Shipping Progress
(02-16-2021, 04:52 PM)WarpLover Wrote:
(02-16-2021, 04:25 PM)dgdimick Wrote:
(02-16-2021, 04:11 PM)WarpLover Wrote:
(02-16-2021, 03:04 PM)TRS-80 Wrote:
(02-14-2021, 02:05 PM)WarpLover Wrote: Are we limited to just one phone per order or could we order two, from your experience?
From some correspondence I had with sales via email they said you could order "up to 5" but for more than that to contact them for an Invoice (whatever that means).
Which, incidentally, had nothing to do with the question I actually asked them Big Grin but maybe sharing this information here ends up helping someone else out, after all.
Your avatar looks like a RS Color Computer to me.
(02-15-2021, 09:50 PM)dgdimick Wrote:
(02-15-2021, 11:58 AM)WarpLover Wrote: I want a convergence running Mobian. I always max out on the HW options when I buy something like this, so 3gb is a must. I will want to use the phone as a computer, so the ability to have mouse, keyboard and full screen is fantastic. And a phone that could run on a wired Ethernet! Who would have thought?
I also will want to do SDR. I was disappointed to hear that almost every wifi chipset has FM built in, but no one make drivers for them and apparently they aren't completely hooked up within the chip either. FM will be nice to have on the SDR.
I was just thinking about Pine64s keyboard with 2 USB ports. So you plug in the convergence adapter and that adds a USB hub to the phone. And when you plug a Pine64 keyboard into that, it adds another USB hub? Is the keyboard using external power, or is it getting its power from the convergence adapter in that scenario? Just wondering out loud.
The RTL-SDR has been demonstrated as working with the PinePhone.
I'm pushing my luck here, but I wonder if anyone has tried a Hauppauge TV tuner in the USB port of the adapter? It's used on linux and many home theater boxes, I just wondered if they have tried it on the phone yet?
So after the Feb announcement, its clear I won't get Mobian preinstalled. No Biggie. All I can say on the decision for only shipping Manjero preinstalled is....it better work.
I'm not sure about the Hauppauge tuner, is it using the same Chip set as the RTL-SDR? If so it shouldn't be an issue.
I'm also pretty sure it's not that hard to swap out the OS version when you do get your Phone, there seems to be pretty good documentation on how to do it.
It's unrelated to SDR.
It's a USB dongle with a coax connector on the opposite end. It has dual TV tuners inside (watch one show - record another, or picture in picture). It scans the signal on the coax for channels like a TV does, and you end up with a software TV tuner/PVR/TV Guide and so on. It would be great for local free "airband" TV (weather, sports). Comes with a very small portable TV antenna.
I can get everything BUT local TV on my PC. This device changes that.
https://youtu.be/Gkdkh4NleVA
Some random stuff because I'm just waking up, have not had my coffee, and have a bit of A.D.D.
I'm not sure if you're understanding how Linux works, or me it could just be me miss-understanding your post, however, It is ALL about the chipset.
Just because it's an SDR, and plugs into your computer, doesn't mean it's supported by the OS. Unless someone has taken the time to write a DRIVER for the Chipset used by XYZ SDR, then it will not work. The current DOCUMENTED CHIPSET supported is the RTL2832U chipset. A quick search for the Chipset used by the Hauppauge TV tuner turns up a mess of nonsense; it's sort of like searching for "I own a car"
I'll try and use two analogies here to explain DRIVERS and SOFTWARE.
1 - When you buy XYZ product, you may need to install some type of driver, normally this is provided by the software required to be installed to use XYZ product. If the Hauppauge TV tuner isn't supported by an OS, (Windows, Mac OS, Linux, etc) it's because the divers needed by the OS have not been written; the OS wont even "see" the SDR when it's inserted in to the USB slot. Then you need someone to write the SOFTWARE to provide the functions you want to use with the XYZ product.
2 - Think of it as a car, you want XYZ tires, however, BMW hasn't built the correct RIMS needed to mount the tires on the car; Software drivers. Once someone comes out with the correct rims; Software Drivers.  You now need to find someone to mount the tires on the rim; Software that allows the car to drive with these new tires.
I'm hoping I've been able to clear up any confusion, with out coming across as a jerk, it's not me intention - it's a failure to have a real time conversation; I say something and you ask questions.
As one random bit of information that could be helpful, check out this URL for more information on Linux support for the SDR Dongle you own
https://www.hauppauge.com/pages/support/...linux.html
While I don't own this SDR, I'll be more then happy to try and help you when I get my PinePhone, so at least try and get it to working for you, I'm not going to promise I'll be able to solve any issue you have, however, I can at least try to help. A simple duckduckgo search doesn't return any data that someone has figured out how to get your SDR Dongle to work, however, this doesn't mean you should give up all hope, just use it as a data point, that it may not work.
I'm more then willing to spend the time communicating with you, so you can understand this subject, someone a LONG time ago spent the time helping me understand this, and I'm more then happy to help someone else.
Shipping Progress - by TerryB - 03-03-2016, 05:10 PM
RE: Shipping Progress - by tllim - 03-03-2016, 05:40 PM
Shipping Progress - by RaspiBit - 03-04-2016, 02:51 AM
RE: Shipping Progress - by tllim - 03-04-2016, 09:46 AM
RE: Shipping Progress - by RaspiBit - 03-04-2016, 10:30 AM
RE: Shipping Progress - by tllim - 03-04-2016, 03:11 PM
RE: Shipping Progress - by RaspiBit - 03-04-2016, 03:39 PM
RE: Shipping Progress - by tllim - 03-04-2016, 04:01 PM
RE: Shipping Progress - by RaspiBit - 03-04-2016, 04:29 PM
RE: Shipping Progress - by TerryB - 03-06-2016, 04:18 PM
RE: Shipping Progress - by GoZone - 03-08-2016, 01:22 PM
RE: Shipping Progress - by Tarjei85 - 03-07-2016, 03:10 AM
RE: Shipping Progress - by tllim - 03-07-2016, 10:03 AM
RE: Shipping Progress - by pine.tree - 03-07-2016, 10:27 AM
RE: Shipping Progress - by ViperVi - 03-07-2016, 10:44 AM
RE: Shipping Progress - by tllim - 03-07-2016, 11:19 AM
RE: Shipping Progress - by Tarjei85 - 03-07-2016, 10:44 AM
RE: Shipping Progress - by KryPtAlIvIaN - 03-07-2016, 01:29 PM
Shipping Progress - by RaspiBit - 03-07-2016, 03:11 PM
RE: Shipping Progress - by alid - 03-09-2016, 12:26 AM
RE: Shipping Progress - by tllim - 03-09-2016, 12:53 AM
RE: Shipping Progress - by Ghost - 03-09-2016, 02:59 AM
RE: Shipping Progress - by tllim - 03-09-2016, 03:22 AM
RE: Shipping Progress - by hazerty - 03-09-2016, 01:12 AM
RE: Shipping Progress - by tllim - 03-09-2016, 02:11 AM
RE: Shipping Progress - by Ghost - 03-09-2016, 03:27 AM
RE: Shipping Progress - by tllim - 03-09-2016, 03:38 AM
RE: Shipping Progress - by joe - 03-09-2016, 04:07 AM
RE: Shipping Progress - by hazerty - 03-09-2016, 04:07 AM
RE: Shipping Progress - by norm24 - 03-09-2016, 05:49 AM
RE: Shipping Progress - by tllim - 03-09-2016, 01:32 PM
RE: Shipping Progress - by hazerty - 03-09-2016, 06:57 AM
RE: Shipping Progress - by norm24 - 03-09-2016, 07:33 AM
RE: Shipping Progress - by RaspiBit - 03-09-2016, 08:19 AM
RE: Shipping Progress - by GoZone - 03-09-2016, 09:58 AM
RE: Shipping Progress - by tllim - 03-09-2016, 11:47 AM
RE: Shipping Progress - by peterz - 03-09-2016, 12:40 PM
RE: Shipping Progress - by JulianM - 03-09-2016, 12:46 PM
RE: Shipping Progress - by JulianM - 03-09-2016, 01:47 PM
RE: Shipping Progress - by hazerty - 03-09-2016, 01:58 PM
RE: Shipping Progress - by tllim - 03-09-2016, 02:25 PM
RE: Shipping Progress - by Tarjei85 - 03-09-2016, 03:03 PM
RE: Shipping Progress - by tllim - 03-09-2016, 04:01 PM
RE: Shipping Progress - by Tarjei85 - 03-11-2016, 12:57 PM
RE: Shipping Progress - by pine.tree - 03-11-2016, 01:19 PM
RE: Shipping Progress - by Tarjei85 - 03-11-2016, 04:06 PM
RE: Shipping Progress - by RaspiBit - 03-09-2016, 04:11 PM
RE: Shipping Progress - by PAPABEAR121268 - 03-09-2016, 10:52 PM
RE: Shipping Progress - by tllim - 03-09-2016, 11:59 PM
RE: Shipping Progress - by GoZone - 03-11-2016, 12:33 PM
RE: Shipping Progress - by batrad - 03-14-2016, 11:55 AM
Shipping Progress - by RaspiBit - 03-14-2016, 02:36 PM
RE: Shipping Progress - by g_t_j - 03-14-2016, 02:41 PM
RE: Shipping Progress - by tllim - 03-15-2016, 08:59 AM
RE: Shipping Progress - by g_t_j - 03-15-2016, 09:47 AM
RE: Shipping Progress - by tllim - 03-15-2016, 09:56 AM
RE: Shipping Progress - by g_t_j - 03-15-2016, 10:04 AM
RE: Shipping Progress - by thtroyer - 03-15-2016, 01:18 PM
RE: Shipping Progress - by g_t_j - 03-15-2016, 01:26 PM
RE: Shipping Progress - by RaspiBit - 03-15-2016, 09:22 AM
RE: Shipping Progress - by hazerty - 03-15-2016, 02:32 PM
RE: Shipping Progress - by thtroyer - 03-15-2016, 02:47 PM
Shipping Progress - by RaspiBit - 03-15-2016, 04:41 PM
RE: Shipping Progress - by dabone - 03-15-2016, 05:25 PM
RE: Shipping Progress - by tllim - 03-16-2016, 09:59 AM
RE: Shipping Progress - by hazerty - 03-16-2016, 01:15 AM
RE: Shipping Progress - by NWUK - 03-16-2016, 04:04 AM
RE: Shipping Progress - by thtroyer - 03-16-2016, 08:29 AM
RE: Shipping Progress - by dabone - 03-16-2016, 11:20 AM
RE: Shipping Progress - by tllim - 03-16-2016, 04:00 PM
RE: Shipping Progress - by hrw - 03-17-2016, 03:17 AM
RE: Shipping Progress - by Bart333 - 03-16-2016, 04:19 PM
RE: Shipping Progress - by tllim - 03-16-2016, 04:34 PM
RE: Shipping Progress - by rakib-hasan - 03-18-2016, 01:04 PM
RE: Shipping Progress - by tllim - 03-18-2016, 04:31 PM
RE: Shipping Progress - by ataylorm - 03-18-2016, 03:25 PM
RE: Shipping Progress - by RaspiBit - 03-18-2016, 10:23 PM
RE: Shipping Progress - by tllim - 03-18-2016, 10:52 PM
RE: Shipping Progress - by Triggernometry - 03-19-2016, 08:06 AM
RE: Shipping Progress - by alid - 03-20-2016, 08:59 PM
RE: Shipping Progress - by devildog125 - 03-19-2016, 03:32 PM
RE: Shipping Progress - by tllim - 03-19-2016, 08:43 PM
RE: Shipping Progress - by g_t_j - 03-20-2016, 02:30 AM
RE: Shipping Progress - by peterz - 03-20-2016, 04:45 AM
RE: Shipping Progress - by tllim - 03-20-2016, 09:25 AM
RE: Shipping Progress - by peterz - 03-20-2016, 02:07 PM
RE: Shipping Progress - by tllim - 03-20-2016, 03:25 PM
RE: Shipping Progress - by wlinville - 03-21-2016, 12:01 AM
RE: Shipping Progress - by gubaguba - 03-21-2016, 05:03 AM
RE: Shipping Progress - by jswizle9386 - 03-21-2016, 07:43 AM
RE: Shipping Progress - by tllim - 03-21-2016, 02:26 PM
RE: Shipping Progress - by g_t_j - 03-21-2016, 02:35 PM
RE: Shipping Progress - by thtroyer - 03-21-2016, 08:07 AM
RE: Shipping Progress - by tllim - 03-21-2016, 08:47 AM
RE: Shipping Progress - by TheMonkeyKing - 03-21-2016, 01:59 PM
RE: Shipping Progress - by tllim - 03-21-2016, 02:49 PM
RE: Shipping Progress - by g_t_j - 03-21-2016, 02:53 PM
RE: Shipping Progress - by TheMonkeyKing - 03-21-2016, 03:40 PM
RE: Shipping Progress - by jeffmc - 03-21-2016, 03:44 PM
RE: Shipping Progress - by nagmier - 03-21-2016, 06:18 PM
RE: Shipping Progress - by tllim - 03-21-2016, 06:43 PM
RE: Shipping Progress - by nagmier - 03-21-2016, 07:02 PM
RE: Shipping Progress - by tllim - 03-21-2016, 07:41 PM
RE: Shipping Progress - by g_t_j - 03-22-2016, 05:33 AM
RE: Shipping Progress - by pushpendrak - 03-21-2016, 08:55 PM
RE: Shipping Progress - by tllim - 03-21-2016, 09:20 PM
RE: Shipping Progress - by tllim - 03-22-2016, 12:41 AM
RE: Shipping Progress - by hrw - 03-22-2016, 11:53 AM
Shipping Progress - by eric2905 - 03-22-2016, 03:04 AM
RE: Shipping Progress - by Rainfox - 03-22-2016, 03:43 AM
RE: Shipping Progress - by Pepito95 - 03-22-2016, 05:09 AM
RE: Shipping Progress - by tllim - 03-22-2016, 08:02 AM
RE: Shipping Progress - by g_t_j - 03-22-2016, 08:30 AM
RE: Shipping Progress - by peterz - 03-22-2016, 09:25 AM
RE: Shipping Progress - by tllim - 03-22-2016, 09:43 AM
RE: Shipping Progress - by g_t_j - 03-22-2016, 01:52 PM
RE: Shipping Progress - by tllim - 03-22-2016, 02:54 PM
RE: Shipping Progress - by g_t_j - 03-22-2016, 03:07 PM
RE: Shipping Progress - by cholbi - 03-23-2016, 10:59 AM
Shipping Progress - by RaspiBit - 03-22-2016, 07:43 AM
RE: Shipping Progress - by harris - 03-22-2016, 07:53 AM
RE: Shipping Progress - by tllim - 03-22-2016, 08:29 AM
RE: Shipping Progress - by harris - 03-24-2016, 09:14 AM
RE: Shipping Progress - by harris - 03-30-2016, 06:32 AM
RE: Shipping Progress - by thtroyer - 03-22-2016, 08:25 AM
RE: Shipping Progress - by tllim - 03-22-2016, 08:32 AM
RE: Shipping Progress - by Rigor_M - 03-22-2016, 10:45 AM
RE: Shipping Progress - by tllim - 03-22-2016, 12:14 PM
RE: Shipping Progress - by jhgoodwin - 03-22-2016, 12:39 PM
RE: Shipping Progress - by peterz - 03-24-2016, 04:06 AM
RE: Shipping Progress - by tllim - 03-24-2016, 07:54 AM
RE: Shipping Progress - by TheMonkeyKing - 03-24-2016, 10:21 AM
RE: Shipping Progress - by thtroyer - 03-24-2016, 01:16 PM
RE: Shipping Progress - by psychedup - 03-24-2016, 02:29 PM
RE: Shipping Progress - by monty1 - 03-24-2016, 02:37 PM
RE: Shipping Progress - by pine.tree - 03-24-2016, 05:07 PM
RE: Shipping Progress - by TheMonkeyKing - 03-31-2016, 09:18 AM
RE: Shipping Progress - by gubaguba - 03-22-2016, 01:14 PM
RE: Shipping Progress - by amc2012 - 03-22-2016, 01:35 PM
RE: Shipping Progress - by yourhighpriestess - 03-22-2016, 02:30 PM
RE: Shipping Progress - by tllim - 03-22-2016, 04:04 PM
RE: Shipping Progress - by g_t_j - 03-22-2016, 04:22 PM
RE: Shipping Progress - by hrw - 03-23-2016, 12:31 AM
RE: Shipping Progress - by tllim - 03-23-2016, 12:52 AM
RE: Shipping Progress - by monsieurmarc - 03-22-2016, 02:31 PM
RE: Shipping Progress - by monty1 - 03-22-2016, 04:50 PM
RE: Shipping Progress - by tllim - 03-23-2016, 09:24 AM
RE: Shipping Progress - by monty1 - 03-23-2016, 10:41 AM
RE: Shipping Progress - by nick0318 - 03-22-2016, 05:27 PM
RE: Shipping Progress - by tllim - 03-22-2016, 09:43 PM
RE: Shipping Progress - by Faye - 03-22-2016, 10:14 PM
RE: Shipping Progress - by tllim - 03-22-2016, 10:38 PM
RE: Shipping Progress - by Faye - 03-22-2016, 10:43 PM
RE: Shipping Progress - by tllim - 03-22-2016, 11:07 PM
RE: Shipping Progress - by monsieurmarc - 03-23-2016, 05:38 AM
RE: Shipping Progress - by nagmier - 03-23-2016, 05:54 AM
RE: Shipping Progress - by monsieurmarc - 03-23-2016, 07:35 AM
RE: Shipping Progress - by Brianf - 03-23-2016, 09:37 AM
RE: Shipping Progress - by tllim - 03-23-2016, 10:32 AM
RE: Shipping Progress - by Severian - 03-23-2016, 04:37 PM
RE: Shipping Progress - by tllim - 03-23-2016, 04:45 PM
RE: Shipping Progress - by SkimMilk - 03-23-2016, 07:00 PM
RE: Shipping Progress - by tllim - 03-23-2016, 07:07 PM
RE: Shipping Progress - by SkimMilk - 03-23-2016, 07:09 PM
RE: Shipping Progress - by tllim - 03-23-2016, 07:34 PM
RE: Shipping Progress - by SkimMilk - 03-23-2016, 08:10 PM
RE: Shipping Progress - by Inuyasha - 03-24-2016, 07:17 AM
RE: Shipping Progress - by jmonteiro - 03-24-2016, 07:53 AM
RE: Shipping Progress - by birdcatx7 - 03-24-2016, 05:54 PM
Shipping Progress - by RaspiBit - 03-25-2016, 01:59 AM
RE: Shipping Progress - by tllim - 03-25-2016, 08:43 AM
RE: Shipping Progress - by jswizle9386 - 03-25-2016, 01:44 PM
RE: Shipping Progress - by tllim - 03-25-2016, 04:04 PM
RE: Shipping Progress - by hrw - 03-28-2016, 01:25 PM
RE: Shipping Progress - by tllim - 03-28-2016, 02:05 PM
RE: Shipping Progress - by Ghost - 03-28-2016, 03:02 PM
RE: Shipping Progress - by pine.tree - 03-28-2016, 03:51 PM
RE: Shipping Progress - by nagmier - 03-28-2016, 05:39 PM
RE: Shipping Progress - by TerryB - 03-25-2016, 02:58 AM
RE: Shipping Progress - by darhf - 03-25-2016, 04:36 AM
RE: Shipping Progress - by DrMeh - 03-25-2016, 03:33 PM
RE: Shipping Progress - by GoZone - 03-25-2016, 06:55 PM
RE: Shipping Progress - by pushpendrak - 03-25-2016, 11:07 PM
RE: Shipping Progress - by Onyvas - 03-26-2016, 06:11 AM
RE: Shipping Progress - by dabone - 03-26-2016, 10:57 AM
RE: Shipping Progress - by Ghost - 03-26-2016, 11:54 AM
RE: Shipping Progress - by Jschnee - 03-26-2016, 03:23 PM
RE: Shipping Progress - by pine.tree - 03-26-2016, 03:31 PM
RE: Shipping Progress - by dabone - 03-26-2016, 03:54 PM
RE: Shipping Progress - by drag00n - 03-26-2016, 04:30 PM
RE: Shipping Progress - by jswizle9386 - 03-26-2016, 05:42 PM
Shipping Progress - by devildog125 - 03-26-2016, 11:42 PM
Shipping Progress - by RaspiBit - 03-27-2016, 02:37 AM
RE: Shipping Progress - by komplike - 03-28-2016, 04:32 AM
RE: Shipping Progress - by Inuyasha - 03-28-2016, 05:15 AM
RE: Shipping Progress - by komplike - 03-28-2016, 05:40 AM
RE: Shipping Progress - by pine.tree - 03-28-2016, 07:05 AM
RE: Shipping Progress - by komplike - 03-28-2016, 08:03 AM
RE: Shipping Progress - by tllim - 03-28-2016, 12:44 PM
RE: Shipping Progress - by Ghost - 03-28-2016, 06:56 AM
RE: Shipping Progress - by benpope81 - 03-28-2016, 08:12 AM
RE: Shipping Progress - by pine.tree - 03-28-2016, 08:43 AM
RE: Shipping Progress - by komplike - 03-28-2016, 08:50 AM
RE: Shipping Progress - by pine.tree - 03-28-2016, 08:53 AM
RE: Shipping Progress - by komplike - 03-28-2016, 08:55 AM
RE: Shipping Progress - by pine.tree - 03-28-2016, 09:01 AM
RE: Shipping Progress - by hrw - 03-28-2016, 02:56 PM
RE: Shipping Progress - by SkimMilk - 03-28-2016, 07:21 PM
RE: Shipping Progress - by tllim - 03-28-2016, 11:14 PM
RE: Shipping Progress - by jswizle9386 - 03-29-2016, 12:00 AM
RE: Shipping Progress - by tllim - 03-29-2016, 12:57 AM
RE: Shipping Progress - by jswizle9386 - 03-29-2016, 10:51 AM
RE: Shipping Progress - by rbag4i5 - 03-29-2016, 02:38 AM
RE: Shipping Progress - by Tikimaster - 03-29-2016, 10:09 AM
RE: Shipping Progress - by pushpendrak - 03-29-2016, 01:44 AM
RE: Shipping Progress - by stephen fleming - 03-29-2016, 01:45 AM
RE: Shipping Progress - by Tarjei85 - 03-29-2016, 02:48 AM
RE: Shipping Progress - by Darkover - 03-29-2016, 07:55 AM
RE: Shipping Progress - by yusijs - 03-29-2016, 10:37 AM
RE: Shipping Progress - by mrgoose - 03-29-2016, 12:57 PM
Shipping Progress - by RaspiBit - 03-29-2016, 01:05 PM
RE: Shipping Progress - by hazerty - 03-29-2016, 01:41 PM
RE: Shipping Progress - by peterz - 03-29-2016, 02:00 PM
RE: Shipping Progress - by VeeKayB1 - 03-29-2016, 02:33 PM
RE: Shipping Progress - by Vairn - 03-29-2016, 06:44 PM
RE: Shipping Progress - by jswizle9386 - 03-29-2016, 09:14 PM
RE: Shipping Progress - by tllim - 03-30-2016, 01:24 AM
RE: Shipping Progress - by rbag4i5 - 03-30-2016, 01:28 AM
RE: Shipping Progress - by nick0318 - 03-29-2016, 09:54 PM
RE: Shipping Progress - by yusijs - 03-30-2016, 01:31 AM
RE: Shipping Progress - by pine.tree - 03-30-2016, 06:43 AM
RE: Shipping Progress - by harris - 03-30-2016, 06:51 AM
RE: Shipping Progress - by tllim - 03-30-2016, 09:52 AM
RE: Shipping Progress - by monty1 - 03-30-2016, 10:44 AM
RE: Shipping Progress - by pine.tree - 03-30-2016, 10:54 AM
RE: Shipping Progress - by monty1 - 03-30-2016, 12:36 PM
RE: Shipping Progress - by jswizle9386 - 03-30-2016, 02:57 PM
RE: Shipping Progress - by harris - 04-14-2016, 08:06 AM
RE: Shipping Progress - by pine.tree - 03-30-2016, 06:54 AM
RE: Shipping Progress - by monsieurmarc - 03-31-2016, 04:48 AM
RE: Shipping Progress - by macacob - 03-31-2016, 07:42 AM
RE: Shipping Progress - by pine.tree - 03-31-2016, 08:00 AM
RE: Shipping Progress - by pine.tree - 03-31-2016, 09:49 AM
RE: Shipping Progress - by TheMonkeyKing - 03-31-2016, 10:01 AM
RE: Shipping Progress - by philou - 03-31-2016, 10:30 AM
RE: Shipping Progress - by pine.tree - 03-31-2016, 10:37 AM
RE: Shipping Progress - by philou - 03-31-2016, 10:55 AM
RE: Shipping Progress - by pine.tree - 03-31-2016, 11:04 AM
RE: Shipping Progress - by philou - 04-01-2016, 10:02 AM
RE: Shipping Progress - by monsieurmarc - 03-31-2016, 12:46 PM
RE: Shipping Progress - by TheMonkeyKing - 03-31-2016, 01:10 PM
RE: Shipping Progress - by AstainHellbring - 03-31-2016, 07:26 PM
RE: Shipping Progress - by pine.tree - 03-31-2016, 07:36 PM
RE: Shipping Progress - by AstainHellbring - 03-31-2016, 08:02 PM
RE: Shipping Progress - by yusijs - 04-01-2016, 10:52 AM
RE: Shipping Progress - by jswizle9386 - 04-01-2016, 12:54 PM
RE: Shipping Progress - by tllim - 04-01-2016, 10:14 PM
RE: Shipping Progress - by yusijs - 04-01-2016, 11:07 PM
RE: Shipping Progress - by ViperVi - 04-01-2016, 09:20 AM
RE: Shipping Progress - by SnowLeopard - 04-17-2016, 02:52 AM
RE: Shipping Progress - by fneves - 04-01-2016, 09:38 AM
RE: Shipping Progress - by pine.tree - 04-01-2016, 01:14 PM
RE: Shipping Progress - by nick0318 - 04-01-2016, 01:18 PM
RE: Shipping Progress - by rakib-hasan - 04-01-2016, 01:23 PM
RE: Shipping Progress - by elnur - 04-01-2016, 02:35 PM
RE: Shipping Progress - by macacob - 04-01-2016, 02:49 PM
RE: Shipping Progress - by vsz85 - 04-02-2016, 12:00 AM
Shipping Progress - by eric2905 - 04-02-2016, 12:43 AM
RE: Shipping Progress - by pushpendrak - 04-02-2016, 01:06 AM
RE: Shipping Progress - by Tarjei85 - 04-02-2016, 02:35 AM
RE: Shipping Progress - by pine.tree - 04-02-2016, 06:03 AM
RE: Shipping Progress - by Harrisburg - 04-02-2016, 07:22 AM
RE: Shipping Progress - by HeadShot - 04-02-2016, 01:41 PM
RE: Shipping Progress - by Sumeet.GiLL - 04-02-2016, 09:13 AM
RE: Shipping Progress - by tllim - 04-02-2016, 02:10 PM
RE: Shipping Progress - by Sumeet.GiLL - 04-02-2016, 02:30 PM
RE: Shipping Progress - by tllim - 04-02-2016, 02:50 PM
RE: Shipping Progress - by g_t_j - 04-02-2016, 05:28 PM
RE: Shipping Progress - by Tikimaster - 04-02-2016, 11:29 AM
RE: Shipping Progress - by anexpert - 04-02-2016, 01:01 PM
RE: Shipping Progress - by g_t_j - 04-02-2016, 02:32 PM
RE: Shipping Progress - by Inuyasha - 04-02-2016, 02:39 PM
RE: Shipping Progress - by Sumeet.GiLL - 04-02-2016, 03:00 PM
RE: Shipping Progress - by Tikimaster - 04-02-2016, 03:10 PM
RE: Shipping Progress - by tllim - 04-03-2016, 02:25 PM
RE: Shipping Progress - by hazerty - 04-04-2016, 01:11 AM
RE: Shipping Progress - by nick0318 - 04-02-2016, 04:26 PM
RE: Shipping Progress - by tycoonbob - 04-02-2016, 09:54 PM
RE: Shipping Progress - by Ghost - 04-03-2016, 12:14 AM
RE: Shipping Progress - by MikeJewski - 04-03-2016, 08:10 AM
RE: Shipping Progress - by dabone - 04-03-2016, 01:46 PM
RE: Shipping Progress - by jswizle9386 - 04-04-2016, 10:03 AM
RE: Shipping Progress - by yusijs - 04-04-2016, 12:37 PM
RE: Shipping Progress - by TheMonkeyKing - 04-04-2016, 01:24 PM
RE: Shipping Progress - by Shady2tree - 04-04-2016, 01:35 PM
RE: Shipping Progress - by TheMonkeyKing - 04-05-2016, 02:00 PM
RE: Shipping Progress - by macacob - 04-08-2016, 11:39 AM
RE: Shipping Progress - by peterz - 04-08-2016, 11:47 AM
RE: Shipping Progress - by anexpert - 04-08-2016, 03:09 PM
RE: Shipping Progress - by g_t_j - 04-09-2016, 04:15 AM
RE: Shipping Progress - by TeaPack - 04-09-2016, 12:07 PM
RE: Shipping Progress - by g_t_j - 04-09-2016, 12:14 PM
RE: Shipping Progress - by TeaPack - 04-09-2016, 12:34 PM
RE: Shipping Progress - by jacky2008 - 04-10-2016, 08:24 PM
RE: Shipping Progress - by Brianf - 04-12-2016, 09:29 AM
RE: Shipping Progress - by tllim - 04-12-2016, 08:21 PM
RE: Shipping Progress - by g_t_j - 04-14-2016, 05:08 AM
RE: Shipping Progress - by hrw - 04-12-2016, 09:32 AM
RE: Shipping Progress - by rbag4i5 - 04-13-2016, 11:13 PM
RE: Shipping Progress - by tllim - 04-14-2016, 04:32 PM
RE: Shipping Progress - by dabone - 04-16-2016, 02:12 PM
RE: Shipping Progress - by pine.tree - 04-16-2016, 07:41 PM
RE: Shipping Progress - by Krinilssen - 04-17-2016, 12:25 AM
RE: Shipping Progress - by Bart333 - 04-17-2016, 01:14 PM
RE: Shipping Progress - by tllim - 04-18-2016, 09:53 AM
Shipping Progress - by SkimMilk - 04-17-2016, 06:29 PM
RE: Shipping Progress - by pushpendrak - 04-17-2016, 11:03 PM
RE: Shipping Progress - by macoco - 04-19-2016, 11:00 AM
RE: Shipping Progress - by UnixOutlaw - 04-18-2016, 12:35 AM
RE: Shipping Progress - by g_t_j - 04-18-2016, 09:59 AM
RE: Shipping Progress - by tllim - 04-19-2016, 03:42 PM
RE: Shipping Progress - by g_t_j - 04-19-2016, 06:57 PM
RE: Shipping Progress - by hrw - 04-20-2016, 02:45 PM
RE: Shipping Progress - by hrw - 04-19-2016, 11:32 AM
RE: Shipping Progress - by ViperVi - 04-19-2016, 02:15 PM
RE: Shipping Progress - by gordwait - 04-19-2016, 06:13 PM
RE: Shipping Progress - by tllim - 04-19-2016, 09:24 PM
Shipping Progress - by RaspiBit - 04-20-2016, 03:29 AM
RE: Shipping Progress - by tllim - 04-20-2016, 04:31 AM
RE: Shipping Progress - by amc2012 - 04-21-2016, 11:09 AM
RE: Shipping Progress - by Rigor_M - 04-20-2016, 09:05 AM
RE: Shipping Progress - by tllim - 04-21-2016, 04:10 PM
RE: Shipping Progress - by kannutti - 04-20-2016, 03:53 PM
RE: Shipping Progress - by nagmier - 04-20-2016, 06:41 PM
RE: Shipping Progress - by kannutti - 04-21-2016, 03:27 AM
RE: Shipping Progress - by kermit6672 - 04-21-2016, 12:23 PM
RE: Shipping Progress - by Shady2tree - 04-21-2016, 01:14 PM
RE: Shipping Progress - by pushpendrak - 04-21-2016, 09:02 PM
RE: Shipping Progress - by pJaSpeR - 04-22-2016, 03:19 AM
RE: Shipping Progress - by T3charmy - 04-26-2016, 09:35 AM
RE: Shipping Progress - by T3charmy - 04-27-2016, 12:59 PM
RE: Shipping Progress - by kannutti - 04-22-2016, 04:27 AM
RE: Shipping Progress - by Inuyasha - 04-22-2016, 05:09 AM
RE: Shipping Progress - by tllim - 04-22-2016, 06:33 AM
RE: Shipping Progress - by Inuyasha - 04-22-2016, 06:40 AM
RE: Shipping Progress - by moyaja - 04-22-2016, 09:21 AM
RE: Shipping Progress - by tllim - 04-22-2016, 04:33 PM
RE: Shipping Progress - by richc - 04-22-2016, 02:29 PM
Shipping Progress - by eric2905 - 04-24-2016, 02:14 AM
RE: Shipping Progress - by tllim - 04-24-2016, 03:02 AM
RE: Shipping Progress - by eric2905 - 04-24-2016, 04:40 AM
RE: Shipping Progress - by SnowLeopard - 04-25-2016, 12:55 AM
RE: Shipping Progress - by Tiszai Istvan - 04-25-2016, 07:16 AM
RE: Shipping Progress - by AA666 - 04-25-2016, 10:31 AM
RE: Shipping Progress - by Brianf - 04-26-2016, 07:28 AM
RE: Shipping Progress - by pine.tree - 04-26-2016, 07:40 AM
RE: Shipping Progress - by nagmier - 04-26-2016, 07:44 AM
RE: Shipping Progress - by Brianf - 04-26-2016, 07:56 AM
RE: Shipping Progress - by tllim - 04-26-2016, 02:03 PM
RE: Shipping Progress - by amc2012 - 04-27-2016, 01:34 PM
RE: Shipping Progress - by pine.tree - 04-26-2016, 08:15 AM
RE: Shipping Progress - by gubaguba - 04-26-2016, 01:02 PM
RE: Shipping Progress - by g_t_j - 04-26-2016, 03:11 PM
RE: Shipping Progress - by curiousgally - 04-26-2016, 10:21 PM
RE: Shipping Progress - by benpope81 - 04-27-2016, 08:59 AM
RE: Shipping Progress - by Faye - 04-27-2016, 09:22 AM
Shipping Progress - by eric2905 - 04-27-2016, 10:40 AM
RE: Shipping Progress - by Faye - 04-27-2016, 04:12 PM
RE: Shipping Progress - by kermit6672 - 04-27-2016, 04:45 PM
RE: Shipping Progress - by nagmier - 04-27-2016, 05:33 PM
RE: Shipping Progress - by kermit6672 - 04-27-2016, 05:45 PM
Shipping Progress - by SkimMilk - 04-27-2016, 06:19 PM
RE: Shipping Progress - by kermit6672 - 04-27-2016, 09:44 PM
RE: Shipping Progress - by KE4JGX - 04-27-2016, 07:48 PM
RE: Shipping Progress - by curiousgally - 04-27-2016, 09:54 PM
Shipping Progress - by devildog125 - 04-27-2016, 10:58 PM
RE: Shipping Progress - by RaspiBit - 04-28-2016, 05:39 PM
RE: Shipping Progress - by hrw - 04-29-2016, 01:49 AM
RE: Shipping Progress - by anexpert - 05-01-2016, 04:42 AM
RE: Shipping Progress - by tllim - 05-02-2016, 08:24 AM
RE: Shipping Progress - by peterz - 05-02-2016, 11:55 AM
RE: Shipping Progress - by prouser2 - 05-02-2016, 12:38 PM
RE: Shipping Progress - by tllim - 05-02-2016, 12:52 PM
RE: Shipping Progress - by tllim - 05-02-2016, 07:03 PM
RE: Shipping Progress - by dimia - 05-12-2016, 12:42 AM
RE: Shipping Progress - by macacob - 05-12-2016, 07:53 AM
RE: Shipping Progress - by Tiszai Istvan - 05-02-2016, 03:08 AM
RE: Shipping Progress - by tllim - 05-02-2016, 08:26 AM
RE: Shipping Progress - by pineresearch - 05-02-2016, 08:50 AM
RE: Shipping Progress - by pine.tree - 05-02-2016, 08:55 AM
RE: Shipping Progress - by pineresearch - 05-02-2016, 08:59 AM
RE: Shipping Progress - by pine.tree - 05-02-2016, 09:05 AM
RE: Shipping Progress - by pineresearch - 05-02-2016, 09:18 AM
RE: Shipping Progress - by Waterside - 05-04-2016, 09:08 PM
RE: Shipping Progress - by g_t_j - 05-06-2016, 06:20 AM
RE: Shipping Progress - by pine.tree - 05-02-2016, 09:51 AM
Shipping Progress - by SkimMilk - 05-02-2016, 10:54 AM
RE: Shipping Progress - by blktiger - 05-02-2016, 02:33 PM
RE: Shipping Progress - by howardsternisbatman - 05-02-2016, 04:32 PM
RE: Shipping Progress - by tllim - 05-02-2016, 07:06 PM
RE: Shipping Progress - by UnixOutlaw - 05-02-2016, 07:53 PM
RE: Shipping Progress - by tllim - 05-02-2016, 11:36 PM
RE: Shipping Progress - by UnixOutlaw - 05-10-2016, 01:53 AM
RE: Shipping Progress - by tllim - 05-10-2016, 08:25 AM
RE: Shipping Progress - by cchwann - 05-02-2016, 10:29 PM
RE: Shipping Progress - by tllim - 05-02-2016, 11:37 PM
RE: Shipping Progress - by cchwann - 05-03-2016, 12:27 AM
Shipping Progress - by SkimMilk - 05-03-2016, 04:08 AM
Shipping Progress - by RaspiBit - 05-03-2016, 04:19 AM
RE: Shipping Progress - by benpope81 - 05-03-2016, 05:07 AM
RE: Shipping Progress - by benpope81 - 05-08-2016, 11:06 PM
RE: Shipping Progress - by Sumeet.GiLL - 05-03-2016, 09:47 AM
RE: Shipping Progress - by pineresearch - 05-03-2016, 09:52 AM
RE: Shipping Progress - by queonda - 05-03-2016, 10:39 AM
RE: Shipping Progress - by rahlquist - 05-03-2016, 10:58 AM
RE: Shipping Progress - by Ghost - 05-03-2016, 10:47 AM
Shipping Progress - by devildog125 - 05-03-2016, 01:09 PM
RE: Shipping Progress - by rahlquist - 05-03-2016, 01:28 PM
RE: Shipping Progress - by devildog125 - 05-03-2016, 01:35 PM
RE: Shipping Progress - by rahlquist - 05-03-2016, 01:47 PM
RE: Shipping Progress - by devildog125 - 05-03-2016, 01:57 PM
RE: Shipping Progress - by rahlquist - 05-03-2016, 02:08 PM
RE: Shipping Progress - by g_t_j - 05-03-2016, 01:51 PM
RE: Shipping Progress - by wenderfit - 05-03-2016, 02:26 PM
RE: Shipping Progress - by SkimMilk - 05-04-2016, 08:06 PM
RE: Shipping Progress - by cryptoknight - 05-04-2016, 08:42 AM
RE: Shipping Progress - by pine.tree - 05-04-2016, 09:13 AM
RE: Shipping Progress - by macacob - 05-04-2016, 02:22 PM
RE: Shipping Progress - by macacob - 05-16-2016, 02:31 PM
RE: Shipping Progress - by amunro - 05-04-2016, 03:18 PM
RE: Shipping Progress - by wenderfit - 05-04-2016, 11:06 PM
Shipping Progress - by RaspiBit - 05-05-2016, 10:46 PM
RE: Shipping Progress - by Inuyasha - 05-06-2016, 04:58 AM
RE: Shipping Progress - by clarkss12 - 05-06-2016, 05:11 AM
RE: Shipping Progress - by pine.tree - 05-06-2016, 08:19 AM
RE: Shipping Progress - by Sumeet.GiLL - 05-06-2016, 11:01 AM
RE: Shipping Progress - by Ghost - 05-06-2016, 11:28 AM
RE: Shipping Progress - by nagmier - 05-06-2016, 05:07 PM
RE: Shipping Progress - by Waterside - 05-06-2016, 05:15 PM
RE: Shipping Progress - by g_t_j - 05-07-2016, 02:31 AM
RE: Shipping Progress - by balaji_pitchumani - 05-06-2016, 07:21 PM
RE: Shipping Progress - by rogerthn - 05-07-2016, 02:48 AM
RE: Shipping Progress - by nagmier - 05-07-2016, 10:04 AM
RE: Shipping Progress - by Tikimaster - 05-08-2016, 07:55 PM
RE: Shipping Progress - by tllim - 05-09-2016, 09:29 PM
RE: Shipping Progress - by Tikimaster - 05-11-2016, 02:39 PM
RE: Shipping Progress - by colinxu - 05-08-2016, 08:13 PM
RE: Shipping Progress - by balaji_pitchumani - 05-08-2016, 11:45 PM
RE: Shipping Progress - by bonterra - 05-09-2016, 04:54 AM
RE: Shipping Progress - by tllim - 05-09-2016, 09:03 AM
RE: Shipping Progress - by TheMonkeyKing - 05-09-2016, 09:26 AM
RE: Shipping Progress - by bonterra - 05-09-2016, 01:10 PM
RE: Shipping Progress - by nagmier - 05-09-2016, 07:01 PM
RE: Shipping Progress - by bonterra - 05-09-2016, 11:50 PM
RE: Shipping Progress - by TheMonkeyKing - 05-11-2016, 02:57 PM
RE: Shipping Progress - by Inuyasha - 05-10-2016, 08:34 AM
RE: Shipping Progress - by g_t_j - 05-10-2016, 09:13 AM
RE: Shipping Progress - by ktiedt - 05-10-2016, 11:17 AM
RE: Shipping Progress - by Inuyasha - 05-10-2016, 11:37 AM
RE: Shipping Progress - by g_t_j - 05-10-2016, 11:49 AM
RE: Shipping Progress - by bonterra - 05-11-2016, 01:20 AM
RE: Shipping Progress - by benpope81 - 05-12-2016, 08:45 AM
Shipping Progress - by bonterra - 05-12-2016, 01:31 PM
RE: Shipping Progress - by amc2012 - 05-12-2016, 01:54 PM
RE: Shipping Progress - by macacob - 05-12-2016, 02:03 PM
RE: Shipping Progress - by Sagecoast - 05-12-2016, 04:58 PM
RE: Shipping Progress - by Waterside - 05-12-2016, 10:34 PM
RE: Shipping Progress - by amc2012 - 05-13-2016, 01:51 PM
RE: Shipping Progress - by bonterra - 05-13-2016, 02:32 AM
RE: Shipping Progress - by Montala - 05-13-2016, 04:20 AM
RE: Shipping Progress - by gubaguba - 05-13-2016, 06:37 AM
RE: Shipping Progress - by Tikimaster - 05-13-2016, 09:22 PM
RE: Shipping Progress - by amc2012 - 05-16-2016, 02:17 PM
RE: Shipping Progress - by wboson - 05-14-2016, 10:53 PM
RE: Shipping Progress - by g_t_j - 05-16-2016, 02:56 PM
RE: Shipping Progress - by Montala - 05-16-2016, 03:07 PM
RE: Shipping Progress - by g_t_j - 05-16-2016, 03:13 PM
RE: Shipping Progress - by Montala - 05-16-2016, 03:37 PM
RE: Shipping Progress - by macacob - 05-17-2016, 08:18 AM
RE: Shipping Progress - by amc2012 - 05-17-2016, 03:02 PM
RE: Shipping Progress - by Montala - 05-17-2016, 03:14 PM
RE: Shipping Progress - by Tikimaster - 05-17-2016, 03:22 PM
RE: Shipping Progress - by bonterra - 05-18-2016, 12:09 AM
RE: Shipping Progress - by tllim - 05-18-2016, 09:52 AM
Shipping Progress - by SkimMilk - 05-17-2016, 06:36 PM
RE: Shipping Progress - by ktiedt - 05-18-2016, 10:40 AM
RE: Shipping Progress - by tllim - 05-18-2016, 11:34 AM
RE: Shipping Progress - by ktiedt - 05-18-2016, 01:12 PM
RE: Shipping Progress - by DeepBlu - 05-18-2016, 10:44 AM
RE: Shipping Progress - by ktiedt - 05-18-2016, 11:22 AM
RE: Shipping Progress - by tllim - 05-18-2016, 11:43 AM
RE: Shipping Progress - by tllim - 05-18-2016, 11:36 AM
RE: Shipping Progress - by Montala - 05-18-2016, 01:12 PM
RE: Shipping Progress - by macacob - 05-19-2016, 04:46 AM
RE: Shipping Progress - by Montala - 05-19-2016, 05:30 AM
RE: Shipping Progress - by macacob - 05-19-2016, 07:39 AM
RE: Shipping Progress - by Montala - 05-19-2016, 08:07 AM
RE: Shipping Progress - by macacob - 05-19-2016, 10:24 AM
RE: Shipping Progress - by Montala - 05-19-2016, 11:24 AM
RE: Shipping Progress - by Rigor_M - 05-20-2016, 08:29 AM
RE: Shipping Progress - by tllim - 05-20-2016, 11:00 AM
RE: Shipping Progress - by Rigor_M - 05-20-2016, 11:11 AM
RE: Shipping Progress - by tllim - 05-20-2016, 11:17 AM
RE: Shipping Progress - by blktiger - 05-22-2016, 01:03 PM
RE: Shipping Progress - by mrgoose - 05-20-2016, 09:41 AM
RE: Shipping Progress - by tllim - 05-20-2016, 10:51 AM
RE: Shipping Progress - by tllim - 05-20-2016, 11:04 AM
RE: Shipping Progress - by Montala - 05-20-2016, 11:13 AM
RE: Shipping Progress - by tllim - 05-20-2016, 11:26 AM
RE: Shipping Progress - by Montala - 05-20-2016, 11:33 AM
RE: Shipping Progress - by tllim - 05-20-2016, 11:43 AM
Shipping Progress - by bonterra - 05-20-2016, 12:25 PM
RE: Shipping Progress - by anexpert - 05-21-2016, 12:31 AM
RE: Shipping Progress - by Slydawgg - 05-21-2016, 10:15 PM
RE: Shipping Progress - by mFinnholm - 05-23-2016, 04:01 AM
RE: Shipping Progress - by Namlehse - 05-23-2016, 10:07 AM
RE: Shipping Progress - by pine.tree - 05-23-2016, 10:21 AM
Shipping Progress - by mFinnholm - 05-23-2016, 02:25 PM
RE: Shipping Progress - by DrMeh - 05-23-2016, 08:12 PM
RE: Shipping Progress - by aegiap - 05-24-2016, 12:26 AM
RE: Shipping Progress - by gbjensen - 05-24-2016, 03:32 AM
RE: Shipping Progress - by Spaghetti Monster - 05-24-2016, 10:05 AM
RE: Shipping Progress - by Bart333 - 05-24-2016, 03:46 AM
RE: Shipping Progress - by tllim - 05-24-2016, 10:57 AM
RE: Shipping Progress - by Tikimaster - 05-24-2016, 11:51 AM
RE: Shipping Progress - by nagmier - 05-24-2016, 12:20 PM
RE: Shipping Progress - by pine.tree - 05-24-2016, 03:26 PM
RE: Shipping Progress - by Tikimaster - 05-24-2016, 05:32 PM
RE: Shipping Progress - by clarkss12 - 05-24-2016, 12:30 PM
RE: Shipping Progress - by g_t_j - 05-24-2016, 01:27 PM
RE: Shipping Progress - by Montala - 05-24-2016, 03:07 PM
RE: Shipping Progress - by g_t_j - 05-25-2016, 09:07 AM
RE: Shipping Progress - by jtgiroux - 05-24-2016, 05:34 PM
RE: Shipping Progress - by Rigor_M - 05-25-2016, 05:58 AM
RE: Shipping Progress - by pine.tree - 05-25-2016, 06:47 AM
Shipping Progress - by bonterra - 05-24-2016, 11:55 PM
RE: Shipping Progress - by kaiser - 05-25-2016, 07:43 AM
RE: Shipping Progress - by amc2012 - 05-25-2016, 09:13 AM
RE: Shipping Progress - by jtgiroux - 05-29-2016, 02:07 PM
RE: Shipping Progress - by montero65 - 05-25-2016, 03:05 PM
RE: Shipping Progress - by hatman28 - 05-25-2016, 11:33 PM
RE: Shipping Progress - by gbjensen - 05-26-2016, 06:37 AM
RE: Shipping Progress - by gbjensen - 06-06-2016, 12:21 AM
RE: Shipping Progress - by gbjensen - 06-06-2016, 02:50 AM
RE: Shipping Progress - by hatman28 - 06-10-2016, 01:33 AM
RE: Shipping Progress - by Montala - 05-26-2016, 01:33 AM
RE: Shipping Progress - by Tikimaster - 05-26-2016, 05:35 AM
RE: Shipping Progress - by Montala - 05-26-2016, 07:02 AM
RE: Shipping Progress - by smokinimages - 05-26-2016, 01:39 AM
RE: Shipping Progress - by burn6010 - 05-26-2016, 08:23 AM
RE: Shipping Progress - by montero65 - 05-26-2016, 10:42 AM
RE: Shipping Progress - by hatman28 - 05-26-2016, 11:25 PM
Shipping Progress - by mFinnholm - 05-26-2016, 11:27 PM
RE: Shipping Progress - by RichT - 05-27-2016, 10:40 AM
RE: Shipping Progress - by TheMonkeyKing - 05-27-2016, 11:58 AM
RE: Shipping Progress - by burn6010 - 05-27-2016, 01:58 PM
RE: Shipping Progress - by TheMonkeyKing - 05-27-2016, 02:53 PM
RE: Shipping Progress - by Montala - 05-27-2016, 03:45 PM
RE: Shipping Progress - by bonterra - 05-28-2016, 02:58 AM
RE: Shipping Progress - by phbosco - 05-29-2016, 08:43 PM
RE: Shipping Progress - by bonterra - 05-30-2016, 01:50 AM
RE: Shipping Progress - by phbosco - 05-30-2016, 07:26 PM
RE: Shipping Progress - by dkryder - 05-30-2016, 08:42 AM
RE: Shipping Progress - by Bart333 - 05-30-2016, 10:40 AM
Shipping Progress - by mFinnholm - 05-30-2016, 10:41 AM
RE: Shipping Progress - by kflorek46 - 05-30-2016, 06:39 PM
RE: Shipping Progress - by Russia - 06-01-2016, 02:21 AM
RE: Shipping Progress - by vlzinch - 06-01-2016, 03:43 AM
RE: Shipping Progress - by pfeerick - 06-01-2016, 04:13 AM
RE: Shipping Progress - by vlzinch - 06-01-2016, 05:59 AM
RE: Shipping Progress - by MobileFusion - 06-01-2016, 04:50 AM
RE: Shipping Progress - by benpope81 - 06-01-2016, 09:13 AM
RE: Shipping Progress - by MobileFusion - 06-02-2016, 08:50 AM
RE: Shipping Progress - by mFinnholm - 06-01-2016, 11:33 PM
RE: Shipping Progress - by TheMonkeyKing - 06-02-2016, 08:49 AM
RE: Shipping Progress - by montero65 - 06-03-2016, 06:46 AM
RE: Shipping Progress - by kflorek46 - 06-04-2016, 11:48 AM
RE: Shipping Progress - by RichT - 06-04-2016, 11:56 AM
RE: Shipping Progress - by Bart333 - 06-04-2016, 05:18 PM
RE: Shipping Progress - by tllim - 06-04-2016, 07:09 PM
RE: Shipping Progress - by montero65 - 06-04-2016, 08:06 PM
RE: Shipping Progress - by Tikimaster - 06-05-2016, 11:44 AM
RE: Shipping Progress - by dkryder - 06-05-2016, 07:10 AM
RE: Shipping Progress - by bonterra - 06-05-2016, 11:43 AM
RE: Shipping Progress - by ubuntuGuy - 06-06-2016, 06:08 AM
RE: Shipping Progress - by birdcatx7 - 06-06-2016, 11:20 AM
RE: Shipping Progress - by JulianM - 06-06-2016, 12:22 PM
RE: Shipping Progress - by RichT - 06-06-2016, 12:59 PM
RE: Shipping Progress - by JulianM - 06-06-2016, 01:04 PM
RE: Shipping Progress - by TheMonkeyKing - 06-06-2016, 01:21 PM
RE: Shipping Progress - by montero65 - 06-06-2016, 01:46 PM
RE: Shipping Progress - by rowy - 06-06-2016, 02:08 PM
RE: Shipping Progress - by Bart333 - 06-07-2016, 12:06 PM
RE: Shipping Progress - by MikeJewski - 06-07-2016, 07:21 AM
RE: Shipping Progress - by peterz - 06-07-2016, 12:42 PM
RE: Shipping Progress - by kflorek46 - 06-07-2016, 07:48 PM
RE: Shipping Progress - by tllim - 06-21-2016, 08:40 AM
RE: Shipping Progress - by montero65 - 06-07-2016, 07:33 AM
RE: Shipping Progress - by Montala - 06-07-2016, 04:00 PM
RE: Shipping Progress - by bonterra - 06-08-2016, 12:27 AM
RE: Shipping Progress - by Montala - 06-08-2016, 02:49 AM
RE: Shipping Progress - by janeku - 06-08-2016, 02:21 PM
RE: Shipping Progress - by Tikimaster - 06-08-2016, 04:19 PM
RE: Shipping Progress - by richc - 06-09-2016, 09:34 AM
RE: Shipping Progress - by Tikimaster - 06-09-2016, 11:26 AM
RE: Shipping Progress - by RichT - 06-09-2016, 11:39 AM
RE: Shipping Progress - by Tikimaster - 06-09-2016, 03:01 PM
RE: Shipping Progress - by birdcatx7 - 06-09-2016, 01:38 PM
Shipping Progress - by bonterra - 06-09-2016, 02:40 PM
RE: Shipping Progress - by TheMonkeyKing - 06-10-2016, 08:27 AM
RE: Shipping Progress - by birdcatx7 - 06-10-2016, 11:07 AM
RE: Shipping Progress - by tllim - 06-10-2016, 05:40 PM
RE: Shipping Progress - by tllim - 06-10-2016, 05:41 PM
RE: Shipping Progress - by Tikimaster - 06-11-2016, 10:37 PM
RE: Shipping Progress - by tllim - 06-14-2016, 09:56 PM
RE: Shipping Progress - by mFinnholm - 06-13-2016, 12:13 AM
RE: Shipping Progress - by florevillepine - 06-13-2016, 08:48 AM
RE: Shipping Progress - by rikkyrik - 06-13-2016, 04:17 PM
RE: Shipping Progress - by tllim - 06-13-2016, 04:51 PM
RE: Shipping Progress - by rikkyrik - 06-15-2016, 11:41 AM
RE: Shipping Progress - by tllim - 06-21-2016, 08:22 AM
RE: Shipping Progress - by rikkyrik - 06-21-2016, 04:35 PM
RE: Shipping Progress - by RichT - 06-10-2016, 12:56 PM
RE: Shipping Progress - by lospinos - 06-10-2016, 07:30 PM
RE: Shipping Progress - by hatman28 - 06-10-2016, 11:42 PM
RE: Shipping Progress - by GoingPostal13 - 06-13-2016, 03:43 AM
RE: Shipping Progress - by Russia - 06-13-2016, 03:46 AM
RE: Shipping Progress - by amc2012 - 06-15-2016, 10:10 AM
RE: Shipping Progress - by AVL2016 - 06-13-2016, 04:49 PM
RE: Shipping Progress - by Cyrel - 06-13-2016, 05:28 PM
RE: Shipping Progress - by hatman28 - 06-13-2016, 11:07 PM
RE: Shipping Progress - by mFinnholm - 06-14-2016, 08:19 AM
RE: Shipping Progress - by nazrinkooy - 06-14-2016, 01:26 AM
RE: Shipping Progress - by birdcatx7 - 06-14-2016, 07:31 AM
RE: Shipping Progress - by tllim - 06-21-2016, 07:08 AM
RE: Shipping Progress - by tllim - 06-21-2016, 07:09 AM
RE: Shipping Progress - by birdcatx7 - 06-21-2016, 10:16 AM
RE: Shipping Progress - by montero65 - 06-14-2016, 09:26 AM
RE: Shipping Progress - by tllim - 06-14-2016, 04:38 PM
RE: Shipping Progress - by janeku - 06-14-2016, 02:18 PM
RE: Shipping Progress - by tllim - 06-14-2016, 04:40 PM
RE: Shipping Progress - by blakeslade - 06-15-2016, 06:15 PM
RE: Shipping Progress - by tllim - 06-16-2016, 06:44 AM
RE: Shipping Progress - by clarkss12 - 06-14-2016, 06:50 PM
RE: Shipping Progress - by tllim - 06-14-2016, 08:52 PM
RE: Shipping Progress - by blktiger - 06-14-2016, 08:24 PM
RE: Shipping Progress - by tllim - 06-14-2016, 08:53 PM
RE: Shipping Progress - by blktiger - 06-14-2016, 09:46 PM
RE: Shipping Progress - by tllim - 06-14-2016, 09:51 PM
RE: Shipping Progress - by blktiger - 06-17-2016, 06:49 AM
RE: Shipping Progress - by tllim - 06-17-2016, 04:01 PM
RE: Shipping Progress - by moyaja - 06-18-2016, 10:08 AM
RE: Shipping Progress - by tllim - 06-18-2016, 04:46 PM
RE: Shipping Progress - by blktiger - 06-19-2016, 02:13 PM
RE: Shipping Progress - by tllim - 06-19-2016, 05:49 PM
RE: Shipping Progress - by mFinnholm - 06-14-2016, 10:02 PM
RE: Shipping Progress - by nazrinkooy - 06-14-2016, 11:12 PM
RE: Shipping Progress - by tllim - 06-24-2016, 02:34 AM
RE: Shipping Progress - by tllim - 06-26-2016, 08:38 PM
RE: Shipping Progress - by Renshai - 06-15-2016, 02:17 AM
RE: Shipping Progress - by tllim - 06-28-2016, 02:39 AM
RE: Shipping Progress - by tllim - 06-28-2016, 03:06 AM
RE: Shipping Progress - by asuras - 06-15-2016, 04:42 AM
RE: Shipping Progress - by Swartz05 - 06-15-2016, 09:18 AM
RE: Shipping Progress - by montero65 - 06-15-2016, 09:34 AM
RE: Shipping Progress - by Swartz05 - 06-15-2016, 12:24 PM
RE: Shipping Progress - by peterz - 06-15-2016, 02:11 PM
RE: Shipping Progress - by tllim - 06-16-2016, 06:48 AM
RE: Shipping Progress - by peterz - 07-03-2016, 02:47 AM
RE: Shipping Progress - by tllim - 06-16-2016, 06:51 AM
RE: Shipping Progress - by montero65 - 06-15-2016, 12:41 PM
RE: Shipping Progress - by Ghost - 06-15-2016, 12:47 PM
RE: Shipping Progress - by montero65 - 06-15-2016, 12:58 PM
RE: Shipping Progress - by Joey716 - 06-15-2016, 01:19 PM
RE: Shipping Progress - by tllim - 06-21-2016, 08:30 AM
RE: Shipping Progress - by Joey716 - 06-21-2016, 08:35 AM
RE: Shipping Progress - by TheMonkeyKing - 06-15-2016, 04:30 PM
RE: Shipping Progress - by tllim - 06-16-2016, 06:50 AM
RE: Shipping Progress - by mike in mich - 06-15-2016, 10:03 PM
RE: Shipping Progress - by tllim - 06-16-2016, 06:49 AM
RE: Shipping Progress - by mike in mich - 06-23-2016, 06:47 PM
RE: Shipping Progress - by tllim - 06-24-2016, 02:13 AM
RE: Shipping Progress - by mike in mich - 06-24-2016, 04:46 PM
RE: Shipping Progress - by Hartza - 06-16-2016, 07:32 AM
RE: Shipping Progress - by Hartza - 06-22-2016, 03:17 PM
RE: Shipping Progress - by tllim - 06-22-2016, 04:05 PM
RE: Shipping Progress - by tllim - 07-03-2016, 03:53 PM
RE: Shipping Progress - by Hartza - 07-06-2016, 12:12 AM
RE: Shipping Progress - by Eole - 06-16-2016, 07:39 AM
RE: Shipping Progress - by florevillepine - 06-16-2016, 02:52 PM
RE: Shipping Progress - by rowy - 06-16-2016, 04:00 PM
RE: Shipping Progress - by MrWizerd - 06-16-2016, 05:21 PM
RE: Shipping Progress - by wesk - 06-16-2016, 08:27 PM
RE: Shipping Progress - by MrWizerd - 06-17-2016, 01:30 AM
RE: Shipping Progress - by wesk - 06-20-2016, 01:21 PM
RE: Shipping Progress - by SirLenuxx - 06-17-2016, 01:59 AM
RE: Shipping Progress - by MrWizerd - 06-17-2016, 02:35 AM
RE: Shipping Progress - by dkryder - 06-17-2016, 04:31 AM
RE: Shipping Progress - by Pim9001 - 06-18-2016, 07:31 AM
RE: Shipping Progress - by tllim - 06-18-2016, 04:39 PM
RE: Shipping Progress - by lukebamar - 06-19-2016, 10:05 AM
RE: Shipping Progress - by tllim - 06-19-2016, 05:47 PM
RE: Shipping Progress - by lukebamar - 06-26-2016, 07:03 AM
RE: Shipping Progress - by tllim - 06-26-2016, 07:58 PM
RE: Shipping Progress - by tllim - 06-26-2016, 08:34 PM
RE: Shipping Progress - by lukebamar - 06-27-2016, 01:52 PM
RE: Shipping Progress - by neo - 06-19-2016, 10:00 PM
RE: Shipping Progress - by tllim - 06-20-2016, 06:10 PM
RE: Shipping Progress - by tllim - 06-21-2016, 08:58 AM
RE: Shipping Progress - by neo - 06-28-2016, 02:23 AM
RE: Shipping Progress - by neo - 07-03-2016, 12:07 AM
RE: Shipping Progress - by tatopillo - 06-20-2016, 05:51 AM
RE: Shipping Progress - by tllim - 06-20-2016, 06:12 PM
RE: Shipping Progress - by asuras - 06-21-2016, 03:52 AM
RE: Shipping Progress - by tllim - 06-21-2016, 07:04 AM
RE: Shipping Progress - by tllim - 06-26-2016, 08:43 PM
RE: Shipping Progress - by tllim - 06-28-2016, 03:04 AM
RE: Shipping Progress - by tllim - 06-21-2016, 04:31 PM
RE: Shipping Progress - by Linux Runner - 06-20-2016, 10:53 AM
RE: Shipping Progress - by montero65 - 06-20-2016, 11:09 AM
RE: Shipping Progress - by tllim - 06-20-2016, 06:19 PM
RE: Shipping Progress - by Rigor_M - 06-20-2016, 11:33 AM
RE: Shipping Progress - by tllim - 06-20-2016, 06:20 PM
RE: Shipping Progress - by prouser2 - 06-20-2016, 01:24 PM
RE: Shipping Progress - by tllim - 06-20-2016, 06:24 PM
RE: Shipping Progress - by prouser2 - 06-21-2016, 06:25 AM
RE: Shipping Progress - by tllim - 07-03-2016, 03:11 PM
Shipping Progress - by hypnopooper - 07-03-2016, 03:28 PM
RE: Shipping Progress - by blktiger - 06-20-2016, 07:18 PM
RE: Shipping Progress - by Rigor_M - 06-21-2016, 09:03 AM
RE: Shipping Progress - by tllim - 06-21-2016, 04:22 PM
RE: Shipping Progress - by Rigor_M - 06-22-2016, 05:52 AM
RE: Shipping Progress - by tllim - 06-22-2016, 04:04 PM
RE: Shipping Progress - by Tikimaster - 06-22-2016, 11:17 AM
RE: Shipping Progress - by tllim - 06-22-2016, 04:13 PM
RE: Shipping Progress - by hazerty - 06-21-2016, 09:10 AM
RE: Shipping Progress - by pvelyk - 06-21-2016, 09:31 AM
RE: Shipping Progress - by pvelyk - 06-22-2016, 05:13 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:29 PM
RE: Shipping Progress - by pvelyk - 06-27-2016, 06:05 AM
RE: Shipping Progress - by curtislau - 06-21-2016, 10:46 AM
RE: Shipping Progress - by tllim - 06-21-2016, 04:24 PM
RE: Shipping Progress - by curtislau - 06-28-2016, 10:53 AM
RE: Shipping Progress - by tllim - 06-28-2016, 08:41 PM
RE: Shipping Progress - by pinkelephants - 06-21-2016, 11:36 AM
RE: Shipping Progress - by tllim - 06-21-2016, 04:23 PM
RE: Shipping Progress - by pinkelephants - 06-21-2016, 04:54 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:26 PM
RE: Shipping Progress - by pinkelephants - 06-27-2016, 07:56 AM
RE: Shipping Progress - by TheMonkeyKing - 06-21-2016, 03:32 PM
RE: Shipping Progress - by ligourney - 06-21-2016, 06:34 PM
RE: Shipping Progress - by tllim - 06-22-2016, 05:02 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:43 PM
RE: Shipping Progress - by ligourney - 06-26-2016, 10:53 PM
RE: Shipping Progress - by ligourney - 07-01-2016, 05:38 PM
RE: Shipping Progress - by ligourney - 07-03-2016, 05:35 PM
RE: Shipping Progress - by tllim - 07-04-2016, 05:39 PM
RE: Shipping Progress - by wesk - 07-04-2016, 10:09 PM
RE: Shipping Progress - by tllim - 07-05-2016, 09:45 PM
RE: Shipping Progress - by ligourney - 07-06-2016, 05:57 PM
RE: Shipping Progress - by blackt1ger - 06-21-2016, 07:01 PM
RE: Shipping Progress - by tllim - 06-22-2016, 05:05 PM
RE: Shipping Progress - by blackt1ger - 06-22-2016, 05:14 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:45 PM
RE: Shipping Progress - by sleeektoy - 06-21-2016, 07:31 PM
RE: Shipping Progress - by tllim - 06-22-2016, 05:06 PM
RE: Shipping Progress - by sleeektoy - 07-03-2016, 05:38 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:47 PM
RE: Shipping Progress - by nonmindo - 06-21-2016, 10:01 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:41 PM
RE: Shipping Progress - by CanadianIceTech - 06-21-2016, 11:21 PM
RE: Shipping Progress - by tllim - 06-22-2016, 05:10 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:49 PM
RE: Shipping Progress - by CanadianIceTech - 06-26-2016, 11:30 PM
RE: Shipping Progress - by NeoDrakkon - 06-22-2016, 02:10 AM
RE: Shipping Progress - by tllim - 06-22-2016, 05:12 PM
RE: Shipping Progress - by wesk - 06-22-2016, 09:16 PM
RE: Shipping Progress - by tllim - 06-24-2016, 02:20 AM
RE: Shipping Progress - by wesk - 06-24-2016, 07:14 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:50 PM
RE: Shipping Progress - by Kickro - 06-22-2016, 02:23 AM
RE: Shipping Progress - by tllim - 06-26-2016, 10:53 PM
RE: Shipping Progress - by agback - 06-22-2016, 02:53 AM
RE: Shipping Progress - by tllim - 06-22-2016, 05:11 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:54 PM
RE: Shipping Progress - by JulianM - 06-22-2016, 03:02 AM
RE: Shipping Progress - by tllim - 06-22-2016, 04:22 PM
RE: Shipping Progress - by JulianM - 06-23-2016, 03:40 AM
RE: Shipping Progress - by kourai - 06-22-2016, 03:57 AM
RE: Shipping Progress - by tllim - 06-22-2016, 04:27 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:36 PM
RE: Shipping Progress - by kourai - 07-11-2016, 03:52 AM
RE: Shipping Progress - by tllim - 07-14-2016, 06:06 PM
RE: Shipping Progress - by clarkss12 - 06-22-2016, 08:31 AM
RE: Shipping Progress - by tllim - 06-22-2016, 04:29 PM
RE: Shipping Progress - by tllim - 06-22-2016, 04:31 PM
RE: Shipping Progress - by florevillepine - 06-22-2016, 12:20 PM
RE: Shipping Progress - by tllim - 06-22-2016, 04:07 PM
RE: Shipping Progress - by tllim - 06-24-2016, 02:01 AM
RE: Shipping Progress - by Linux Runner - 06-22-2016, 02:50 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:31 PM
RE: Shipping Progress - by Linux Runner - 06-27-2016, 10:10 AM
RE: Shipping Progress - by Linux Runner - 06-30-2016, 05:20 PM
RE: Shipping Progress - by mattsoftware - 06-22-2016, 05:09 PM
RE: Shipping Progress - by tllim - 06-26-2016, 10:56 PM
RE: Shipping Progress - by mattsoftware - 06-27-2016, 04:17 PM
RE: Shipping Progress - by kb1qzh - 06-22-2016, 05:15 PM
RE: Shipping Progress - by benhadad - 06-22-2016, 07:17 PM
RE: Shipping Progress - by Dilbert42 - 06-22-2016, 07:50 PM
RE: Shipping Progress - by Eole - 06-23-2016, 02:11 AM
RE: Shipping Progress - by tllim - 06-24-2016, 02:23 AM
RE: Shipping Progress - by tllim - 06-28-2016, 03:13 AM
RE: Shipping Progress - by Eole - 06-28-2016, 05:43 AM
RE: Shipping Progress - by Jacco - 06-23-2016, 04:21 AM
RE: Shipping Progress - by tllim - 06-28-2016, 09:08 PM
RE: Shipping Progress - by Michael C - 07-02-2016, 10:42 AM
RE: Shipping Progress - by Michael C - 07-08-2016, 12:05 AM
RE: Shipping Progress - by tllim - 07-02-2016, 11:10 PM
RE: Shipping Progress - by smokinimages - 06-23-2016, 07:05 AM
RE: Shipping Progress - by kharder - 06-23-2016, 09:49 AM
RE: Shipping Progress - by tllim - 06-24-2016, 02:25 AM
RE: Shipping Progress - by tllim - 06-28-2016, 03:09 AM
RE: Shipping Progress - by hazerty - 06-23-2016, 02:31 PM
RE: Shipping Progress - by tllim - 06-24-2016, 02:29 AM
RE: Shipping Progress - by adk_mechetech - 06-23-2016, 03:24 PM
RE: Shipping Progress - by tllim - 06-24-2016, 02:15 AM
RE: Shipping Progress - by tllim - 06-28-2016, 03:17 AM
RE: Shipping Progress - by debito128 - 06-24-2016, 01:34 AM
RE: Shipping Progress - by tllim - 06-24-2016, 02:17 AM
RE: Shipping Progress - by debito128 - 06-24-2016, 04:43 AM
RE: Shipping Progress - by debito128 - 06-27-2016, 04:11 AM
RE: Shipping Progress - by tllim - 07-02-2016, 11:13 PM
RE: Shipping Progress - by smokinimages - 06-24-2016, 08:44 AM
RE: Shipping Progress - by tllim - 06-26-2016, 08:05 PM
RE: Shipping Progress - by tllim - 06-28-2016, 02:44 AM
RE: Shipping Progress - by montero65 - 06-24-2016, 09:54 AM
RE: Shipping Progress - by tllim - 06-26-2016, 08:01 PM
RE: Shipping Progress - by netsailor - 06-25-2016, 04:50 AM
RE: Shipping Progress - by tllim - 06-26-2016, 08:04 PM
RE: Shipping Progress - by tllim - 06-28-2016, 02:46 AM
RE: Shipping Progress - by Michele3D - 06-25-2016, 06:24 AM
RE: Shipping Progress - by Michele3D - 06-27-2016, 04:13 AM
RE: Shipping Progress - by mtcomp - 06-25-2016, 06:37 AM
RE: Shipping Progress - by clarkss12 - 06-25-2016, 07:52 AM
RE: Shipping Progress - by pinkelephants - 06-25-2016, 10:02 PM
RE: Shipping Progress - by xorrizon - 06-25-2016, 12:46 PM
RE: Shipping Progress - by tllim - 06-26-2016, 08:00 PM
RE: Shipping Progress - by tllim - 06-28-2016, 09:01 PM
RE: Shipping Progress - by xorrizon - 06-29-2016, 02:48 AM
RE: Shipping Progress - by tllim - 06-29-2016, 06:12 PM
RE: Shipping Progress - by xorrizon - 07-06-2016, 12:19 PM
RE: Shipping Progress - by tllim - 07-07-2016, 10:44 AM
RE: Shipping Progress - by benhadad - 06-25-2016, 03:46 PM
RE: Shipping Progress - by tllim - 06-26-2016, 07:51 PM
RE: Shipping Progress - by benhadad - 06-26-2016, 09:17 PM
RE: Shipping Progress - by benhadad - 06-27-2016, 08:15 AM
RE: Shipping Progress - by heday - 06-26-2016, 11:52 AM
RE: Shipping Progress - by tllim - 06-26-2016, 07:55 PM
RE: Shipping Progress - by StillWaiting - 06-26-2016, 05:30 PM
RE: Shipping Progress - by tllim - 06-26-2016, 07:53 PM
RE: Shipping Progress - by montero65 - 06-26-2016, 08:02 PM
RE: Shipping Progress - by yin0203 - 06-26-2016, 08:51 PM
RE: Shipping Progress - by yin0203 - 06-27-2016, 12:28 AM
Backer #18,347 - by zzarko - 06-27-2016, 12:38 AM
RE: Backer #18,347 - by zzarko - 07-09-2016, 01:17 AM
RE: Shipping Progress - by blakeslade - 06-27-2016, 11:47 AM
RE: Shipping Progress - by tllim - 06-27-2016, 09:48 PM
RE: Shipping Progress - by blakeslade - 06-28-2016, 03:45 AM
RE: Shipping Progress - by tllim - 06-28-2016, 08:39 PM
RE: Shipping Progress - by blakeslade - 07-04-2016, 06:08 AM
RE: Shipping Progress - by blakeslade - 07-08-2016, 08:17 AM
RE: Shipping Progress - by tllim - 07-14-2016, 06:25 PM
RE: Shipping Progress - by scdbeebe - 06-27-2016, 04:20 PM
RE: Shipping Progress - by wesk - 06-27-2016, 09:34 PM
RE: Shipping Progress - by tllim - 06-27-2016, 09:52 PM
RE: Shipping Progress - by scdbeebe - 06-30-2016, 11:08 AM
RE: Shipping Progress - by birdcatx7 - 06-27-2016, 04:39 PM
RE: Shipping Progress - by mikey0000 - 06-27-2016, 09:07 PM
RE: Shipping Progress - by tllim - 06-28-2016, 02:30 AM
RE: Shipping Progress - by tllim - 06-28-2016, 08:53 PM
RE: Shipping Progress - by Lucifershadows - 06-27-2016, 10:08 PM
RE: Shipping Progress - by tllim - 06-27-2016, 11:04 PM
RE: Shipping Progress - by Lucifershadows - 06-28-2016, 06:35 PM
RE: Shipping Progress - by tllim - 06-28-2016, 08:48 PM
RE: Shipping Progress - by Lucifershadows - 06-30-2016, 02:39 AM
RE: Shipping Progress - by Inuyasha - 06-28-2016, 01:08 PM
RE: Shipping Progress - by thermistor - 06-28-2016, 02:19 PM
RE: Shipping Progress - by tllim - 06-28-2016, 08:43 PM
RE: Shipping Progress - by tllim - 07-03-2016, 04:14 PM
RE: Shipping Progress - by Michael C - 06-28-2016, 04:29 PM
RE: Shipping Progress - by Zoidiano0 - 06-28-2016, 09:37 PM
RE: Shipping Progress - by tllim - 06-29-2016, 05:43 PM
RE: Shipping Progress - by yin0203 - 06-28-2016, 11:08 PM
RE: Shipping Progress - by tllim - 06-29-2016, 05:48 PM
RE: Shipping Progress - by chris88 - 06-29-2016, 03:23 AM
RE: Shipping Progress - by tllim - 06-29-2016, 06:00 PM
RE: Shipping Progress - by chris88 - 07-05-2016, 05:52 AM
RE: Shipping Progress - by tllim - 07-05-2016, 09:43 PM
RE: Shipping Progress - by tllim - 07-06-2016, 12:29 AM
RE: Shipping Progress - by cristiandan - 06-29-2016, 05:06 AM
RE: Shipping Progress - by tllim - 06-29-2016, 05:51 PM
RE: Shipping Progress - by tllim - 07-02-2016, 10:48 PM
RE: Shipping Progress - by cristiandan - 07-10-2016, 08:37 AM
RE: Shipping Progress - by tllim - 07-14-2016, 06:14 PM
RE: Shipping Progress - by cristiandan - 10-14-2016, 08:30 AM
RE: Shipping Progress - by Bart333 - 06-29-2016, 05:10 AM
RE: Shipping Progress - by figos - 06-29-2016, 05:16 AM
RE: Shipping Progress - by sarts0703 - 06-29-2016, 05:23 AM
RE: Shipping Progress - by tllim - 06-29-2016, 06:04 PM
RE: Shipping Progress - by sarts0703 - 06-30-2016, 10:18 AM
RE: Shipping Progress - by Macksteez - 06-29-2016, 07:17 AM
RE: Shipping Progress - by damian1m - 06-29-2016, 07:32 AM
RE: Shipping Progress - by vinn - 06-30-2016, 03:32 AM
RE: Shipping Progress - by hahn - 06-30-2016, 01:05 PM
RE: Shipping Progress - by hahn - 07-02-2016, 02:56 AM
RE: Shipping Progress - by tllim - 07-02-2016, 09:58 PM
RE: Shipping Progress - by hyperjeff - 06-30-2016, 07:40 PM
RE: Shipping Progress - by hyperjeff - 07-02-2016, 11:46 AM
RE: Shipping Progress - by iacobaeus - 07-01-2016, 03:18 AM
RE: Shipping Progress - by tllim - 07-02-2016, 10:07 PM
RE: Shipping Progress - by Crispin - 07-01-2016, 07:33 AM
RE: Shipping Progress - by tllim - 07-02-2016, 10:09 PM
RE: Shipping Progress - by Crispin - 07-03-2016, 02:56 AM
RE: Shipping Progress - by Brientim - 07-01-2016, 12:12 PM
RE: Shipping Progress - by tllim - 07-02-2016, 10:19 PM
RE: Shipping Progress - by Brientim - 07-04-2016, 10:39 AM
RE: Shipping Progress - by Brientim - 07-13-2016, 08:55 AM
RE: Shipping Progress - by yin0203 - 07-02-2016, 02:15 AM
RE: Shipping Progress - by Pineplayer - 07-02-2016, 11:18 AM
RE: Shipping Progress - by tllim - 07-02-2016, 10:03 PM
RE: Shipping Progress - by Pineplayer - 07-03-2016, 07:01 AM
RE: Shipping Progress - by Pineplayer - 07-13-2016, 06:25 AM
RE: Shipping Progress - by tllim - 07-14-2016, 06:04 PM
RE: Shipping Progress - by tllim - 07-15-2016, 04:13 PM
RE: Shipping Progress - by Pineplayer - 07-15-2016, 05:58 PM
RE: Shipping Progress - by Pineplayer - 07-19-2016, 07:49 AM
RE: Shipping Progress - by tllim - 07-22-2016, 07:25 PM
RE: Shipping Progress - by rikkyrik - 07-03-2016, 08:33 AM
RE: Shipping Progress - by nygger - 07-03-2016, 08:47 AM
RE: Shipping Progress - by Zurc - 07-03-2016, 05:24 PM
RE: Shipping Progress - by tllim - 07-04-2016, 05:38 PM
RE: Shipping Progress - by figos - 07-04-2016, 03:05 AM
RE: Shipping Progress - by tllim - 07-04-2016, 05:43 PM
RE: Shipping Progress - by tllim - 07-04-2016, 05:44 PM
RE: Shipping Progress - by jtgiroux - 07-04-2016, 11:49 AM
RE: Shipping Progress - by tllim - 07-04-2016, 05:47 PM
RE: Shipping Progress - by cyphergenetics - 07-04-2016, 02:32 PM
RE: Shipping Progress - by tllim - 07-04-2016, 05:52 PM
RE: Shipping Progress - by aai - 07-05-2016, 04:18 AM
RE: Shipping Progress - by tllim - 07-05-2016, 09:42 PM
RE: Shipping Progress - by aai - 07-06-2016, 02:58 PM
RE: Shipping Progress - by MarkHaysHarris777 - 07-06-2016, 03:51 PM
RE: Shipping Progress - by tllim - 07-07-2016, 10:48 AM
RE: Shipping Progress - by tllim - 07-15-2016, 02:43 PM
RE: Shipping Progress - by Mijoro - 07-05-2016, 08:11 AM
RE: Shipping Progress - by tllim - 07-06-2016, 12:27 AM
RE: Shipping Progress - by Inuyasha - 07-05-2016, 03:13 PM
RE: Shipping Progress - by tllim - 07-05-2016, 09:44 PM
RE: Shipping Progress - by mFinnholm - 07-06-2016, 04:54 AM
RE: Shipping Progress - by blackt1ger - 07-06-2016, 07:24 AM
RE: Shipping Progress - by Linux Runner - 07-06-2016, 10:45 AM
RE: Shipping Progress - by Linux Runner - 07-08-2016, 10:30 AM
RE: Shipping Progress - by Linux Runner - 07-11-2016, 08:28 PM
RE: Shipping Progress - by Linux Runner - 07-13-2016, 10:23 AM
RE: Shipping Progress - by tllim - 07-14-2016, 05:59 PM
RE: Shipping Progress - by Linux Runner - 07-14-2016, 06:05 PM
RE: Shipping Progress - by Ghost - 07-07-2016, 01:27 AM
RE: Shipping Progress - by xorrizon - 07-07-2016, 05:05 AM
RE: Shipping Progress - by YvesHanoulle - 07-07-2016, 04:24 AM
RE: Shipping Progress - by tllim - 07-07-2016, 10:52 AM
RE: Shipping Progress - by britva - 07-07-2016, 05:22 AM
RE: Shipping Progress - by tllim - 07-07-2016, 10:55 AM
RE: Shipping Progress - by tllim - 07-14-2016, 06:20 PM
RE: Shipping Progress - by blackt1ger - 07-07-2016, 10:18 PM
RE: Shipping Progress - by cursebreaker - 07-08-2016, 04:37 AM
RE: Shipping Progress - by tllim - 07-14-2016, 06:18 PM
RE: Shipping Progress - by Jacco - 07-08-2016, 07:39 AM
RE: Shipping Progress - by Michael C - 07-11-2016, 09:59 AM
RE: Shipping Progress - by blackt1ger - 07-10-2016, 11:19 PM
RE: Shipping Progress - by tllim - 07-14-2016, 06:09 PM
RE: Shipping Progress - by NeoDrakkon - 07-12-2016, 02:14 AM
RE: Shipping Progress - by NeoDrakkon - 07-14-2016, 10:11 AM
RE: Shipping Progress - by tllim - 07-14-2016, 05:54 PM
RE: Shipping Progress - by Macksteez - 07-13-2016, 07:14 AM
RE: Shipping Progress - by tllim - 07-14-2016, 06:01 PM
RE: Shipping Progress - by Macksteez - 08-06-2016, 06:26 AM
RE: Shipping Progress - by TheMonkeyKing - 07-13-2016, 08:27 AM
RE: Shipping Progress - by Linux Runner - 07-14-2016, 08:50 PM
RE: Shipping Progress - by tllim - 07-15-2016, 02:31 PM
RE: Shipping Progress - by christianstarling - 07-15-2016, 04:16 PM
RE: Shipping Progress - by tllim - 07-16-2016, 11:14 PM
RE: Shipping Progress - by christianstarling - 07-17-2016, 03:43 PM
RE: Shipping Progress - by christianstarling - 07-23-2016, 12:12 AM
RE: Shipping Progress - by tllim - 07-27-2016, 12:07 PM
RE: Shipping Progress - by niem - 07-16-2016, 03:34 AM
RE: Shipping Progress - by Tiszai Istvan - 07-18-2016, 07:09 AM
RE: Shipping Progress - by Rigor_M - 07-18-2016, 09:37 AM
RE: Shipping Progress - by tllim - 07-22-2016, 07:24 PM
RE: Shipping Progress - by Cyrel - 07-21-2016, 10:42 PM
RE: Shipping Progress - by tllim - 07-22-2016, 07:27 PM
RE: Shipping Progress - by 1cheapmike - 07-22-2016, 10:54 PM
RE: Shipping Progress - by trik57r - 07-25-2016, 08:21 AM
RE: Shipping Progress - by Linux Runner - 07-25-2016, 08:49 PM
RE: Shipping Progress - by wanthalf - 07-26-2016, 08:24 AM
RE: Shipping Progress - by jtgiroux - 07-30-2016, 05:09 PM
RE: Shipping Progress - by tllim - 07-30-2016, 07:37 PM
RE: Shipping Progress - by HorreC - 08-04-2016, 10:11 AM
RE: Shipping Progress - by tllim - 08-05-2016, 12:53 PM
RE: Shipping Progress - by tycoonbob - 08-05-2016, 08:34 AM
RE: Shipping Progress - by tllim - 08-05-2016, 12:54 PM
RE: Shipping Progress - by bonterra - 08-08-2016, 05:58 AM
RE: Shipping Progress - by tycoonbob - 08-14-2016, 11:42 PM
RE: Shipping Progress - by janeku - 08-05-2016, 01:17 PM
RE: Shipping Progress - by OxfordMaker - 08-08-2016, 02:27 PM
RE: Shipping Progress - by guysamuel - 08-10-2016, 01:54 PM
RE: Shipping Progress - by yin0203 - 08-15-2016, 09:43 PM
RE: Shipping Progress - by Terra854 - 10-13-2016, 05:07 AM
RE: Shipping Progress - by Scr3wdriv3r - 10-15-2016, 03:19 AM
RE: Shipping Progress - by sukk741 - 12-16-2016, 04:17 AM
RE: Shipping Progress - by tllim - 12-16-2016, 09:32 PM
RE: Shipping Progress - by sukk741 - 12-19-2016, 11:49 PM
RE: Shipping Progress - by Rigor_M - 12-27-2016, 01:23 PM
RE: Shipping Progress - by tllim - 01-02-2017, 12:46 AM
RE: Shipping Progress - by Rigor_M - 01-02-2017, 03:23 PM
RE: Shipping Progress - by jukuuck - 02-15-2017, 01:42 AM
RE: Shipping Progress - by tllim - 02-15-2017, 09:44 AM
RE: Shipping Progress - by jukuuck - 02-19-2017, 10:06 PM
RE: Shipping Progress - by Wizzard - 05-06-2017, 06:01 AM
RE: Shipping Progress - by Fuges - 07-01-2017, 01:43 PM
RE: Shipping Progress - by dkryder - 07-03-2017, 06:19 AM
RE: Shipping Progress - by S3phi40T - 02-27-2018, 03:17 PM
RE: Shipping Progress - by ORB1Rouge - 09-12-2018, 08:54 PM
RE: Shipping Progress - by SimonL - 01-16-2021, 08:32 AM
RE: Shipping Progress - by MNtinkerer - 01-16-2021, 07:20 PM
RE: Shipping Progress - by WarpLover - 02-12-2021, 10:46 AM
RE: Shipping Progress - by dgdimick - 02-13-2021, 04:11 AM
RE: Shipping Progress - by WarpLover - 02-14-2021, 09:19 AM
RE: Shipping Progress - by dgdimick - 02-14-2021, 01:43 PM
RE: Shipping Progress - by WarpLover - 02-14-2021, 02:05 PM
RE: Shipping Progress - by dgdimick - 02-14-2021, 02:29 PM
RE: Shipping Progress - by WarpLover - 02-14-2021, 03:14 PM
RE: Shipping Progress - by dgdimick - 02-14-2021, 05:27 PM
RE: Shipping Progress - by WarpLover - 02-15-2021, 11:58 AM
RE: Shipping Progress - by dgdimick - 02-15-2021, 09:50 PM
RE: Shipping Progress - by TRS-80 - 02-16-2021, 03:04 PM
RE: Shipping Progress - by WarpLover - 02-16-2021, 04:11 PM
RE: Shipping Progress - by dgdimick - 02-16-2021, 04:25 PM
RE: Shipping Progress - by WarpLover - 02-16-2021, 04:52 PM
RE: Shipping Progress - by dgdimick - 02-17-2021, 04:56 AM
RE: Shipping Progress - by WarpLover - 02-17-2021, 10:01 AM
RE: Shipping Progress - by dgdimick - 02-17-2021, 10:17 AM
RE: Shipping Progress - by WarpLover - 02-17-2021, 10:29 AM
RE: Shipping Progress - by dgdimick - 02-17-2021, 11:27 AM
RE: Shipping Progress - by WarpLover - 02-17-2021, 01:04 PM
RE: Shipping Progress - by dgdimick - 02-18-2021, 02:00 PM
RE: Shipping Progress - by WarpLover - 02-18-2021, 03:10 PM
RE: Shipping Progress - by dgdimick - 02-20-2021, 10:30 AM
RE: Shipping Progress - by WarpLover - 02-20-2021, 04:07 PM
RE: Shipping Progress - by dgdimick - 02-25-2021, 11:02 AM
  What happened to $12 EU shipping rate to Poland? Randomuser 5 3,257 12-17-2023, 01:57 PM
Last Post: ashvaganda
  Shipping Alternatives for USA customers FOSSagent0 4 2,916 05-13-2023, 09:44 AM
  Shipping to Canada extremely costly cptantiles 1 1,257 02-28-2023, 11:33 PM
Last Post: calinb
  Shipping TO Hong Kong? hker 1 2,165 07-06-2022, 07:47 PM
Last Post: RuTrainsurfer
  Shipping stuck in: "Airlines Receive" for nearly a month KiteX3 12 8,479 03-26-2022, 03:58 PM
Last Post: dachalife
  Have EU pinephones started shipping since CNY? baigan 6 5,522 02-28-2022, 10:55 PM
  No more standard shipping? kqlnut 3 3,890 07-19-2021, 05:45 AM
Last Post: kqlnut
Question PineBook Pro shipping to India User 22380 2 4,472 06-25-2021, 09:37 PM
Last Post: User 22380
  no shipping notice on my purchase restiforin 0 2,302 06-13-2021, 03:18 PM
Last Post: restiforin
  Shipping service used in Canada MikeJewski 6 12,268 05-17-2021, 04:13 PM
Last Post: optimus
Users browsing this thread: 17 Guest(s)
