Rock64+android usb3.0 does not work
(12-26-2017, 03:42 PM)elultimocarajote Wrote:
(12-18-2017, 12:45 AM)tllim Wrote:
(12-15-2017, 06:32 AM)elultimocarajote Wrote: Rock64+android
Usb3.0 does not work
Usb 2.0 working.
Somebody can help me?
Why USB 3.0 doesn't work?
I have using the USB 3/0 HDD and pendrive everyday and works well.
What type of USB 3.0 drive that you plan to attached? Please make sure that your device doesn't draw more than 900mA current.
The problem appears when i switch  usb2.0 (bluetooth keyboard) and usb3.0 hdd.
When i connect both in usb2.0 everything works fine.
thanks
I have this issue as well. Earlier I had posted that I was having issues with my Rock64 4Gb board being very sluggish in Lakka and Android. It is my USB 3 port causing it, but mainly in conjunction with USB 2. If I only use USB 3 with my 4-port hub and plug everything into that, it all works perfectly. Things run very smoothly. But as soon as I plug in a USB 2 device (controller, flash drive, etc...) my Rock64 board gets extremely slow and laggy.
Likewise, if I plug in my USB 2 4-port hub and plug everything into that (including anything USB 3) my Rock64 runs very smooth. As soon as I plug in a USB 3 device in the USB 3 port, it gets very laggy.
So, like this:
USB2 in correct port: works
USB3 in correct port: works
USB2 in USB3 port: works
USB3 in USB2 port: works
USB2 in correct port + USB3 in correct port: lags system badly
USB3 in USB2 port + USB2 in USB3 port: works (Because all ports act as USB2 now)
I genuinely don't know what's going on here. It happens only in Android and in Lakka, but these are the only operating systems I've tried. I don't remember having this issue on previous builds (non-rooted) of Android, but I also haven't gotten around to trying an older build yet.
Build info:
Rock64 4GB board w/heatsinks and fan
Rock64 PSU from Pine64
Android on 32Gb eMMC
Lakka on SD
Physical switch for dual-boot purposes (saves having to remove the jumper!)
Modified Raspberry Pi 3 case w/fan
Things I've tried to troubleshoot:
Single booting each OS
Removing the USB hubs from the picture
Several different USB2/3 cables and devices
Removing the fan from the GPIO power pins
Things I intend to try and will update later:
An older build of Android
A different Linux based OS from Lakka
RE: Rock64+android usb3.0 does not work - by dudemo - 12-31-2017, 08:41 AM
RE: Rock64+android usb3.0 does not work - by k8Va - 03-30-2018, 04:26 AM
  Android Images (ROCK64) pineadmin 76 169,974 05-13-2024, 04:13 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 6,435 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,414 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,126 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,634 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,081 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,558 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,116 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,623 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,797 09-18-2020, 07:58 PM
Last Post: BowerR64
