Armbian images available
#30
(10-31-2019, 12:40 AM)Wizzard Wrote:
(10-30-2019, 08:33 PM)tllim Wrote: Not surprise its work, when designs Pinebook Pro, we try to follow the Rockpro64 GPIO pin assignment and use back same peripheral chips as identical as possible :-)
I just expected that everything will work, when it is so identical Smile
First just drop in a PBP device tree into /boot. Then just edit extlinux with:
video=eDP-1:1920x1080@60
See if you get something on the screen. You will likely miss sound, bt/wifi, battery support, and a number other things but at least it will confirm that Armbian is bootable with a simple dtb swap.
Armbian images available - by Luke - 12-04-2018, 05:34 AM
RE: Armbian images available - by y0sh - 12-04-2018, 09:51 AM
RE: Armbian images available - by NightCrawler504 - 12-04-2018, 02:31 PM
RE: Armbian images available - by NightCrawler504 - 12-04-2018, 04:22 PM
RE: Armbian images available - by battlenut - 01-09-2019, 07:01 AM
RE: Armbian images available - by NightCrawler504 - 01-13-2019, 01:08 AM
RE: Armbian images available - by pineadmin - 12-05-2018, 10:39 PM
RE: Armbian images available - by amator_1 - 12-07-2018, 09:03 AM
RE: Armbian images available - by QLEMAC - 01-04-2019, 07:22 PM
RE: Armbian images available - by lestat70 - 01-19-2019, 09:48 AM
RE: Armbian images available - by NightCrawler504 - 02-12-2019, 12:24 AM
RE: Armbian images available - by Luke - 02-12-2019, 05:13 AM
RE: Armbian images available - by festor89 - 02-12-2019, 07:22 AM
RE: Armbian images available - by Luke - 02-12-2019, 07:46 AM
RE: Armbian images available - by pineadmin - 05-31-2019, 02:01 AM
RE: Armbian images available - by NightCrawler504 - 06-08-2019, 02:19 AM
RE: Armbian images available - by Luke - 06-08-2019, 07:12 AM
RE: Armbian images available - by NightCrawler504 - 06-09-2019, 12:17 AM
RE: Armbian images available - by NightCrawler504 - 06-13-2019, 10:30 PM
RE: Armbian images available - by Luke - 06-14-2019, 12:38 AM
RE: Armbian images available - by igorp - 07-07-2019, 03:49 AM
RE: Armbian images available - by pineadmin - 07-10-2019, 01:34 AM
RE: Armbian images available - by pineadmin - 08-05-2019, 01:19 AM
RE: Armbian images available - by Wizzard - 10-29-2019, 02:18 AM
RE: Armbian images available - by Luke - 10-29-2019, 02:51 AM
RE: Armbian images available - by Wizzard - 10-29-2019, 02:59 AM
RE: Armbian images available - by Luke - 10-29-2019, 07:36 AM
RE: Armbian images available - by tllim - 10-30-2019, 08:33 PM
RE: Armbian images available - by Wizzard - 10-31-2019, 12:40 AM
RE: Armbian images available - by Luke - 10-31-2019, 07:36 AM
RE: Armbian images available - by Wizzard - 10-31-2019, 12:33 PM
RE: Armbian images available - by Luke - 10-31-2019, 02:55 PM
RE: Armbian images available - by Wizzard - 10-31-2019, 03:00 PM
RE: Armbian images available - by Luke - 10-31-2019, 03:01 PM
Armbian images available - by Wizzard - 10-31-2019, 03:10 PM
RE: Armbian images available - by balbes150 - 12-13-2019, 08:09 AM
RE: Armbian images available - by martinayotte - 12-13-2019, 08:24 AM
RE: Armbian images available - by balbes150 - 12-14-2019, 02:24 AM
RE: Armbian images available - by martinayotte - 12-14-2019, 07:35 AM
RE: Armbian images available - by balbes150 - 12-14-2019, 08:55 AM
RE: Armbian images available - by NightCrawler504 - 01-01-2020, 02:28 PM
RE: Armbian images available - by dukla2000 - 01-02-2020, 04:44 AM
RE: Armbian images available - by NightCrawler504 - 08-25-2020, 03:42 PM
RE: Armbian images available - by Wizzard - 09-17-2020, 04:49 AM
RE: Armbian images available - by NightCrawler504 - 12-28-2020, 04:14 AM
RE: Armbian images available - by NightCrawler504 - 02-08-2021, 10:34 PM
RE: Armbian images available - by bg002h - 03-23-2021, 06:02 PM
RE: Armbian images available - by TRS-80 - 03-23-2021, 09:45 PM
RE: Armbian images available - by bg002h - 03-24-2021, 04:44 PM
RE: Armbian images available - by bg002h - 03-25-2021, 02:12 PM
RE: Armbian images available - by bg002h - 03-25-2021, 10:41 PM
RE: Armbian images available - by MisterA - 04-22-2021, 09:58 AM
RE: Armbian images available - by Wizzard - 04-26-2021, 03:16 AM
RE: Armbian images available - by NightCrawler504 - 09-18-2021, 02:35 PM
RE: Armbian images available - by LMM - 09-19-2021, 01:50 AM
RE: Armbian images available - by TRS-80 - 09-28-2021, 02:46 PM
RE: Armbian images available - by bas-r - 04-19-2022, 02:28 AM
RE: Armbian images available - by NightCrawler504 - 04-22-2022, 12:26 AM
RE: Armbian images available - by TRS-80 - 04-30-2022, 03:43 PM
RE: Armbian images available - by NightCrawler504 - 08-03-2022, 05:13 PM
RE: Armbian images available - by Rocklobster - 08-04-2022, 06:56 AM
  Expose /dev/mali0 in armbian pedromiguel.sanchez 2 2,029 07-25-2022, 04:52 AM
Last Post: pedromiguel.sanchez
  Enable DSI/TD Ports on Armbian (jammy) dkebler 0 954 06-16-2022, 06:56 PM
Last Post: dkebler
  Armbian Jammy-Running fairly stable Rocklobster 0 1,191 05-04-2022, 01:00 PM
Last Post: Rocklobster
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 91 89,289 04-03-2022, 01:44 PM
Last Post: davidlsbc
  Armbian is looking for maintainer for ROCKPro64 TRS-80 20 14,416 03-19-2022, 09:32 PM
Last Post: paralin1
  Armbian 22.02 Release Announcement TRS-80 0 1,170 02-28-2022, 05:08 PM
Last Post: TRS-80
  OpenMediaVault: link from wiki or Armbian? Goffi 0 1,181 02-10-2022, 03:57 AM
Last Post: Goffi
Bug Unreliable display in Armbian and Debian ksattic 3 3,187 11-17-2021, 05:42 AM
Last Post: PakoSt
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 1,899 10-29-2021, 11:15 AM
Last Post: TRS-80
  RockPro64 EDP in Armbian hannescam 2 2,554 10-15-2021, 09:07 AM
Last Post: hannescam
