power supply
(03-15-2016, 09:28 AM)tllim Wrote:
(03-15-2016, 09:24 AM)SkairkrohBule Wrote:
(03-15-2016, 06:07 AM)gax1985 Wrote:
(01-26-2016, 11:40 AM)Nilocsemliw Wrote: Both should work fine.
I think that you could use less than 2 Amps but you wouldn't have the full capability of the board 2.1 Amps is just the recommend power supply
Hello !
   Would an ipad mini charger work ?
    Thanks !
I think iPads have proprietary connectors not standard micro usb, so I don't think so.
Th iiPad charger can work, just not using the lighting cable and change with good micro USB cable.
Has anyone tried a 1500 ma charger. I can't get the board to boot up get a red light every time i plug it in Only have chargers that are 5 V 1500 ma
power supply - by Phlebas - 02-17-2016, 05:18 AM
RE: power supply - by Ghost - 02-17-2016, 05:29 AM
RE: power supply - by Phlebas - 02-17-2016, 05:38 AM
RE: power supply - by MichaelMeissner - 02-17-2016, 07:03 AM
RE: power supply - by Ghost - 02-17-2016, 07:05 AM
RE: power supply - by Phlebas - 02-17-2016, 08:49 AM
RE: power supply - by tllim - 02-17-2016, 09:49 PM
RE: power supply - by By-Jokese - 02-21-2016, 06:15 AM
RE: power supply - by tllim - 02-21-2016, 09:13 PM
RE: USB 5V 2A Or 5V 2.1A power supply with microusb cable can run PINE64? - by ruyaguilar - 03-15-2016, 09:51 PM
  New RockPro64 Power Up Problem enorbet2 7 5,204 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,874 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,956 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,449 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 12,637 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 5,143 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,806 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,176 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,570 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 6,170 10-23-2016, 12:16 PM
Last Post: dkryder
