Boots just fine. Can not install new image.
If you are running the stock Ubuntu Mate image that came with the pinebook, you'll find it both slower than the current ayufan builds (plus all the inevitable bug fixes and tweaks that have come over time).
You will find android quite slow on the pinebook via microSD card unless you use a card with good random I/O performance. I would recommend that if you intend to be booting from the SD for stuff, that you get yourself a could of Samsung EVO cards... they have the best random I/O performance and have proven to be very reliable. The best setup if you want to be able to use android AND linux is to install android to your eMMC as that will give Android the best performance, and then use Linux from your microSD.
Unfortunately there is no BIOS/preboot screens. If you get a USB to serial adapter though, you could enable the serial UART on the headphones jack, and see what is going on, but I can almost guarantee that if you try a different card type you won't have any issues (since you've used Etcher and corrupt or faulty microSDs shouldn't be an issue).
I believe there may be an issue with 64GB+ cards (as they going into the XC class), but I need to find out more about that.
RE: Boots just fine. Can not install new image. - by pfeerick - 07-24-2017, 01:34 AM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 777 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  PBP Debian 11 GRUB install error zlth 2 2,028 11-18-2022, 07:42 AM
Last Post: zlth
  Soquartz - what image for Model A baseboard? kbanfield 0 1,525 10-14-2022, 10:38 AM
Last Post: kbanfield
  wrong launguage install chadace 1 4,083 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 6,524 03-18-2020, 09:42 AM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 152,193 01-15-2020, 12:46 PM
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,711 05-15-2019, 02:55 PM
Last Post: Thatoo
  Creating bootable Debian backup image Drago 3 6,078 12-11-2018, 03:42 PM
Last Post: evilbunny
  Rock64 suitable for headless TVHeadend install? elsmandino 3 6,555 06-26-2018, 11:37 AM
Last Post: Luke
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,277 04-15-2018, 07:37 AM
Last Post: bunkerWHz
