Pinebook SDIO gpio control using SD card slot blog post
This post is just to document the placement of the pins on my breakout with the extender;  the Sparkfun breakout board ( coming soon ) has a slightly different layout.
Pin     SD      SPI
PF5     D2      X
PF4     D3      CS
PF3     CMD     DI
+       VDD     VDD
PF2     CLK     SCLK
PF1     D0      DO
PF0     D1      X
-       VSS     VSS
Note:  Vss in the pic above (ground) is normally the third pin up from the bottom, between D0 and CLK.  I moved Vss physically to create two logical groups of three pins PF0-2 and PF3-5;  this also allows for good separation between Vdd and Vss.
Note:  See schematic pp 9;  T-card/USB
RE: Pinebook SDIO gpio control using SD card slot blog post - by MarkHaysHarris777 - 07-22-2017, 07:44 AM
  pinebook 1080p power/barrel connector/cable cel 0 568 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,399 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,255 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,673 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,401 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,652 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 3,027 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,659 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 14,002 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  CH341 boards for GPIO xalius 1 4,173 11-22-2020, 10:50 AM
Last Post: pinephonenewbee
