Linux Mainline
#50
Two LEDs (white: Power, red: Stanby) on rock64-board are not displayed correctly.
Do you recognize that?
Concrete state is:
In kernel-4.4.103 both of them are always off, and
in kernel-4.15.0 both are always on.
When confirming Commits, the LED display has been changed several times.
And the contents of the last Commits are as follows.
Looking at this, I think that the above state is different from the expected behavior.
Finally,
The kernel-4.15.0 @ 0.6.13 setting is "heartbeat" & "mmc 0".
And this version will work correctly, I add this and report it.
ayufan: rock64: use disk-activity as trigger
Change-Id: I1467219088d94df1f874319afd8bf286c64ed6a7 standby-led {
standby-led {
- linux,default-trigger = "heartbeat";
- gpios = <&rk805 1 GPIO_ACTIVE_LOW>;
+ linux,default-trigger = "disk-activity";
+ gpios = <&rk805 0 GPIO_ACTIVE_LOW>;
default-state = "on";
power-led {
- linux,default-trigger = "mmc0";
- gpios = <&rk805 0 GPIO_ACTIVE_LOW>;
+ gpios = <&rk805 1 GPIO_ACTIVE_LOW>;
Linux Mainline - by ayufan - 08-28-2017, 04:00 PM
RE: Linux Mainline - by jl_678 - 08-28-2017, 07:07 PM
RE: Linux Mainline - by ayufan - 08-29-2017, 01:26 AM
RE: Linux Mainline - by ayufan - 08-29-2017, 03:09 AM
RE: Linux Mainline - by rontant - 08-29-2017, 06:18 AM
RE: Linux Mainline - by jl_678 - 08-29-2017, 06:46 AM
RE: Linux Mainline - by rontant - 08-29-2017, 09:39 PM
RE: Linux Mainline - by moravecz - 08-29-2017, 11:29 PM
RE: Linux Mainline - by Farley56 - 08-30-2017, 08:35 AM
RE: Linux Mainline - by jl_678 - 08-30-2017, 07:33 PM
RE: Linux Mainline - by rontant - 09-02-2017, 09:45 PM
RE: Linux Mainline - by ayufan - 09-04-2017, 03:16 PM
RE: Linux Mainline - by rontant - 09-04-2017, 07:51 PM
RE: Linux Mainline - by tillea - 09-19-2017, 11:22 AM
RE: Linux Mainline - by rontant - 09-22-2017, 10:16 PM
RE: Linux Mainline - by scat70 - 09-24-2017, 04:37 AM
RE: Linux Mainline - by scat70 - 09-24-2017, 05:26 AM
RE: Linux Mainline - by stuartiannaylor - 09-24-2017, 08:57 AM
RE: Linux Mainline - by redfish - 01-13-2018, 10:19 PM
RE: Linux Mainline - by redfish - 01-15-2018, 11:21 AM
RE: Linux Mainline - by scat70 - 09-24-2017, 10:58 AM
RE: Linux Mainline - by stuartiannaylor - 09-26-2017, 05:55 AM
RE: Linux Mainline - by rontant - 09-28-2017, 02:54 AM
RE: Linux Mainline - by ayufan - 09-28-2017, 02:25 AM
RE: Linux Mainline - by stuartiannaylor - 09-28-2017, 07:22 AM
RE: Linux Mainline - by maal - 10-05-2017, 10:06 AM
RE: Linux Mainline - by stuartiannaylor - 10-05-2017, 01:07 PM
RE: Linux Mainline - by nocrash - 10-18-2017, 10:37 PM
RE: Linux Mainline - by tarmiste - 12-11-2017, 06:15 AM
RE: Linux Mainline - by maal - 12-11-2017, 10:26 AM
RE: Linux Mainline - by thewonderer - 12-11-2017, 11:39 PM
RE: Linux Mainline - by eloranta - 12-13-2017, 04:10 PM
RE: Linux Mainline - by eloranta - 12-22-2017, 10:17 PM
RE: Linux Mainline - by Osiander - 12-25-2017, 11:00 AM
RE: Linux Mainline - by maal - 01-04-2018, 04:56 PM
RE: Linux Mainline - by thewonderer - 01-04-2018, 06:10 PM
RE: Linux Mainline - by maal - 01-05-2018, 07:18 AM
RE: Linux Mainline - by ClaudiaF - 01-05-2018, 04:58 PM
RE: Linux Mainline - by thewonderer - 01-06-2018, 07:42 PM
RE: Linux Mainline - by maal - 01-06-2018, 03:26 PM
RE: Linux Mainline - by dkryder - 01-06-2018, 07:56 PM
RE: Linux Mainline - by maal - 01-07-2018, 04:00 AM
RE: Linux Mainline - by maal - 01-07-2018, 02:53 PM
RE: Linux Mainline - by valdiks - 01-08-2018, 04:44 AM
RE: Linux Mainline - by matteobp - 01-10-2018, 04:41 AM
RE: Linux Mainline - by maal - 01-10-2018, 08:22 AM
RE: Linux Mainline - by matteobp - 01-10-2018, 11:00 AM
RE: Linux Mainline - by ayufan - 01-14-2018, 05:00 AM
RE: Linux Mainline - by redfish - 01-14-2018, 11:31 AM
RE: Linux Mainline - by t4_4t - 01-19-2018, 09:33 PM
RE: Linux Mainline - by maal - 03-01-2018, 04:42 AM
RE: Linux Mainline - by decontainerized - 06-22-2018, 06:31 AM
RE: Linux Mainline - by beakfire - 07-14-2018, 06:37 PM
RE: Linux Mainline - by suberimakuri - 09-29-2018, 09:52 PM
RE: Linux Mainline-Ayufan 4.20 - by belfastraven - 01-16-2019, 01:49 PM
RE: Linux Mainline-Ayufan 4.20 - by Voyt - 01-22-2019, 04:12 PM
RE: Linux Mainline-Ayufan 4.20 - by kanelxake - 01-24-2019, 02:03 PM
RE: Linux Mainline - by Mentaluproar - 01-23-2019, 08:34 PM
RE: Linux Mainline - by thewonderer - 01-29-2019, 06:56 PM
RE: Linux Mainline - by ElektromAn - 01-30-2019, 02:59 PM
RE: Linux Mainline - by KC7NOA - 01-30-2019, 09:44 PM
RE: Linux Mainline - by shuikaiyuan - 06-15-2019, 11:59 PM
RE: Linux Mainline - by CameronNemo - 08-28-2019, 01:51 AM
RE: Linux Mainline - by Wizzard - 05-14-2021, 10:41 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 172 03-24-2024, 01:07 PM
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,789 06-02-2023, 07:52 AM
Last Post: diederik
  The state of mainline hardware decoding CounterPillow 17 15,402 01-26-2022, 03:39 PM
Last Post: sigmaris
  Linux 5.15 Kernel - openSuse mark1250 0 1,306 12-02-2021, 04:36 PM
Last Post: mark1250
  Alpine Linux isndw 12 18,021 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 1,376 07-29-2021, 07:19 AM
Last Post: shivarj89
  Linux Images (ROCK64) pineadmin 164 283,699 02-12-2021, 10:14 AM
Last Post: useful64
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,438 08-31-2020, 01:41 AM
Last Post: as365n4
  Arch Linux ARM on the Rock64 V3 justinweiss 2 4,939 08-24-2020, 05:16 PM
Last Post: justinweiss
  Arch Linux Arm - external RTC problem max 1 3,012 08-17-2020, 10:35 AM
Last Post: max
