Question regarding odd startup behaviour
Information
I've got a question regarding a cool RockPro64 4GB board I recently acquired (the previous owner ran it once, concluded it was too much hassle compared to a RPI4 and sent it to me. It worked fine at his place before sending it to me);
When powered the only thing it does, regardless of peripherals connected or storage present, is flash the white LED and one of the ethernet LEDs continuously at something around 2-3Hz. I tried many things; different microSD cards, different card readers, different distros. I also tried disabling the SPI flash by grounding the clock pin; also results in the same behavior. When powered during this behavior the 5V GPOI pin is a steady 5V but the 3.3V seems to be "flashing" together with the LEDs as well.
Finally I tried hooking up the UART2 slot to a usb->UART adapter in order to maybe get something out of the board in that way. Nothing was showing on the UART output, but when I looked back at the RockPro64 suddenly the LED flashing pattern had changed. The board was booting up!
It turns out that I can reliably and  turn on the board (from a powered but "blink-looping") state by connecting the UART pins to a powered UART USB controller, but nothing else! (rebooting always seems to work fine, so only starting from a turned off state is problematic) Connecting either of the UART pins (8 or 10) to ground or the 3.3V volt supply doesn't start it either.
I updated the firmware via the armbian-config menu, but that doesn't seem to make a difference.
Does anyone have any idea what might be causing this behavior? Is some kind of memory corrupted perhaps? perhaps a somewhat faulty 3.3V circuit? a short? Visually the board seems fine.
Any help in diagnosing this odd behaviour is welcome! Thanks in advance
Question Another Fan Question backwoodstech2 1 345 02-03-2024, 04:09 PM
Last Post: backwoodstech2
  Considering buying and question on the PCIe slot MobileJAD 25 42,813 11-07-2019, 03:10 PM
Last Post: hmuller
  RK3399 question enip 6 7,651 07-20-2019, 05:00 AM
Last Post: stuartiannaylor
  Basic question on the Nas case of the rockPro Slam 1 3,227 01-23-2019, 08:04 AM
Last Post: Slam
  Performance issue/question bobdaroze 8 11,304 11-11-2018, 10:41 PM
Last Post: tuxd3v
  Rock64 OMV video question / same for RockPro64 I would assume RockPro64Newbie 0 16,587 08-19-2018, 04:11 AM
Last Post: RockPro64Newbie
  Dual SATA-II Interface Card question and NAS question RockPro64Newbie 5 5,908 08-17-2018, 10:58 PM
  Power Supply ordering question frewind 8 10,308 08-03-2018, 11:15 AM
Last Post: dkryder
