USB HDD Power
Hey Guys,
I just wondered if i want to attach a external usb HDD to the PINE64 do i need a powered usb hub or not ?
Because the HDD i own, only got one usb cable and no power supply
(12-27-2015, 06:06 PM)eender Wrote: Hey Guys,
The Pine A64 USB port can supply +5V 500mA power, just make sure that your USB HDD consume less than this figure.
Is there a way to boost the capability of the Pine64 to take USB powered hard drives? Would attaching a second battery fix this?
(01-29-2016, 02:04 AM)Gearsoul Wrote: Is there a way to boost the capability of the Pine64 to take USB powered hard drives? Would attaching a second battery fix this?
The Pine will support USB powered hard drives whose power consumption is less than or equal to 500mA. A good many USB powered hard drives should work just fine.
Cool, cool~ Good to know! :3 I'll just have to check carefully when purchasing/using them in the future.
(01-29-2016, 05:42 AM)Gearsoul Wrote: Cool, cool~ Good to know! :3 I'll just have to check carefully when purchasing/using them in the future.
Not sure what you'll be using your Pine for but why not just by an external enclosure that uses AC power?
Backer number: 24,762
Backerkit STATUS: Items Received
  Z-Wave - Full and Low Power Inclusion mode B34N 1 7,341 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 7,537 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 24,363 01-05-2017, 12:37 AM
Last Post: swinging
  Power switch circuit drewh 43 100,741 09-19-2016, 09:17 AM
Last Post: tampadave
  Power Off / Reset Buttons - DietPi casmiguefl 4 14,088 08-12-2016, 05:28 PM
Last Post: casmiguefl
  power Circuit polo 28 67,076 07-01-2016, 07:06 PM
Last Post: pfeerick
  Power over Ethernet (PoE) WLR 1 8,561 02-10-2016, 07:14 PM
