unable to write an pine64 image on a 16G micro
i have been trying in vain to get a bootable 16G micro SD card with SentOS and Android for a while now. no luck.
i have tried numerous programs like etcher and it always fails in validation.
not sure what i am doing wrong.
tried 2 diff computers with W10.
(01-26-2017, 10:56 AM)suresh Wrote: i have been trying in vain to get a bootable 16G micro SD card with SentOS and Android for a while now. no luck.
CentOS - could you provide a link to the img please? Also, which version of android did you try to flash - ayufan's 6/ 7, or pine's 5.1?
Assuming you did everything correctly, its probably a faulty SD card.
picked the 16GB android (6.0)and RemixOS (2.0). from this link below. Etcher fails. i can format the SD card and write files to it.
i used Rufus and it seem to work. will test it out and update.
http://wiki.pine64.org/index.php/Main_Pa..._OS_Images
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 10,541 10-21-2025, 10:13 AM
  Soquartz - what image for Model A baseboard? kbanfield 0 3,260 10-14-2022, 10:38 AM
Last Post: kbanfield
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,805 08-24-2021, 08:17 AM
Last Post: lamson
  Newbie unable to connect to internet Derek7 2 6,141 07-16-2021, 12:41 AM
Last Post: Derek7
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,200 06-17-2021, 05:35 AM
Last Post: kqlnut
  micro sd card won't insert Samuel Venable 2 7,201 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  Just discovered Pine64 ! - first Q philip_rhoades 4 10,412 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 6,684 04-19-2020, 10:33 PM
  recommended micro sd card ? mronhb 91 304,433 03-03-2020, 11:34 PM
Last Post: siyatalerja
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 217,261 01-15-2020, 12:46 PM
