Stock Android Oreo 8.1 release
#24
(07-10-2018, 01:41 PM)Poincare Wrote:
(06-25-2018, 07:25 PM)xecutioner Wrote:
(06-25-2018, 01:48 PM)Luke Wrote: Just a heads-up, looks like the eMMC boot image is iffy on some boards. In other words, it may not work 100%. SD boot works fine however.
I have burned the EMMC version several times using the PINE64 Software Installer. In each case, the Rock64 will not boot. The small lights come on and it appears that the board is active, however, there is no output from the HDMI. I have repeated this 10 times now; in each case the MD5SUM matches the download and there is no problem with PINE64 Software Installer flashing the EMMC.  In all cases, I have left the board to boot for up to 60 minutes without output. It is not functioning.
EDIT:  By using Etcher and not the pINE64 Software Installer, I was able to successfully flash the EMMC and the Rock64 boots into Android 8.1.  However, the system image only has 8gb, with about 3GB free.  I have a 32GB EMMC card and want to expand the filesystem to use the full EMMC.  There are no tools in the supplied Android image nor can I find any available to expanding Android 8.1 to full EMMC capacity.
Anyone know how to expand the Android 8.1 partition from the stock EMMC image to full EMMC capacity?
I would like to know the answer to this as well..
Stock Android Oreo 8.1 release - by tllim - 06-24-2018, 04:47 PM
RE: Stock Android Oreo 8.1 release - by Blinky - 06-25-2018, 03:56 AM
RE: Stock Android Oreo 8.1 release - by tllim - 06-26-2018, 12:46 PM
RE: Stock Android Oreo 8.1 release - by Luke - 06-25-2018, 01:48 PM
RE: Stock Android Oreo 8.1 release - by Poincare - 07-10-2018, 01:41 PM
RE: Stock Android Oreo 8.1 release - by xecutioner - 07-12-2018, 06:42 PM
RE: Stock Android Oreo 8.1 release - by burram - 08-31-2018, 05:53 AM
RE: Stock Android Oreo 8.1 release - by Luke - 08-31-2018, 09:05 AM
RE: Stock Android Oreo 8.1 release - by roberthr - 06-26-2018, 01:07 AM
RE: Stock Android Oreo 8.1 release - by joe - 06-26-2018, 07:47 AM
RE: Stock Android Oreo 8.1 release - by roberthr - 06-26-2018, 08:38 AM
RE: Stock Android Oreo 8.1 release - by Luke - 06-26-2018, 11:02 AM
RE: Stock Android Oreo 8.1 release - by dkryder - 06-27-2018, 10:34 AM
RE: Stock Android Oreo 8.1 release - by allikdeew - 06-27-2018, 10:43 AM
RE: Stock Android Oreo 8.1 release - by geno - 06-28-2018, 01:25 AM
RE: Stock Android Oreo 8.1 release - by clobeca - 08-06-2018, 09:26 PM
RE: Stock Android Oreo 8.1 release - by Willem53 - 06-27-2018, 12:07 PM
RE: Stock Android Oreo 8.1 release - by joe - 06-29-2018, 07:30 PM
RE: Stock Android Oreo 8.1 release - by thead - 06-29-2018, 04:52 PM
RE: Stock Android Oreo 8.1 release - by geno - 07-01-2018, 04:43 AM
RE: Stock Android Oreo 8.1 release - by dhruan - 07-04-2018, 12:50 AM
RE: Stock Android Oreo 8.1 release - by fire219 - 07-04-2018, 09:10 AM
RE: Stock Android Oreo 8.1 release - by ycllwl - 07-07-2018, 08:30 PM
RE: Stock Android Oreo 8.1 release - by dhruan - 07-10-2018, 08:22 PM
RE: Stock Android Oreo 8.1 release - by kostaman - 07-13-2018, 01:34 AM
RE: Stock Android Oreo 8.1 release - by dhruan - 07-17-2018, 07:55 PM
RE: Stock Android Oreo 8.1 release - by pfeerick - 07-13-2018, 07:30 AM
RE: Stock Android Oreo 8.1 release - by kostaman - 07-18-2018, 03:46 AM
RE: Stock Android Oreo 8.1 release - by kostaman - 07-27-2018, 01:06 AM
Not stable on 4gb board. - by dougunder - 08-02-2018, 11:52 AM
RE: Stock Android Oreo 8.1 release - by kostaman - 08-03-2018, 12:36 AM
RE: Stock Android Oreo 8.1 release - by dougunder - 11-21-2018, 10:18 AM
RE: Stock Android Oreo 8.1 release - by gorba77 - 08-06-2018, 11:11 PM
RE: Stock Android Oreo 8.1 release - by AlexS - 08-12-2018, 06:31 AM
RE: Stock Android Oreo 8.1 release - by AlexS - 10-11-2018, 05:04 AM
RE: Stock Android Oreo 8.1 release - by tllim - 10-12-2018, 03:17 PM
RE: Stock Android Oreo 8.1 release - by lumix14 - 11-25-2018, 09:31 AM
RE: Stock Android Oreo 8.1 release - by AlexS - 10-29-2018, 02:46 AM
RE: Stock Android Oreo 8.1 release - by elik745i - 10-30-2018, 10:51 AM
RE: Stock Android Oreo 8.1 release - by fender90 - 11-21-2018, 05:38 AM
RE: Stock Android Oreo 8.1 release - by lumix14 - 11-25-2018, 09:34 AM
RE: Stock Android Oreo 8.1 release - by Trispy - 08-27-2019, 09:34 PM
RE: Stock Android Oreo 8.1 release - by Pepe - 04-11-2020, 04:43 PM
  Android Images (ROCK64) pineadmin 76 170,079 05-13-2024, 04:13 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 6,460 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,427 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,143 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,653 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,092 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,568 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,135 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,635 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,812 09-18-2020, 07:58 PM
Last Post: BowerR64
