Pine64 2Gb not booting [SOLVED]
Options:
Try different power supply
Try different microSD card
Try different screen/monitor/TV
Recommend choosing one of these and using process of elimination. These are the three most common issues.
Notes:
  • LCD panel connections should be connected with the contacts facing down
  • Pre-loaded Android image is probably not the LCD image
  • (There are two different Android images - one for LCD, another for HDMI)
  • If trying an HDMI Android image, only screens with either 1080p or 720p resolutions will likely work
  • Pine supplied power supply and microSD are not the greatest quality
  • A 5.1V 2.5A power supply is recommended
  • A Samsung Evo microSD card is recommended (though I have booted the Android LCD image just fine using the Pine supplied microSD)
Pine64 2Gb not booting [SOLVED] - by negativ3 - 10-08-2016, 10:08 AM
RE: Pine64 2Gb not booting - by Ghost - 10-08-2016, 10:59 AM
RE: Pine64 2Gb not booting - by negativ3 - 10-08-2016, 11:29 AM
RE: Pine64 2Gb not booting - by Ghost - 10-08-2016, 11:51 AM
RE: Pine64 2Gb not booting - by negativ3 - 10-08-2016, 12:03 PM
RE: Pine64 2Gb not booting - by negativ3 - 10-08-2016, 10:59 PM
RE: Pine64 2Gb not booting [SOLVED] - by Marty999 - 10-19-2016, 01:33 AM
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,763 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,469 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 5,780 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 3,990 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 151,412 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 5,791 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 16,395 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 8,362 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 209,507 10-11-2018, 11:35 PM
Last Post: Technolab88
  Pine64 installer way slow flashing Paraplegic Racehorse 2 4,523 01-10-2018, 04:05 PM
Last Post: dkryder
