Rock64 SSD internal PNY CS900 240GB w/Pine usb|sata adapter
Information
The pic above left is my new internal PNY CS900 SSD ( solid state drive ) attached via the Pine store usb|sata adapter;  there is not enough juice to power the SSD stand-alone via the usb3.0 port -- consequently I have the PNY running from my belkin usb powered hub.  The usb|sata adapter has a power port for 12v @2A in;  its on order;  will update with performance data once attached via usb3.0.
The SSD is very fast as is;  I used it tonight to backup my eMMC file system,  as well downloaded the first Lakka image for testing;  I built the Lakka image right on the Rock64 -- writing the image with dd directly to the SD card from the PNY CS900 SSD!  This was completely successful.
I will be posting iozone3 perf data on both setups once my 12v adapter gets in.
The pic above right is my frog.  Actually, its a three toed tree toad;  Yes, i'm serious.  I just thought you might like to see her;  yes, she's female.
Shy
i promise not to ask how you knew the frog was female.
  Are HW design files available for ROCK64? irenek 3 4,754 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 329 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,061 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 619 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,213 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,733 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,517 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,611 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,502 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,024 09-28-2021, 03:07 PM
Last Post: TRS-80
