Flashing android to eMMC from linux sd card boot
This is a method that worked to install android 8.1 onto emmc without using the emmc to SD card adaptor.
It also worked when using the Android tools did not.
Someone else may find this useful
=== Flashing Android to eMMC from Linux SD Boot (ROCKPro64)===
This method enables installing android to emmc using dd method without an emmc adaptor.
Can also be an alternate method if other methods are unsuccesful
Install Linux to an SD Card (Verified with bionic but may work with others).
Insert SD and empty eMMc (eMMc card must be empty so that ROCKPro64 boots off SD card).
(If necessary, emmc can be cleared using android tools linked below)
Boot Linux
Download desired dd android image from pine64 using curl (curl http://link_to_rockpro64_image.img.xz --output AndroidImage.img.xz)
Extract android image using unxz (unxz AndroidImage.img.xz)
Verify that emmc is visible by typing sudo fdisk -l | less.
eMMc should be shown as /dev/mmcblk1 with the correct size
Write android image to emmc using dd (sudo dd if=./AndroidImage.img od=/dev/mmcblk1)
Wait for dd to finish. (if screen turns off give it another 10 minutes and assume its done).
Unplug power, remove sd card.
Plug power back in and enjoy android.
Thanks to lucasz for helping out.
Flashing android to eMMC from linux sd card boot - by nlem - 10-05-2018, 07:24 AM
  Android images for RockPro64 BitAnnihilator 1 159 04-17-2024, 07:50 AM
  Difficulty installing Android on Rockpro64 spammycheese 0 2,821 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 2,657 06-04-2022, 12:18 AM
Last Post: grobbs
  Android TV miguelangelaj 2 3,081 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,512 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 11,257 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 2,734 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 25,065 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 14,183 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 4,061 04-16-2021, 02:03 AM
Last Post: Wizzard
