EMMC not booting while SD does.
Hello all,
I recently ordered a rockpro64 with a few accessories, one of which is an emmc module (https://ameridroid.com/collections/stora...dule-blank).
However, I am unable to get the rockpro64 to boot with just the emmc module plugged in. I used the usb->emmc adapter to dd the Debian stretch image (version 0.7.9) to it. When it wouldn't boot with that image, I tried an SD card and that worked perfectly. Not only that, but the emmc is visible in /dev/ when booted off the SD so the SBC does recognize the emmc....it just won't boot from it.
After that, I tried a plethora of things to try to get emmc to boot:
1. dd the image to the emmc while booted off the SD with the emmc plugged in to the rockpro64.
2. dd the android emmc image to the emmc.
3. Changed every combination of mmc boot partition enable/disable/ack along with the various boot bus options.
4. Plugged in a serial adapter to view the boot process. The attempted emmc boot showed nothing on serial while the SD boot showed the whole process as expected.
A few things to note:
1. Before flashing anything to the emmc, I noticed it was already loaded with an odroid XU3  image, despite the emmc module I ordered stating it's supposed to be empty. Could this be a problem? I know the Odroids use the boot0 boot partition and I guess rockchip doesnt, so I enabled rw on the boot parts and zero'd them out.
2. The Linux mmc tool and dmesg showes the emmc module as hs200 as opposed to the hs400 that the ameridroid site says. The mmc version is 5.1 as confirmed by the linux mmc tool.
3. The linux kernel reports the emmc model number as DG4032 if that helps.
Any help would be appreciated. Thanks.
EMMC not booting while SD does. - by Apokalypz - 08-08-2018, 02:27 AM
RE: EMMC not booting while SD does. - by wittend - 09-06-2018, 09:34 AM
RE: EMMC not booting while SD does. - by _fs - 09-15-2018, 04:22 PM
RE: EMMC not booting while SD does. - by _fs - 09-15-2018, 05:23 PM
RE: EMMC not booting while SD does. - by jnoxon - 09-25-2018, 08:38 PM
RE: EMMC not booting while SD does. - by mocara - 09-26-2018, 12:23 AM
RE: EMMC not booting while SD does. - by jarcik - 10-13-2018, 03:23 AM
RE: EMMC not booting while SD does. - by jarcik - 10-14-2018, 12:52 PM
RE: EMMC not booting while SD does. - by e3k - 03-04-2019, 05:53 AM
RE: EMMC not booting while SD does. - by jnoxon - 09-28-2018, 05:02 PM
RE: EMMC not booting while SD does. - by jarcik - 10-13-2018, 02:56 AM
RE: EMMC not booting while SD does. - by Bullet64 - 03-04-2019, 07:15 AM
RE: EMMC not booting while SD does. - by graham-r - 03-10-2019, 04:12 AM
  Can i use this Emmc for Rockpro 64 Supratec 2 683 12-20-2023, 09:12 AM
  eMMC modules ajtravis 3 2,405 10-12-2022, 01:44 PM
Last Post: ajtravis
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,831 07-02-2022, 09:24 AM
Last Post: dkebler
  Booting my RockPro64 from NVMe drive PsySc0rpi0n 4 5,810 05-11-2022, 02:35 PM
Last Post: PsySc0rpi0n
  Flash to eMMC? Barugon 4 2,836 04-27-2022, 03:10 PM
Last Post: Barugon
  Sata HD stopped booting db579 2 2,204 03-11-2022, 03:34 PM
Last Post: db579
  rockpro64 emmc GreyLinux 8 6,877 11-08-2021, 01:56 PM
Last Post: GreyLinux
  eMMC 128gb flailingeffort 1 2,603 01-18-2021, 04:42 AM
Last Post: Wizzard
Exclamation need help booting off USB 3.0 HDD/SSD idontgetit 1 3,189 10-29-2020, 04:50 AM
Last Post: t4_4t
  Rockpro64 with PCI FC Card - Not booting (Sometimes) MSteam 1 2,952 10-25-2020, 07:42 PM
Last Post: MSteam
