How to Setup Serial Console Cable Over the Rock64 SBC
The Photon has been connected to Rock64 via TX and RX pin crossover at each end.
But I am not getting any message on the serial console here is the attached putty and mincom console screen
https://ibb.co/mxYpJe
Connection
Rock 64            Photon          Nextion Display
GPIO6(gnd)-------gnd pin------------Gnd pin
GPIO8(TX)---------RX pin-------------TX pin
GPIO10(RX)-------TX pin-------------RX pin
Here is the circuit diagram using Fertilizing https://ibb.co/ebtOeU
The code is located in the Photon Memory and it send data via serial com to both RX pins (rock64 and Nextion display) the nextion touch display acts as a control panel for photon
RE: How to Setup Serial Console Cable Over the Rock64 SBC - by Mpoint - 10-05-2018, 05:14 PM
  Are HW design files available for ROCK64? irenek 3 4,801 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 338 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,076 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 628 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,262 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,755 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,537 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,635 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,563 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,064 09-28-2021, 03:07 PM
Last Post: TRS-80
