RETRO-GAMING: ANNOUNCING BETA RELEASE OF RECALBOX FOR THE ROCKPRO64
#22
Removing the setting should just force the display to whatever the maximum detected resolution should be. And you're right, I'm sorry, I was thinking about the write-up in my latest release for the rock64, not the pro.
I'd encourage you to put video=HDMI-A-1:1280x1024@60 back in for your purposes. And you can try setting the aspect ratio inside the recalbox menu to see if it gets carried down to the libretro cores. You can also try different aspect ratio settings from inside a libretro core that's running by hitting the hotkey + X and then backing up the the settings->video section and cycling thru the different aspect ratios until you find one that's best for your needs.
RE: RETRO-GAMING: ANNOUNCING BETA RELEASE OF RECALBOX FOR THE ROCKPRO64 - by Mrfixit2001 - 02-14-2019, 11:02 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 658 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 780 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,737 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,942 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 84,486 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 630 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 1,019 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,686 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,740 01-03-2023, 06:53 PM
Last Post: raph
  hello i want to drive an edp screen with my rockpro64 hannescam 0 796 10-20-2022, 01:22 PM
Last Post: hannescam
