Android kernel booting
(02-14-2016, 03:32 PM)patrickhwood Wrote:
(02-14-2016, 12:51 PM)drag00n Wrote: Yes, part5, but no cksums... I hex edited it and worked [FACE WITH TEARS OF JOY]
Well, my box works with 3.10... I have to test hdmi, WiFi and so... Tty stops working but i have no inittab so ill add it to rc.local until i realize a way to do it properly with systemd, so new to me...eth100 working, later ill try to use 1000 but should be the same.
Also surprised with temperature... Android burned my finger when idle, and with linux i can barely tell if it is powered on...
Talk later..
Drag00n
I think you might notice that the environment has reset to the default one rather than taking it from partition 5 after you modified it.  Are you getting the uboot countdown from 3 now?  bootdelay is set to 0 in the environment on the SD partition, which disables it.
Oh my, you're totally right...
I missed the line:
*** Warning - bad CRC, using default environment
So I got very lucky that default goes with selinux disabled...
And yes, now I can enter sunxi prompt from u-boot. (before I was thinking I was too slow to hit anything...)
Sorry, but I'm relatively new to ARM devices and bootloaders, be patient with me Wink
Thanks for the point.
drag00n
PS: Can I find somewhere good info about how u-boot works? I am totally blind about it and would like to know more...
Android kernel booting - by drag00n - 02-13-2016, 07:05 AM
RE: Android kernel booting - by patrickhwood - 02-13-2016, 10:01 AM
RE: Android kernel booting - by drag00n - 02-13-2016, 10:04 AM
RE: Android kernel booting - by drag00n - 02-14-2016, 03:45 AM
RE: Android kernel booting - by patrickhwood - 02-14-2016, 09:47 AM
RE: Android kernel booting - by drag00n - 02-14-2016, 12:51 PM
RE: Android kernel booting - by patrickhwood - 02-14-2016, 03:32 PM
RE: Android kernel booting - by drag00n - 02-14-2016, 05:02 PM
RE: Android kernel booting - by patrickhwood - 02-14-2016, 08:31 PM
RE: Android kernel booting - by drag00n - 02-15-2016, 03:05 AM
RE: Android kernel booting - by tllim - 02-15-2016, 07:06 AM
RE: Android kernel booting - by Hahaburger - 02-15-2016, 08:10 AM
RE: Android kernel booting - by tllim - 02-15-2016, 04:11 PM
RE: Android kernel booting - by tllim - 02-15-2016, 10:04 PM
RE: Android kernel booting - by khgoh - 02-16-2016, 01:33 AM
RE: Android kernel booting - by drag00n - 02-15-2016, 07:14 AM
RE: Android kernel booting - by patrickhwood - 02-17-2016, 12:09 AM
RE: Android kernel booting - by longsleep - 02-17-2016, 01:11 AM
RE: Android kernel booting - by tllim - 02-17-2016, 06:28 AM
RE: Android kernel booting - by umiddelb - 02-17-2016, 06:51 AM
RE: Android kernel booting - by longsleep - 02-17-2016, 08:53 AM
RE: Android kernel booting - by tllim - 02-17-2016, 09:52 PM
RE: Android kernel booting - by longsleep - 02-18-2016, 01:43 AM
RE: Android kernel booting - by taros - 02-18-2016, 09:51 AM
  PineA64+: Audio in 5.0 Kernel puzzles 6 9,131 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 2,935 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 2,640 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 73,307 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,719 06-21-2018, 05:45 PM
Last Post: evilbunny
  Kernel for A64 git longsleep 179 286,947 03-25-2018, 03:25 PM
Last Post: Luke
  Gentoo for pine64 - longsleep kernel incoherent 0 3,659 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 3,325 07-13-2017, 08:38 PM
Last Post: cztian
  Mainline kernel [Solved] jeroen79 11 19,599 02-08-2017, 06:19 AM
Last Post: umiddelb
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 4,709 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
