Considering buying and question on the PCIe slot
I also did not have much success testing out different PCIe cards.
I tested three different SATA cards, none of them work.
One card (http://www.sybausa.com/index.php?route=p...uct_id=722) needs a couple of resets before it is seen by doing lspci. I notice this as wel during boot: most of the time the card's leds fade out during boot, I then reset the board and after a few tries the leds stay on and I can see some general information using lspci. In this case however the card still doesn't work.
I'm not sure if this also a powerconsumption problem. Anyone have a link to a good powered pcie riser?
All in all: don't expect the pcie slot to just work when buying this board. At least that's my experience...
RE: Considering buying and question on the PCIe slot - by MisterA - 10-10-2018, 03:16 AM
Question Another Fan Question backwoodstech2 1 444 02-03-2024, 04:09 PM
Last Post: backwoodstech2
Information Question regarding odd startup behaviour Mff 0 1,215 12-03-2022, 03:18 PM
Last Post: Mff
  PCIE interface power on too late Slark Xiao 0 1,048 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  PCIe gen1 timeout - how to debug tosi 3 4,679 03-10-2022, 05:06 PM
Last Post: db579
  Anyone try an NVIDIA GPU in the PCIe slot? Paraplegic Racehorse 0 1,767 04-15-2021, 11:46 AM
Last Post: Paraplegic Racehorse
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,802 02-11-2021, 10:18 AM
Last Post: LMM
  PCIe Armbian and Ayufan for nvme ssd LMM 1 2,731 02-03-2021, 04:38 PM
Last Post: LMM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,813 10-20-2020, 10:52 AM
Last Post: GreyLinux
  PCIe x4 mode - Lane 3 failure acdkyn 1 2,831 04-24-2020, 01:32 PM
Last Post: kuleszdl
  micro SD Card Slot Spring not working, Cant boot mjembd 1 3,174 04-16-2020, 12:30 AM
Last Post: mjembd
