Power Ribbon for LCD Display
I put together my PINE with the LCD Touchpanel and everything works great. However now I have the enclosure and the original power ribbon is to short.... Does anyone know where I can get a longer power ribbon? I tried eBay and got a new one but now the Pine doesn't power on with it. I switched it out to the old ribbon and it powers on fine so I'm pretty sure I just got the wrong ribbon.
It says AWM 20624 80C 60V VW-1 on the ribbon. Any help would be appreciated.
i bought a a cable & extender on ebay .
http://www.ebay.com/itm/FFC-FPC-30-pin-0...1985309073
this worked. i also bought just a ffc cable on digikey,
http://www.digikey.cz/product-detail/en/...ND/4573405
and that works.
the one from ebay also has AWM 20264 80C 60V VW-1 on ribbon so i do not think that your piece with that marking means all pieces with that marking do not work. i'd suggest to unhook everything, hook back up, perhaps burn a new sd card. just go from start and try again.
You could always just get the C4 Labs LCD enclosure That way you won't need a longer cable AND you can take the enclosure apart if you needed to.
Matt
(10-23-2016, 07:42 AM)Bluphire Wrote: You could always just get the C4 Labs LCD enclosure That way you won't need a longer cable AND you can take the enclosure apart if you needed to.
Matt
that case is very good looking but fails to support the use of the multiport board or the dev board.
  New RockPro64 Power Up Problem enorbet2 7 13,935 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 3,498 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,608 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 4,507 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 24,731 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 8,495 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 8,073 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 11,989 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 4,104 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  No display at boot up Dremtime 2 8,050 09-13-2016, 10:35 AM
Last Post: Dremtime
