Linux Mainline
(08-28-2017, 04:00 PM)ayufan Wrote: How to install?
wget https://github.com/ayufan-rock64/linux-build/releases/download/0.5.5/linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb
dpkg -i linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb
^^ This will only work when running on one of my images. It will not work with Official images.
^^ In above you may want to look at https://github.com/ayufan-rock64/linux-build/releases and get the latest archive.
I installed from your Strech minimal 4.4.77. I can only report that after reboot into the new kernel, the ssh connection (via Bitvise SSH client) becomes very unstable (frequent disconnection and terminal keyboard becomes sluggish). Dmesg freezes half way and disconnect the SSH client.
rock64@rock64:~$ uname -a
Linux rock64 4.4.77-rockchip-ayufan-93 #1 SMP Tue Aug 29 09:35:00 UTC 2017 aarch64 GNU/Linux
rock64@rock64:~$ wget https://github.com/ayufan-rock64/linux-build/releases/download/0.5.5/linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb
--2017-08-29 09:59:47--  https://github.com/ayufan-rock64/linux-build/releases/download/0.5.5/linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb
Resolving github.com (github.com)... 192.30.255.112, 192.30.255.113
Connecting to github.com (github.com)|192.30.255.112|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://github-production-release-asset-2e65be.s3.amazonaws.com/93933234/d3006ae8-8cb8-11e7-8416-7d0337669e00?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20170830%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20170830T030242Z&X-Amz-Expires=300&X-Amz-Signature=7f821c1e9835fafeb8eba697a66d38f88dec2ff8c2dfb6c0f5dcaea83db6475c&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3Dlinux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb&response-content-type=application%2Foctet-stream [following]
--2017-08-29 09:59:48--  https://github-production-release-asset-2e65be.s3.amazonaws.com/93933234/d3006ae8-8cb8-11e7-8416-7d0337669e00?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20170830%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20170830T030242Z&X-Amz-Expires=300&X-Amz-Signature=7f821c1e9835fafeb8eba697a66d38f88dec2ff8c2dfb6c0f5dcaea83db6475c&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3Dlinux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb&response-content-type=application%2Foctet-stream
Resolving github-production-release-asset-2e65be.s3.amazonaws.com (github-production-release-asset-2e65be.s3.amazonaws.com)... 52.216.160.19
Connecting to github-production-release-asset-2e65be.s3.amazonaws.com (github-production-release-asset-2e65be.s3.amazonaws.com)|52.216.160.19|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 10422630 (9.9M) [application/octet-stream]
Saving to: 'linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb'
linux-image-4.13.0-rc1-r 100%[==================================>]   9.94M   805KB/s    in 29s
2017-08-30 03:03:12 (348 KB/s) - 'linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb' saved [10422630/10422630]
rock64@rock64:~$ sudo dpkg -i linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb
[sudo] password for rock64:
Selecting previously unselected package linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4.
(Reading database ... 37090 files and directories currently installed.)
Preparing to unpack linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4_0.5.5_arm64.deb ...
Unpacking linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4 (0.5.5) ...
Setting up linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4 (0.5.5) ...
update-initramfs: Generating /boot/initrd.img-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4
Warning: root device  does not exist
Using DTB: rk3328-rock64.dtb
Installing /usr/lib/linux-image-4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4/rockchip/rk3328-rock64.dtb into /boot/dtbs/4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4/rk3328-rock64.dtb
Installing new rk3328-rock64.dtb.
Taking backup of rk3328-rock64.dtb.
flash-kernel: deferring update (trigger activated)
Processing triggers for flash-kernel (3.79) ...
flash-kernel: installing version 4.13.0-rc1-rockchip-ayufan-93-ga1d4fc4
Taking backup of Image.
Installing new Image.
Taking backup of initrd.img.
Installing new initrd.img.
Taking backup of dtb.
Installing new dtb.
rock64@rock64:~$ sudo reboot
Linux Mainline - by ayufan - 08-28-2017, 04:00 PM
RE: Linux Mainline - by jl_678 - 08-28-2017, 07:07 PM
RE: Linux Mainline - by ayufan - 08-29-2017, 01:26 AM
RE: Linux Mainline - by ayufan - 08-29-2017, 03:09 AM
RE: Linux Mainline - by rontant - 08-29-2017, 06:18 AM
RE: Linux Mainline - by jl_678 - 08-29-2017, 06:46 AM
RE: Linux Mainline - by rontant - 08-29-2017, 09:39 PM
RE: Linux Mainline - by moravecz - 08-29-2017, 11:29 PM
RE: Linux Mainline - by Farley56 - 08-30-2017, 08:35 AM
RE: Linux Mainline - by jl_678 - 08-30-2017, 07:33 PM
RE: Linux Mainline - by rontant - 09-02-2017, 09:45 PM
RE: Linux Mainline - by ayufan - 09-04-2017, 03:16 PM
RE: Linux Mainline - by rontant - 09-04-2017, 07:51 PM
RE: Linux Mainline - by tillea - 09-19-2017, 11:22 AM
RE: Linux Mainline - by rontant - 09-22-2017, 10:16 PM
RE: Linux Mainline - by scat70 - 09-24-2017, 04:37 AM
RE: Linux Mainline - by scat70 - 09-24-2017, 05:26 AM
RE: Linux Mainline - by stuartiannaylor - 09-24-2017, 08:57 AM
RE: Linux Mainline - by redfish - 01-13-2018, 10:19 PM
RE: Linux Mainline - by redfish - 01-15-2018, 11:21 AM
RE: Linux Mainline - by scat70 - 09-24-2017, 10:58 AM
RE: Linux Mainline - by stuartiannaylor - 09-26-2017, 05:55 AM
RE: Linux Mainline - by rontant - 09-28-2017, 02:54 AM
RE: Linux Mainline - by ayufan - 09-28-2017, 02:25 AM
RE: Linux Mainline - by stuartiannaylor - 09-28-2017, 07:22 AM
RE: Linux Mainline - by maal - 10-05-2017, 10:06 AM
RE: Linux Mainline - by stuartiannaylor - 10-05-2017, 01:07 PM
RE: Linux Mainline - by nocrash - 10-18-2017, 10:37 PM
RE: Linux Mainline - by tarmiste - 12-11-2017, 06:15 AM
RE: Linux Mainline - by maal - 12-11-2017, 10:26 AM
RE: Linux Mainline - by thewonderer - 12-11-2017, 11:39 PM
RE: Linux Mainline - by eloranta - 12-13-2017, 04:10 PM
RE: Linux Mainline - by eloranta - 12-22-2017, 10:17 PM
RE: Linux Mainline - by Osiander - 12-25-2017, 11:00 AM
RE: Linux Mainline - by maal - 01-04-2018, 04:56 PM
RE: Linux Mainline - by thewonderer - 01-04-2018, 06:10 PM
RE: Linux Mainline - by maal - 01-05-2018, 07:18 AM
RE: Linux Mainline - by ClaudiaF - 01-05-2018, 04:58 PM
RE: Linux Mainline - by thewonderer - 01-06-2018, 07:42 PM
RE: Linux Mainline - by maal - 01-06-2018, 03:26 PM
RE: Linux Mainline - by dkryder - 01-06-2018, 07:56 PM
RE: Linux Mainline - by maal - 01-07-2018, 04:00 AM
RE: Linux Mainline - by maal - 01-07-2018, 02:53 PM
RE: Linux Mainline - by valdiks - 01-08-2018, 04:44 AM
RE: Linux Mainline - by matteobp - 01-10-2018, 04:41 AM
RE: Linux Mainline - by maal - 01-10-2018, 08:22 AM
RE: Linux Mainline - by matteobp - 01-10-2018, 11:00 AM
RE: Linux Mainline - by ayufan - 01-14-2018, 05:00 AM
RE: Linux Mainline - by redfish - 01-14-2018, 11:31 AM
RE: Linux Mainline - by t4_4t - 01-19-2018, 09:33 PM
RE: Linux Mainline - by maal - 03-01-2018, 04:42 AM
RE: Linux Mainline - by decontainerized - 06-22-2018, 06:31 AM
RE: Linux Mainline - by beakfire - 07-14-2018, 06:37 PM
RE: Linux Mainline - by suberimakuri - 09-29-2018, 09:52 PM
RE: Linux Mainline-Ayufan 4.20 - by belfastraven - 01-16-2019, 01:49 PM
RE: Linux Mainline-Ayufan 4.20 - by Voyt - 01-22-2019, 04:12 PM
RE: Linux Mainline-Ayufan 4.20 - by kanelxake - 01-24-2019, 02:03 PM
RE: Linux Mainline - by Mentaluproar - 01-23-2019, 08:34 PM
RE: Linux Mainline - by thewonderer - 01-29-2019, 06:56 PM
RE: Linux Mainline - by ElektromAn - 01-30-2019, 02:59 PM
RE: Linux Mainline - by KC7NOA - 01-30-2019, 09:44 PM
RE: Linux Mainline - by shuikaiyuan - 06-15-2019, 11:59 PM
RE: Linux Mainline - by CameronNemo - 08-28-2019, 01:51 AM
RE: Linux Mainline - by Wizzard - 05-14-2021, 10:41 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 165 03-24-2024, 01:07 PM
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,780 06-02-2023, 07:52 AM
Last Post: diederik
  The state of mainline hardware decoding CounterPillow 17 15,362 01-26-2022, 03:39 PM
Last Post: sigmaris
  Linux 5.15 Kernel - openSuse mark1250 0 1,304 12-02-2021, 04:36 PM
Last Post: mark1250
  Alpine Linux isndw 12 17,976 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 1,371 07-29-2021, 07:19 AM
Last Post: shivarj89
  Linux Images (ROCK64) pineadmin 164 283,234 02-12-2021, 10:14 AM
Last Post: useful64
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,420 08-31-2020, 01:41 AM
Last Post: as365n4
  Arch Linux ARM on the Rock64 V3 justinweiss 2 4,927 08-24-2020, 05:16 PM
Last Post: justinweiss
  Arch Linux Arm - external RTC problem max 1 3,008 08-17-2020, 10:35 AM
Last Post: max
