Creating bootable Debian backup image
Hi all,
I'd like to periodically create backup images of Debian (stretch-minimal-rockpro64-0.7.9-1067) because I end up breaking my system a lot (I am a brand new to Linux). How would I go about doing this? Could I take an image of my microSD while it's connected to my macbook pro, or do I have to do this from the Debian command line?
-D
(08-31-2018, 03:01 PM)Drago Wrote: Hi all,
-D
If you want offline backups you can just use dd to clone the image, if you want backups while it's running you'll need something like rsnapshot which can take incremental backups.
-D
I'm booting from eMMC, so while using dd backup, do I do just dd if=/dev/mmcblk1 [...] or should I also backup /dev/mmcblk1boot0 and /dev/mmcblk1boot1?
-D
You only need to dd the device. That will backup everything including the partition table.
  PBP Debian 11 GRUB install error zlth 2 4,970 11-18-2022, 07:42 AM
Last Post: zlth
  Soquartz - what image for Model A baseboard? kbanfield 0 3,233 10-14-2022, 10:38 AM
Last Post: kbanfield
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 217,027 01-15-2020, 12:46 PM
  Rock64 with Debian netinst usb Bloris 6 14,936 12-03-2019, 12:37 PM
Last Post: madalin
Information Creating a NAS server in Pine64 javi_cala 4 12,560 01-21-2019, 02:03 AM
Last Post: bartes
  The Debian Jessie User Accounts? jesse1234 6 12,720 01-20-2019, 06:07 PM
Last Post: zer0sig
  7" Screen - Does it work with Debian abasel 1 6,249 07-26-2017, 05:44 AM
Last Post: pfeerick
  Boots just fine. Can not install new image. willpine 5 12,211 07-25-2017, 06:39 AM
Last Post: willpine
  unable to write an pine64 image on a 16G micro suresh 2 8,708 01-26-2017, 12:56 PM
Last Post: suresh
  Need support for Database use in debian jessie other than mysql sarav_sara 4 10,323 01-16-2017, 06:23 AM
Last Post: Luke
