Rock64 suitable for headless TVHeadend install?
(06-26-2018, 06:52 AM)elsmandino Wrote: Thanks very much for that, Luke.
I am really tempted to look into one of these devices as a complete swap for the NAS.
What, do you think, would be the best way to attach multiple hard drive to the Rock64.
Also, is there anyway I could attach an SSD to host the operating system?
You could boot from an SSD by flashing uboot to SPI on the board. Its simple to do. Other drives would have to be attached to the USB 2.0 ports which would obviously result in (relatively) slow performance, as you'd be limited by the USB 2.0 BUS. And these HDDs would have to be attached using a powered case OR a via a powered USB 2.0 hub as USB 2.0 cannot deliver enough power to drive HDDs.
Others have used USB 3.0 hubs to drive multiple drives at faster speeds but having multiple drives attached to one USB 3.0 can cause issues.
Personally I'd advise you get the RockPro64 if you want a NAS with multiple HDDs (the board has PCIe as well as USB 3.0 and C). And tehre will even be a NAS case for it - take a look in the RockPro64 subforum.
RE: Rock64 suitable for headless TVHeadend install? - by Luke - 06-26-2018, 11:37 AM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 686 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  PBP Debian 11 GRUB install error zlth 2 1,956 11-18-2022, 07:42 AM
Last Post: zlth
  MRAA Rock64 support jbize 2 2,580 07-09-2022, 04:40 AM
Last Post: igorp
  wrong launguage install chadace 1 4,055 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 6,478 03-18-2020, 09:42 AM
  Rock64 with Debian netinst usb Bloris 6 9,135 12-03-2019, 12:37 PM
Last Post: madalin
  The differences between Rock64 and RockPro64 phamoanh 1 4,403 06-12-2019, 10:44 PM
Last Post: evilbunny
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,514 05-15-2019, 02:55 PM
Last Post: Thatoo
  Custom Kernel for ROCK64 mayst 2 5,062 01-07-2019, 08:04 AM
Last Post: mayst
Bug Rock64 Login lpninja 1 4,472 10-04-2018, 12:02 AM
