Stuck on the boot screen...
Quote:Remix OS currently has boot up issue in Pine A64 2GB board due to Ethernet DMA memory panic issue and they are fixing it. The issuer should be role out soon.
OK, thanks for that info, I tried "arch-pine64-bspkernel-20160304-1-xfce4" and that seemed to work OK. Although I have not plugged the WiFi module on yet, does arch support the WiFi module? (forgot to say I do have the 2GB version).
Quote:There are other users having issues with pink/green hues on their screen, and it was fixed by changing their color setting from RGB to YPbPr, which was for fixing the pink hue. For the green hue, i would just go into your monitor/TV settings and play around with the color settings. Let me know if your green tint issue is fixed by this method.
Yep, thanks, that fixed it, as you said, all I did was change the monitor setting from "RGB" to "YPbPr".
I also had to adjust a zoom setting in the monitor from 20% to 0%. I think this is because I have a Dell E248WFP with a native resolution of 1920x1200, and the Pine is outputting 1920x1080, is there a way of forcing the resolution up to 1920x1200?
Stuck on the boot screen... - by PainOfPine - 04-06-2016, 02:39 PM
RE: Stuck on the boot screen... - by tllim - 04-06-2016, 04:14 PM
RE: Stuck on the boot screen... - by piahoo - 04-27-2016, 08:44 PM
RE: Stuck on the boot screen... - by pine.tree - 04-28-2016, 09:18 AM
RE: Stuck on the boot screen... - by pine.tree - 04-07-2016, 06:31 AM
RE: Stuck on the boot screen... - by PainOfPine - 04-07-2016, 11:26 AM
RE: Stuck on the boot screen... - by PainOfPine - 04-08-2016, 01:59 PM
RE: Stuck on the boot screen... - by xrez - 04-28-2016, 10:50 AM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 146 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  stuck to sleep mode pinecil v2 lilibit 3 1,151 12-11-2023, 04:18 PM
Last Post: lilibit
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,212 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,649 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,592 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,718 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,136 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,268 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,171 10-18-2020, 01:41 PM
Last Post: toiny
  SD Card boot - trying out OS Baconomics 1 4,409 06-19-2020, 06:58 AM
