Raspberry Foundation Scren
I would suspect not at this point. Once the pine64's have been shipping for awhile, perhaps people will start porting other displays. But it still early yet, and you should not expect compatibility. Maybe they are compatible, maybe not. I believe both use a DSI cable to connect the screen, but the pinouts might be different.
Note, on the pine64 the touch screen connects to the board using an i2c cable separate from the display, while the Raspberry Pi display provides the touch screen interface through the DSI cable, so even if the displays work, it is likely the touch screen does not work.
At this moment, the only display that I would expect to work on both is an HDMI display with a touch screen controller that acts like a standard USB mouse. That way you are using two standard cables (HDMI and USB). Something like this: http://www.aliexpress.com/item/7inch-HDM...37013.html
Raspberry Foundation Scren - by famazzo - 04-04-2016, 09:05 PM
RE: Raspberry Foundation Scren - by MichaelMeissner - 04-04-2016, 09:37 PM
  Raspberry Pi-Top Mark Smith 3 6,265 10-17-2016, 02:49 PM
Last Post: LeroyahJenkins
  Raspberry Pi and Arduino accessories compatible? Krowyn 6 10,755 10-08-2016, 10:36 AM
Last Post: rohan
  Will the Raspberry Pi 2 camera work nath16 2 4,595 05-29-2016, 07:29 AM
Last Post: nath16
