Z Wave Module and still using GPIO
(01-14-2017, 06:25 PM)bang Wrote: Just realized that the Z wave module is connected to the full GPIO Sad
Is there anyway you still could use any GPIO pins (for input / output) when the Z wave module is connected?
Is it using all of the pins ?
hi bang, the Z-wave module is a uart(x) device; that is, it is controlled ( in the case of the module that plugs into the PI bus ) by uart(2) on device /dev/ttyS2.
The module does not have to be plugged into the bus pins with the adapter;  it may be connected ( with proper knowledge ) to the uart of choice ( uart(2) pi bus, uart(3) euler bus, uart(4) euler bus ).
The only pins that are required is the Vcc, ground, Tx, and Rx pins.
The Z-wave modules are serial devices.
Z Wave Module and still using GPIO - by bang - 01-14-2017, 06:25 PM
RE: Z Wave Module and still using GPIO - by MarkHaysHarris777 - 01-14-2017, 08:34 PM
RE: Z Wave Module and still using GPIO - by bang - 01-16-2017, 03:12 AM
Question Z-Wave module pinout to make it compatible with Pi b+ ebretteville 59 85,427 07-12-2019, 08:55 AM
Last Post: kris240376
Sad Z-Wave and openzwave+node-openzwave-shared saro 2 6,363 09-01-2017, 05:22 AM
Last Post: saro
  Z-Wave - Full and Low Power Inclusion mode B34N 1 4,310 03-26-2017, 06:03 PM
Last Post: B34N
  KICAD Quick Lib and Module Generator mbt28 1 4,734 02-12-2017, 10:45 PM
  Z-Wave US module with adapter aegrotatio 4 7,342 01-08-2017, 12:03 AM
Last Post: aegrotatio
  RaZberry Module (z-wave) need support to get it working! Luxus 13 19,184 11-03-2016, 02:04 AM
Last Post: Luxus
  Z-Wave module problem vintagewaffle 0 2,374 10-26-2016, 10:50 AM
Last Post: vintagewaffle
Video Australia/New Zealand Z-Wave module Jnimmo 46 54,981 10-02-2016, 02:25 PM
  [EU] Z-Wave module tutorials? meowbot 2 5,375 09-13-2016, 07:54 PM
Last Post: Ghost
  New module: POT board Crispin 25 40,737 07-12-2016, 08:47 PM
Last Post: khgoh
