOUNCING BETA RELEASE OF RECALBOX FOR THE ROCKPRO64 - by Luke - 02-19-2019, 10:35 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 664 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 780 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,739 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,956 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 84,502 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 630 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 1,019 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,690 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,741 01-03-2023, 06:53 PM
Last Post: raph
  hello i want to drive an edp screen with my rockpro64 hannescam 0 797 10-20-2022, 01:22 PM
Last Post: hannescam
