mpph264enc output doesn't work on bionic
I guess that won't help, but I tried your commands with an OrangePi RK3399, and it seemed to work.
I suppose it is working with 32 bits, not 64...
$ sudo gst-launch-1.0 -e videotestsrc is-live=false num-buffers=500 \
> ! video/x-raw,format=NV12,width=1280,height=720 \
> ! mpph264enc ! filesink location=1280.h264
(gst-plugin-scanner:741): GLib-GObject-WARNING **: 09:29:09.504: cannot register existing type 'GstKMSSink'
(gst-plugin-scanner:741): GLib-GObject-CRITICAL **: 09:29:09.504: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(gst-plugin-scanner:741): GLib-CRITICAL **: 09:29:09.504: g_once_init_leave: assertion 'result != 0' failed
(gst-plugin-scanner:741): GStreamer-CRITICAL **: 09:29:09.504: gst_element_register: assertion 'g_type_is_a (type, GST_TYPE_ELEMENT)' failed
Setting pipeline to PAUSED ...
mpi: mpp version: b212d1b author: Jacob Chen [mpp]: fix mjpeg buffer leak
Pipeline is PREROLLING ...
h264e_api: h264e_config MPP_ENC_SET_RC_CFG bps 3456000 [3240000 : 3672000]
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:14.428808048
Setting pipeline to READY ...
Setting pipeline to NULL ...
mpp_thread: MPP_THREAD_STOPPING status set mThread 0xab2a1c30
Freeing pipeline ...
linaro@captation-techforum-rk3399-4GB:~$ ffprobe -hide_banner 1280.h264
Input #0, h264, from '1280.h264':
 Duration: N/A, bitrate: N/A
   Stream #0:0: Video: h264 (High), yuv420p(progressive), 1280x720, 30 fps, 30 tbr, 1200k tbn, 60 tbc
RE: mpph264enc output doesn't work on bionic - by gounthar - 11-15-2019, 10:00 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,388 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  HDMI doesn't work on rock64 Noung1991 1 636 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,826 06-30-2022, 06:28 PM
Last Post: rookie_267
  armbian / bionic - hdmi to vga not functioning on newer5.4 kapqa 1 3,048 03-31-2020, 07:19 PM
Sad HDMI doesn't work on rock64 rock7 0 2,805 12-16-2019, 01:04 PM
Last Post: rock7
  Owncloud installation on Ubuntu Bionic Count Omega 9 11,049 07-19-2019, 03:54 AM
Last Post: stuartiannaylor
  HDMI output with Arch Linux Arm yogo1212 2 4,713 07-17-2019, 02:46 AM
Last Post: yogo1212
  Screen lock fail Bionic-lxde-rock64-0.7.8-1061-arm64 electrique 0 2,123 12-28-2018, 11:00 PM
Last Post: electrique
  bionic lxde 0.6.xx was not getting audio/sound jose_s_c 2 4,166 11-13-2018, 11:18 AM
Last Post: UnicornFarts
  Arch Linux minimal image w/ full HDMI output support hiccupstix 1 3,663 11-01-2018, 08:33 AM
Last Post: danboid
