bionic lxde 0.6.xx was not getting audio/sound
I had no audio/sound with bionic-lxde images, I tried pre-release 0.6.55 so went to release 0.6.44 but had same problem. I tried google but not find answer, so google more to learn about ALSA and pulseaudio, seems problem with pulseaudio default sink, and I created following file and now can get audio.
If you get no audio, give this a try.
rock64@rock64:~$ cat ~/.config/pulse/default.pa
.include /etc/pulse/default.pa
set-default-sink alsa_output.platform-hdmi-sound.stereo-fallback
rock64@rock64:~$
Good advice. In the modern day, the majority of sound problems I've had under Linux (and not just on the Rock64) have been due to PulseAudio being used rather than ALSA. It'll be nice when pulse can finally die out. Smile
(06-20-2018, 12:25 AM)jose_s_c Wrote: I had no audio/sound with bionic-lxde images, I tried pre-release 0.6.55 so went to release 0.6.44 but had same problem. I tried google but not find answer, so google more to learn about ALSA and pulseaudio, seems problem with pulseaudio default sink, and I created following file and now can get audio.
rock64@rock64:~$
Thank you Jose! I wasn't getting audio in Ubuntu bionic lxde either through HDMI or the 3.5 jack. modifying /etc/pulse/default.pa to add that set-default-sink line at the end solved my problem!
  Rock64 v2 - did not work song / audio sqw200zu 2 1,366 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  mainline kernel sound support Openwrt lucize 2 4,072 05-01-2020, 05:09 PM
Last Post: PakoSt
  armbian / bionic - hdmi to vga not functioning on newer5.4 kapqa 1 3,040 03-31-2020, 07:19 PM
  Ayufan LXDE with Teamviewer or Dwservice? cenicero 0 1,992 03-14-2020, 06:39 AM
Last Post: cenicero
Bug mpph264enc output doesn't work on bionic rompelstompel 11 16,752 11-15-2019, 10:00 AM
Last Post: gounthar
  Release 0.9.14 Ubuntu Mate desktop, LXDE, OMV, Docker CE (container) Luke 1 4,084 09-19-2019, 07:00 AM
Last Post: Malmgren
  Owncloud installation on Ubuntu Bionic Count Omega 9 10,988 07-19-2019, 03:54 AM
Last Post: stuartiannaylor
  Sound on 3.5mm LXDE georgetina1 1 2,483 01-21-2019, 09:37 AM
Last Post: pas059
  Screen lock fail Bionic-lxde-rock64-0.7.8-1061-arm64 electrique 0 2,120 12-28-2018, 11:00 PM
Last Post: electrique
  HDMI sound on ayufan 0.7.x Trash_Can_Man 0 2,222 10-26-2018, 12:57 PM
Last Post: Trash_Can_Man
