pinebook won't power up or charge
Hello,  I don't use my pinebook often so it seems like after a few days of non use the batteries loose there charge and usually I can just plug it in for a few hours and get it to power on.  This time I've left it plugged in for 2 hours + and I still am unable to get any indication that it's ever charging.  I've held the power button down for several seconds, which usually will turn the green power light on and if it can't boot it will show a battery charging icon on the screen.  I'm not sure when/how but there is a little light next to the power port that turns on.  It's not turned on.  The last time I charged this unit the plastic on the case above the power port would get very hot.  I'm also using the power adapter that came with the pinebook.  Is there something else I can try or is this thing toast?
pinebook won't power up or charge - by eclay - 08-03-2017, 11:15 AM
RE: pinebook won't power up or charge - by Luke - 08-03-2017, 11:28 AM
RE: pinebook won't power up or charge - by eclay - 08-03-2017, 02:52 PM
RE: pinebook won't power up or charge - by Luke - 08-03-2017, 03:21 PM
RE: pinebook won't power up or charge - by eclay - 08-03-2017, 04:06 PM
RE: pinebook won't power up or charge - by Luke - 08-03-2017, 04:16 PM
  pinebook 1080p power/barrel connector/cable cel 0 553 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,387 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,239 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,654 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,365 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,632 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,641 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,907 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,688 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,938 07-02-2020, 06:33 PM
