Pinebook 14" keyboard misses keypresses UPDATE
In the pics above we're looking at the pin(1 -- 12) edge of the Pinebook 8051 MCU responsible for reading the keyboard matrix.  The left pic shows the bent pin(12) , and the pic at the right shows the re-soldered pin(12) !
In 3D the pin(12) never got soldered at all ( because the P&P robot bent the pin! );  pin(12) was shorted against pin(11) which prevented the 8051 from detecting Alt_L and Alt_R (both alt keys were effectively dead).
I used a microscope and surgical scalpel to straighten the pin, then coated the junction with a thin film of rosin flux gel.  I then applied one very quick stroke of a very sharp lite-tinned immaculate soldering tip along the outside edge of the pad|pin;  if this had been any other pin except the corner pin it might not have been possible!
Output(s) from the xev tests above show the Alt_L and Alt_R keypress and keyrelease. The entire keyboard checked out;  the good news is that the shorted pin(11) & pin(12)  did not damage the 8051, and all is good!
Shy
RE: Pinebook 14" keyboard misses keypresses UPDATE - by MarkHaysHarris777 - 09-16-2017, 07:23 PM
  pinebook 1080p power/barrel connector/cable cel 0 584 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,410 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,273 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,697 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,427 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,681 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,681 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 14,075 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,714 08-20-2020, 08:18 AM
Last Post: Reinoud
  Did pine64 change the keyboard? Hsingai 1 3,907 08-10-2020, 06:52 PM
