How to write image to emmc module on the pinebook
(06-26-2017, 04:41 PM)jordanjay29 Wrote: Correct me if I'm wrong, but ayufan's current images only support flashing the eMMC with a brand new downloaded image, and not the contents on the SD card.
Luke is referring to the PINE64 installer, a program you can run from Linux, MacOS/X or Windows IIRC (have only used Linux) to write to an SSD, not the included scripts found in /usr/local/sbin - you burn one of multiple downloadable images or a saved image file, then upon booting said microSD in the pinebook, you can run the script to install or reinstall to the eMMC (I've done this twice since friday, once after munging my eMMC from an Android install and once after setting the brightness too low and finding it easier to reinstall than to try to figure out where Ubuntu keeps default brightness settings) - link to the install client is here: https://github.com/pine64dev/PINE64-Inst.../README.md
it doesn't get happy
it doesn't get sad
it just runs programs
RE: How to write image to emmc module on the pinebook - by zer0sig - 06-26-2017, 06:16 PM
  pinebook 1080p power/barrel connector/cable cel 0 552 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,386 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,237 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,651 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,360 01-03-2022, 03:28 AM
Last Post: kqlnut
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 1,524 10-16-2021, 02:03 PM
Last Post: quixote
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,629 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 3,006 03-26-2021, 09:27 AM
Last Post: jezek
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,637 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,890 12-19-2020, 06:55 PM
Last Post: ron_burgundy
