Power over Ethernet (PoE)
(02-10-2016, 12:35 PM)WLR Wrote: There were requests to embed PoE on the PINE 64 board. Doing so would take a lot of valuable real estate on the board. It also adds complexity to the power circuits and general board layout. Given the size of the board, I think we'd all agree that the design & functionality choices made by the PINE 64 team have been good ones.
So... As it stands now the best way to get PoE is to do it is externally.
It was suggested in another thread to use the "extra" pairs in the CAT 5/6 cable by splitting them out. This compromises the 802.11 specs, but likely will work for short cables. There will be a significant voltage drop on long cables. Putting in higher voltage supplies to compensate will work, but the voltage drop will vary depending on current draw which can be an issue in some applications. That said, it'll work, but there can be significant power issues doing this.
The better and (IMO) correct way would be to use an external 802.3af compliant power device (e.g. something like a TP-LINK TL-POE10R) paired with a POE switch (e.g. something like a TP-LINK TL-SF1008P) or a 802.3af injector. 802.3af allows 25 watts, the previous standard was 15.4 with 12.95 watts available, so 2 amps @5v is no issue.
NOTE: the power out of the TP-LINK device is a barrel connector, so one would need to make a cable or use something ready made like this http://tinyurl.com/usb2m.
Disclaimer: I have no affiliation with TP-LINK, but have used these devices in the past and they worked well.
Just my $0.01 worth.
You have a valid concern, we have explored with PoE vendor and conclusion is lacking PCB real estate for proper 802.3af implementation. We are introducing a 802.3af compliance splitter that work with Pine A64 board.
Power over Ethernet (PoE) - by WLR - 02-10-2016, 12:35 PM
RE: Power over Ethernet (PoE) - by tllim - 02-10-2016, 07:14 PM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 5,247 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 5,466 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 19,227 01-05-2017, 12:37 AM
Last Post: swinging
  Power switch circuit drewh 43 79,682 09-19-2016, 09:17 AM
Last Post: tampadave
  Power Off / Reset Buttons - DietPi casmiguefl 4 10,592 08-12-2016, 05:28 PM
Last Post: casmiguefl
  power Circuit polo 28 52,253 07-01-2016, 07:06 PM
Last Post: pfeerick
  USB NIC / Ethernet thegroverest 1 3,637 07-01-2016, 01:41 PM
Last Post: dkryder
  Hardware-Bugs: No HDMI->DVI-Output / Crashes upon Ethernet Xyntec 3 6,591 04-02-2016, 09:42 AM
Last Post: DaveKram
  USB HDD Power eender 5 11,687 02-06-2016, 09:30 PM
Last Post: blktiger
