Is the Rock 64 something strange?
(08-17-2017, 03:40 PM)kometchtech Wrote:
(08-17-2017, 11:35 AM)MarkHaysHarris777 Wrote:
(08-17-2017, 09:16 AM)fire219 Wrote: Personally, this sounds more like a power supply issue (voltage too low, causing glitches).
What power supply are you using?
This might be a power supply issue, indeed .
...  I need to make a comment on why Evo Plus.  If the card actually supports Evo  then the card will work better in a classical environment;  and also ( believe it or not ) run faster in general.  To put this more succinctly, the Evo Plus cards are a higher quality card and less likely to be prone to malfeasance ( no promises, just generally true ).
It is also important to get your cards from a reputable supplier;  if you buy one of the cheap cards on-line for that unbelievably low price , well , you're just asking for trouble ( I mean this with no sarcasm and ver genuinely ).
Fire219 makes a good point;  our two biggest problems are PSU, and SD card.  The PSU we recommend ( for various reasons ) is the switching supply on the pine store rated for 5v @3000ma;  3.0A.  DO NOT use a charger, and do not try to use a cheap linear supply or one rated for less than 2500ma.  YMMV,  and I'm not arguing about it.  If you don't want to do either of these recommendations, ok.
I did not mention power supply.
But I do not think there is any problem with this.
Because I use the AC adapter (5v3a) I bought from official as I purchase Rock64.
Should I also doubt about this?
Best regards.
No.   Seriously, just get another good card and retry.
RE: Is the Rock 64 something strange? - by MarkHaysHarris777 - 08-17-2017, 04:02 PM
  Rock 64 failure / kernel panic n0021913 2 1,753 07-07-2022, 01:16 PM
Last Post: anchor00
  Rock 64 seem like a dead end munocat 3 4,926 03-21-2019, 10:13 PM
Last Post: thewonderer
  Rock 64 network error as soon as I try to write or read. georgegohl888 1 2,997 03-12-2019, 09:35 AM
Last Post: georgegohl888
  Rock 64 a failure..very disappointed arxaios 5 6,906 11-02-2018, 07:29 AM
Last Post: Trash_Can_Man
  [Issue] All Rock leds are blinking Chispolas 6 7,968 04-18-2018, 09:12 PM
Last Post: pfeerick
  [Warning: root device does not exist] Can not install generic kernel on ROCK 64? pine3228 0 2,612 03-16-2018, 05:40 PM
Last Post: pine3228
  [Repaired] [Progressed] [Successful] How to play Minecraft with ROCK 64 pine3228 9 11,811 03-11-2018, 07:46 AM
Last Post: pine3228
Sad Rock 64 No video borisacomputers 4 5,522 03-03-2018, 03:11 PM
Last Post: borisacomputers
  Strange situation mcrognale 5 5,405 11-01-2017, 08:56 PM
Last Post: mcrognale
Wink My Stick of Rock digitaldaz 3 3,911 10-26-2017, 09:23 AM
Last Post: Luke
