WARNING: internal 10|100 PHY requires magjack hardware!
(04-08-2018, 10:55 AM)xalius Wrote: Can you link a datasheet for your magjack? How is the center tap wired out, or is it internally connected?
Sure, here's the datasheet for the magjack itself: https://www.sparkfun.com/datasheets/Prot...agJack.pdf
And here's the schematic for the breakout board it's attached to: https://cdn.sparkfun.com/datasheets/Brea...ut_v12.pdf
I had also found this project where they connected the same breakout board to some arduino-like board. I tried to copy how they wired up the 4 pins.
RE: WARNING: internal 10|100 PHY requires magjack hardware! - by psychedup - 04-09-2018, 07:43 AM
  Any way to tell the rock64's hardware revision? kittyland 1 2,972 07-01-2021, 09:42 PM
Last Post: evilbunny
  Hardware random number generator? scalextrix 13 16,071 06-04-2018, 02:05 AM
Last Post: scalextrix
  Latest Rock64 board hardware revision Ryan 3 5,262 03-14-2018, 05:42 AM
Last Post: petec
Question How can I use the internal 100M ethernet? gabrielmartinslima 1 2,713 02-12-2018, 02:10 PM
Last Post: dkryder
Information Rock64 SSD internal PNY CS900 240GB w/Pine usb|sata adapter MarkHaysHarris777 1 3,702 09-30-2017, 06:48 AM
Last Post: dkryder
