pinebook 14" sd card slot stopped working
it could possibly be, an outside chance, that the metal tabs of the sd card slot are not making good enough contact with the card itself. the solution that once helped me on a different device was to use fine long tweezers to gently lift up each tab just a very little bit and then try it and repeat a few times until that possibility either works or not. not sure if you can get clear shot at the tabs on the pinebook or not but be very careful in any mod.
RE: pinebook 14" sd card slot stopped working - by dkryder - 12-03-2018, 01:51 PM
  pinebook 1080p power/barrel connector/cable cel 0 560 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,394 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,250 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,666 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,388 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,646 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 3,021 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,648 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,963 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,697 08-20-2020, 08:18 AM
Last Post: Reinoud
