u-boot serial port speed?
I recently got a RockPro64 and I'm assuming it's using u-boot. I have a USB serial port adapter attached to my board and I can log in at 115200.
However, when I power cycle the board I see that it's outputting something with different serial port parameters. What are the serial port settings to be able to interact with u-boot? And what is the command sequence to get into the u-boot command line?
Thanks!
(10-06-2018, 08:26 AM)zener Wrote: I recently got a RockPro64 and I'm assuming it's using u-boot. I have a USB serial port adapter attached to my board and I can log in at 115200.
Thanks!
  • Baudrate: 1500000
  • Data bits: 8
  • Parity: N
  • Stop bits: 1
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Wow, I tried 115200 and down to 9600. 1500000 works great. Thanks!
  enble boot after power loss/restore dkebler 18 9,257 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 118,623 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 653 09-08-2023, 08:14 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 669 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,197 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,251 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,526 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,070 09-05-2022, 04:23 PM
Last Post: ljones
  RockPro64 ddr clock speed causing system instability CypherShrugged 1 1,584 08-15-2022, 02:32 PM
Last Post: CypherShrugged
  U-BOOT Tutorial hazz 0 1,137 07-19-2022, 10:48 PM
Last Post: hazz
