Extremely low write speed on GB ethernet
apparently it was not a problem with the connection, but with the drives that are connected.
when under load, the usb connection the the drives that are connected to the hub crashes.
https://pastebin.com/JGM3xKDz
the hub is a-4 port powered hub by Anker, and two powered sumsung disks are connected to it
hub's lsusb - https://pastebin.com/MiAMh9K5
I'm running 4.4.154-1122-rockchip-ayufan-g7859b9b904a9
with OMV installed
i'v tried the following advice https://bbs.archlinux.org/viewtopic.php?id=183190 on comment #12, which helped a little, the drives became more stable, but disconnected after all.
RE: Extremely low write speed on GB ethernet - by omer811 - 10-24-2018, 10:31 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 691 08-14-2023, 07:55 AM
Last Post: kundanjha
  No USB and Ethernet kreyren 3 2,445 08-18-2022, 10:35 AM
Last Post: kreyren
  RockPro64 ddr clock speed causing system instability CypherShrugged 1 1,622 08-15-2022, 02:32 PM
Last Post: CypherShrugged
  speed and stability tests luckyrockpro 0 1,692 05-29-2019, 08:15 AM
Last Post: luckyrockpro
  OMV Samba speed tweak? g_t_j 0 2,147 05-11-2019, 11:12 AM
Last Post: g_t_j
Sad RockPro64 with OpenMediaVault - Ethernet card is not recognized eduapof 8 12,075 04-18-2019, 08:28 AM
Last Post: g_t_j
  SD Card UHS speed hopkinskong 5 6,647 12-06-2018, 05:52 PM
Last Post: z4v4l
  Not able to write u-boot to SPI Jix0 2 5,125 11-13-2018, 09:39 AM
Last Post: Bullet64
  u-boot serial port speed? zener 2 4,014 10-06-2018, 12:47 PM
Last Post: zener
  rock64pro - using gigabit ethernet dongle on usb type C dkebler 2 3,291 09-07-2018, 12:41 AM
Last Post: steamiestoyster
