Lego Case
(05-05-2016, 09:43 AM)JPCRamos Wrote:
(05-04-2016, 06:37 PM)Luke Wrote:
(05-02-2016, 07:54 PM)JPCRamos Wrote:
(04-30-2016, 11:34 AM)semajcherlagne Wrote:
(04-27-2016, 07:23 AM)JPCRamos Wrote: This is a case i build with the pieces i had available.
This is great!  Can you post a picture of what it looks like with the board inside and things attached?
I just added a
The fan on top is powered via USB, and it has a USB bypass:
Because the connector is too bulky I'll cut it out and wire the fan directly to the expansion pins. I'm deciding between the Pi2 Connector (Pins 4 (5v) and 6 (GND)) and  the Euler "e" Connector (Pins 8 (5v) and 6 (GND)).
The fan speed is controlled manually, it would be great to actually get the software controlling it, but i don't know how to.
I had seen the post of the Lego case you based this on and I have started tweaking it very similarly, I found the 40mm 12v fan that I had was almost molded for the Lego studs to fit, do so I ordered a five volt version that will be functional.  Likewise I am working on a fictional power reset switch, but have to wait for my buttons to arrive as I wish to have both.  I am also trying to work a way to leave access to the io headers but we'll will probably nix the idea I decide to leave it on my entertainment unit.  The problem is I I want two or three more pines play with.  I will post pictures in the morning.
Lego Case? - by Kiryu - 01-30-2016, 11:59 PM
Lego Case - by steveitsupport - 05-04-2016, 06:25 PM
Lego Case - by tallpaulca - 05-09-2016, 08:45 PM
RE: Lego Case - by MrWizerd - 05-09-2016, 11:29 PM
RE: Lego Case - by JPCRamos - 05-10-2016, 06:54 AM
RE: Lego Case - by MrWizerd - 05-10-2016, 08:58 AM
RE: Lego Case - by MrWizerd - 05-12-2016, 01:24 AM
RE: Lego Case - by Tarjei85 - 05-13-2016, 06:46 AM
RE: Lego Case - by MrWizerd - 05-13-2016, 07:17 AM
RE: Lego Case - by Tarjei85 - 05-13-2016, 09:41 AM
RE: Lego Case - by MrWizerd - 05-13-2016, 04:55 PM
RE: Lego Case - by Tarjei85 - 05-14-2016, 12:23 AM
RE: Lego Case - by MrWizerd - 05-14-2016, 02:54 AM
RE: Lego Case - by Tarjei85 - 05-14-2016, 03:46 AM
RE: Lego Case - by Tarjei85 - 05-14-2016, 06:25 AM
RE: Lego Case - by JPCRamos - 05-14-2016, 06:17 PM
RE: Lego Case - by Tarjei85 - 05-15-2016, 04:05 PM
RE: Lego Case - by MrWizerd - 05-16-2016, 12:19 AM
RE: Lego Case - by Tarjei85 - 05-16-2016, 01:07 AM
RE: Lego Case - by MrWizerd - 05-16-2016, 01:31 AM
RE: Lego Case - by Tarjei85 - 05-16-2016, 01:51 AM
RE: Lego Case - by Tarjei85 - 05-16-2016, 04:12 AM
RE: Lego Case - by MrWizerd - 05-16-2016, 02:06 PM
RE: Lego Case - by Tarjei85 - 05-16-2016, 02:58 PM
RE: Lego Case - by CaptainZalo - 05-16-2016, 03:17 PM
RE: Lego Case - by Tarjei85 - 05-16-2016, 03:24 PM
RE: Lego Case - by CaptainZalo - 05-17-2016, 02:01 PM
RE: Lego Case - by Tarjei85 - 05-19-2016, 12:16 AM
RE: Lego Case - by MrWizerd - 05-16-2016, 03:41 PM
RE: Lego Case - by Tarjei85 - 05-16-2016, 11:41 PM
RE: Lego Case - by MrWizerd - 05-17-2016, 01:05 AM
RE: Lego Case - by Tarjei85 - 05-20-2016, 03:19 AM
RE: Lego Case - by MrWizerd - 05-20-2016, 04:06 AM
RE: Lego Case - by MrWizerd - 05-22-2016, 03:47 PM
RE: Lego Case - by Tarjei85 - 05-22-2016, 10:55 PM
RE: Lego Case - by MrWizerd - 05-22-2016, 11:27 PM
RE: Lego Case - by 5kb - 05-26-2016, 09:17 PM
RE: Lego Case - by MrWizerd - 05-26-2016, 10:26 PM
RE: Lego Case - by 5kb - 05-27-2016, 10:44 PM
RE: Lego Case - by MrWizerd - 05-28-2016, 02:49 AM
RE: Lego Case - by apostols - 07-05-2016, 11:01 AM
RE: Lego Case - by Tarjei85 - 07-05-2016, 04:06 PM
RE: Lego Case - by apostols - 07-06-2016, 08:53 AM
RE: Lego Case - by MarkHaysHarris777 - 07-06-2016, 09:35 AM
RE: Lego Case - by Tarjei85 - 07-06-2016, 02:34 PM
RE: Lego Case - by tllim - 07-07-2016, 12:03 PM
RE: Lego Case - by kappadoky - 08-24-2016, 02:10 AM
RE: Lego Case - by mfjnext - 03-17-2017, 12:05 PM
RE: Lego Case - by Luke - 03-17-2017, 02:12 PM
RE: Lego Case - by Tarjei85 - 03-30-2017, 10:11 AM
RE: Lego Case - by Luke - 03-30-2017, 11:36 AM
RE: Lego Case? - by Ghost - 01-31-2016, 01:01 PM
Lego Case - by leongzhi - 02-19-2016, 04:36 AM
RE: Lego Case - by tllim - 02-20-2016, 02:25 AM
RE: Lego Case - by Tarjei85 - 03-31-2016, 08:13 AM
RE: Lego Case - by leongzhi - 04-01-2016, 05:27 AM
RE: Lego Case - by Tarjei85 - 04-01-2016, 06:24 AM
RE: Lego Case - by atomicSoC - 08-26-2016, 08:13 AM
RE: Lego Case - by Tarjei85 - 08-26-2016, 09:38 AM
RE: Lego Case - by leongzhi - 04-18-2016, 09:52 PM
RE: Lego Case - by frewind - 04-19-2016, 01:53 AM
RE: Lego Case - by JPCRamos - 04-27-2016, 07:23 AM
RE: Lego Case - by semajcherlagne - 04-30-2016, 11:34 AM
RE: Lego Case - by JPCRamos - 05-02-2016, 07:54 PM
RE: Lego Case - by tllim - 05-03-2016, 08:54 AM
RE: Lego Case - by Luke - 05-04-2016, 06:37 PM
RE: Lego Case - by JPCRamos - 05-05-2016, 09:43 AM
RE: Lego Case - by MrWizerd - 05-06-2016, 02:45 AM
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,522 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 3,988 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 12,391 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,596 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 19,064 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 10,103 06-28-2017, 04:05 AM
Last Post: ishwest
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 13,134 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 5,333 10-04-2016, 02:45 AM
Last Post: modmypi
Photo Weatherproof case build ltorsini 10 29,494 10-02-2016, 10:49 PM
Last Post: ltorsini
  Playbox case orderable? schindlb 8 13,685 10-02-2016, 08:20 AM
Last Post: schindlb
