Powering up and down USB
Ah OK, I see where you're pointing at Smile
So if I get this straight, this jumper controls whether the vcc-5v is connected directly to the microusb 5v power supply or an upconverted 3.7V supply from the battery. So if I was powering this from DC, cutting the connection J9, 1, 2 would cut power to the 5V power rail, and so the USB devices.
I'm still not sure I understand completely, but staring at it helps. Thank you.
One further question (that makes me suspect I do not understand). The schematic also says "Note: When using DC 5V and battery supply together, Disconnect J9 1, 2, 3, 4" How in this case is the right voltage supplied to the USB power rail?
Powering up and down USB - by reverend_t - 08-17-2017, 11:27 AM
RE: Powering up and down USB - by reverend_t - 08-17-2017, 01:04 PM
RE: Powering up and down USB - by reverend_t - 08-17-2017, 03:54 PM
RE: Powering up and down USB - by reverend_t - 08-21-2017, 06:11 AM
  PINE64 board not powering up loki21century 2 5,630 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 7,310 05-03-2019, 02:48 PM
Last Post: Mendota
  Need some help on powering 16 PINEs pineresearch 13 17,103 04-01-2017, 02:33 AM
Last Post: longsleep
  Pine A64 not powering up / Power button missing vaevictis 10 14,058 07-06-2016, 01:28 PM
Last Post: xalius
