Beginners Guide: Migrating to SSD
This is for Rock 64 LINUX beginners who wants to migrate their Debian Jessie/Stretch minimal from the SD card to a much faster (SSD) and/or bigger drive.
Assuming  the SSD has already been connected,  partitioned,  and formatted to EXT4, here are few simple steps to follow: :
1. Label the SSD partition where the root file systems will be migrated to.
Quote:sudo e2label /dev/sda1 rootfs
Here, my SSD partition is /dev/sda1 (yours maybe different) and I use rootfs as the label. You can use whatever label of your choice but make sure you use the same label on step 4.
2. Mount the SSD drive
Quote:sudo mount /dev/sda1 /mnt
3. Copy (or move) the root file system from the SD card to the SSD partition.
Quote:sudo cp -avx  / /mnt
4. Tell Linux where to find the root file system by editing the configuration file  /boot/efi/extlinux/extlinux.conf
Quote:sudo nano  /boot/efi/extlinux/extlinux.conf
In the editor, you will see the text as follows:
Quote:label kernel-4.4
    kernel /Image
    initrd /initrd.img
    fdt /dtb
    append earlycon=uart8250,mmio32,0xff130000 rw root=LABEL=linux-root rootwait rootfstype=ext4 init=/sbin/init coherent_pool=1M
Change LABEL=linux-root to LABEL=rootfs  or whatever label you used on step 1.
Save the change and exit the editor.
5. Reboot
After reboot and login back, you can verify with lsblk -f command.
Quote:sudo lsblk -f
Have fun.
Beginners Guide: Migrating to SSD - by rontant - 08-19-2017, 12:59 AM
RE: Beginners Guide: Migrating to SSD - by rmbusy - 10-29-2017, 10:56 PM
RE: Beginners Guide: Migrating to SSD - by Luke - 10-30-2017, 02:58 AM
RE: Beginners Guide: Migrating to SSD - by GaryLa - 01-23-2018, 02:41 PM
RE: Beginners Guide: Migrating to SSD - by Luke - 01-23-2018, 03:30 PM
RE: Beginners Guide: Migrating to SSD - by GaryLa - 01-23-2018, 05:54 PM
RE: Beginners Guide: Migrating to SSD - by Luke - 01-24-2018, 05:37 PM
RE: Beginners Guide: Migrating to SSD - by svyt22 - 01-28-2018, 04:40 AM
Information Beginners Guide: Adding USB Storage, Linux Formatting and Permissions Ptheven 4 12,370 03-06-2021, 01:49 PM
Last Post: helpmerock
  Step by step guide PXE diskless configuration. burglar_ot 13 36,075 11-01-2020, 11:26 PM
Last Post: michael.gruner
Thumbs Up A guide for how I made RetroPie, RetroArch, and EmulationStation Work on the Rock64 Mrfixit2001 4 16,217 12-17-2018, 03:52 AM
Last Post: va88
  Guide - XRDP - Debian Stretch / Ubuntu Xenial / OMV S3phi40T 3 14,069 05-05-2018, 06:08 AM
Last Post: S3phi40T
Information Guide - Raid Array (Raid 0) Ptheven 0 4,864 10-07-2017, 09:22 AM
Last Post: Ptheven
Information Guide - Setting up a NFS Share Ptheven 0 5,532 09-26-2017, 04:44 AM
Last Post: Ptheven
  Guide - Setting up a SMB(Windows) file server Ptheven 0 12,660 08-21-2017, 08:54 AM
Last Post: Ptheven
Information Beginners Guide: Locating your board, connecting to it. Ptheven 5 16,052 08-21-2017, 04:12 AM
Last Post: Ptheven
